Real analysis problems (Rudin)
This discussion focuses on solving problems from Walter Rudin's "Real and Complex Analysis," specifically from the first chapter on Abstract Integration. Key problems include proving the measurability of sets defined by functions f and g, as well as the convergence of sequences of measurable functions. Participants emphasize the necessity of establishing properties of measurable sets and sigma-algebras, while also discussing the application of the Dominated Convergence Theorem and Fatou's Lemma in specific scenarios. The conversation highlights the importance of understanding the definitions and properties of measurable functions in real analysis.
  • Understanding of measurable functions and sets in real analysis.
  • Familiarity with sigma-algebras and their properties.
  • Knowledge of the Dominated Convergence Theorem (DCT).
  • Basic concepts of Fatou's Lemma and its applications.
  • Study the properties of measurable functions in the context of Rudin's "Real and Complex Analysis."
  • Learn about sigma-algebras and their role in measure theory.
  • Explore the Dominated Convergence Theorem and its implications for integrals.
  • Investigate Fatou's Lemma and its applications in real analysis problems.
Students and educators in mathematics, particularly those studying real analysis, as well as researchers and professionals seeking to deepen their understanding of measure theory and integration techniques.
island-boy
Hello friends,
I wish to seek your assistance in helping me solve these problems regarding Real Analysis from Rudin's Real and Complex Analysis book. All problems are from the first chapter on Abstract Integration.
While, I don't expect complete solutions, I hope you guys could give me some hints on how I could get started on these problems...cause I have been staring at these problems with little clue on what to do for the last 2 days.:cry:
Exercise #
5)a)Suppose f: X -> [-infinity, +infinity] and g: X -> [-infinity, +infinity]. Prove that the sets {x: f(x) < g(x)} and {x: f(x) = g(x)} are measurable.
5)b) Prove that the set of points at which a sequence of measurable real valued functions converges (to a finite limit) is measurable.
Obviously to prove a set is measurable, I must prove that
1) the whole set is measurable (alternatively, the null set is measurable).
2) If the set A is measurable, then A' is measurable.
3) if A1, A2, A3... are measurable sets, then the countable(or is arbritrary?) union of As are measurable.
I'm not sure how 5)a) relates to 5)b)
Also, for 5)b)
If I let {Fn} be the sequence of measurable functions, how can I show the set of limFn is measurable?
6) Let X be an uncountable set, let M be the collection of all sets E contained in X such that E or E' is at most countable, and define the measure of E ( m(E) ) = 0 in the first case and = 1 in the second. Prove that M is a sigma-algebra in X and that m is a measure on M. Describe the corresponding measurable functions and their integrals.
Similar to 5)a and b, I believe I'm suppose to show that:
and to prove measure, I must show that m is countably additive (i.e measure of union of A sub i's = summation of measure of A sub i's).
Again, how exactly do I show this? Also, does countable set automatically mean it is measurable? I'm am confused here.
ETA:
9) Suppose M is a positive measure of X :f: X -> [0, infinity] is measurable. The integral of f dm over X = c, where 0< c< infinity, and alpha is a constant. Prove that the
limit (as n -> inifinity) of the integral of n ln[1 + (f/n)^alpha] dm over X equals
(i) infinity if alpha is between 0 and 1
(ii) c if alpha equals 1,
(iii) 0 if alpha is greater than 1
I have made some progress in this.
letting fn = n ln[1 + (f/n)^alpha],
if alpha = 1, then fn = n ln[1 + (f/n)], but 1 + (f/n) <= e^(f/n) (using Taylor's formula)
therefore, fn <= n ln(e^ (f/n)) = n(f/n) = f
fn is thereforedominated by f and lim fn = f, therefore, we can use the Dominated Convergence Theorem and the limit (as n -> inifinity) of the integral of n ln[1 + (f/n)^alpha] dm over X = the integral of f dm over X = c.
For the case when alpha is greater than 1, I can use the same technique and show that fn is dominated by alpha*f. And also use the DCT.
What I am not sure of is if alpha is greater than one, does the intergal of the limit (as n -> infinity) of fn dm = 0? If this is so, then my problem is solved Althogh, I wish someone could show me why this is true.
Finally, is alpha is between 0 and 1, the book hints that I should use fatou's lemma, which states that the integral of the lim inf of fn dm <= lim inf of the integral of fn dm.
Since I must prove that thelimit of the intergal of fn dm = inifinty, 'm guessing that I only need to show that the integral of the lim inf fn dm = infinity (i.e. show lim inf fn dm = inifnity). Again, how do I prove this?
Thank you very much for all your help!
You'll probably get more help if you post problems one at a time.
5(a) - There's probably something in the text that indicates that f and g are measurable functions since, if f and g are arbitrary real-valued functions, this is not generally true.
Problem 6 should be relatively straightforward - you're most of the way there:
For, example:
So, is m(X) defined?
