Help Me Solve a Physics Homework Problem - Lagrange Points
The discussion focuses on Lagrange points, specifically in the context of the Earth-Sun system, as discovered by Joseph Louis Lagrange in 1772. Lagrange points are equilibrium positions where a smaller mass can remain stationary relative to two larger masses. The Earth-Sun system has five Lagrange points, with L1 and L2 located between the Earth and the Sun, L3 directly opposite the Sun, and L4 and L5 forming equilateral triangles with the Earth and Sun. The masses involved are the Earth (5.98 x 1024 kg) and the Sun (1.991 x 1030 kg), and the radius of Earth's orbit is 1.496 x 1011 m.
  • Understanding of classical mechanics and gravitational forces
  • Familiarity with the three-body problem in physics
  • Knowledge of quadratic equations for solving mathematical problems
  • Basic comprehension of orbital mechanics and celestial bodies
  • Research the mathematical derivation of Lagrange points using the three-body problem
  • Explore the concept of the Hill Sphere and its applications in celestial mechanics
  • Investigate the significance of L4 and L5 points in potential space missions
  • Learn about the stability of Lagrange points and their implications for satellite placement
Students studying physics, astrophysicists, and anyone interested in orbital dynamics and satellite positioning will benefit from this discussion.
Meistro
Hey a friend asked me for help on his physics homework, and I found this place and was wondering if you guys could help me out.
2: In 1772, the famed Italian-French mathematician Joseph Louis Lagrange was working on the infamous three-body problem when he discovered an interesting quirk in the results. If one mass is much smaller than the other two then there will exist points where this object can be stationary with respect to one of the two masses. These points are known as Lagrange points in his honor. In our treatment we could consider these points to be equilibrium points for a system. If we wanted to find Lagrange point for the Earth-Sun system located between the Earth and the Sun how far from the Earth is this point and what is the significance of the other solution? The mass of the Earth is 5.98 X 10^24 kg, the mass of the Sun is 1.991 x 10^30 kg and the radius of the Earth's orbit is 1.496 x 10^11 m. (solve using quadratic eq.)
Google for Hill Sphere. Wikipedia has a good site. The Hill Sphere will give you the distance to the L1 and L2 points.
L3 is in Earth's orbit, on the opposite side of the Sun, so it is exactly 2 AU away.
L4 and L5 are 60 degrees ahead of and behind the Earth. The Earth, Sun, and L4 form an equilateral triangle, as do the Earth, Sun, and L5. So the Earth L5 distance is 1 AU. The Earth L4 distance is 1 AU. The Sun is also 1 AU from both these points.
Actually, one mass doesn't need to be smaller than the other two, at least for the L4 & L5. And I suspect the other 3 L points as well. The two orbiting masses combined need to be at most ~1/25 the mass of the large object. It's possible for an Earth-mass planet to be in Earth's L4 or L5 point.
  • · Replies 38 ·
