Earth's Rotation: Day & Year Cycles
  • Context: High School
  • Thread starter Thread starter Raza
    Cycles Rotation Year
The discussion centers around the Earth's rotation and revolution, specifically addressing the direction of these movements and the reasons behind them. Participants explore both the daily rotation of the Earth and its annual revolution around the Sun, touching on related concepts in astronomy.
  • Some participants state that the Earth rotates to the east, with one noting it rotates anticlockwise when viewed from above the north pole.
  • There is speculation that the initial rotation of the Earth may have been influenced by the molecular cloud that formed the solar system, potentially affected by external forces such as a passing massive object.
  • One participant clarifies the distinction between rotation (daily) and revolution (annual), asserting that the Earth revolves around the Sun counter-clockwise, as do other planets in the solar system.
  • Another participant mentions that the solar system and its components likely share a common initial bias in rotation stemming from the same gas cloud that formed them.
  • Discussion includes the unique case of Venus, which rotates counter-clockwise but has a retrograde effect due to its slow rotation relative to its revolution around the Sun.
  • There is mention of Uranus and Pluto, which are suggested to rotate clockwise due to their significant axial tilts.
  • A participant indicates a need for further clarification on the Venus rotation topic, suggesting a split into a separate discussion thread.
Participants generally agree on the direction of Earth's rotation and revolution, but there are differing views on the reasons behind these movements and the implications for other celestial bodies, particularly Venus. The discussion remains unresolved regarding the specifics of these influences.
Some assumptions about the initial conditions of the solar system and the effects of external forces remain unexamined. The discussion also highlights the complexity of planetary rotations and their interrelations without reaching definitive conclusions.
Raza
Which way does the Earth rotate and why? I am talking about both of the rotations. Rotation for a day and a rotation for an year.
Astronomy news on Phys.org
It rotates to the east.
I don't know why.
Raza said:
...and why?
Probably because molecular cloud that was to form our solar system was slightly torqued by a passing massive object or spiral arm, but it's hard to say.
I don't know why.
Or, it rotates anticlockwise if viewed above the north pole.
BTW, when it's around the Sun, it's called 'revolution', not 'rotation'.
The Earth rotates counter-clockwise as viewed from above the pole (and above the Solar System). As do all other planets in the SS (Venus too, but it is a special case**).
The Earth revolves around the Sun counter-clockwise, as do all other planets in the SS.
The SS revolves around the galactic core counter-clockwise, as does almost everything else in the galaxy.
These rotations are interlinked, and it is pretty likely that they all stemmed from the same initial bias in rotation as - first the galaxy, then the solar system, then the gas cloud that formed the Earth - all had.
**Venus rotates counter-clockwise, just like all the other planets, however, since its rotation (about its own axis) is actually slower than its revolution (about the Sun), the net effect is that the Sun rises in Venus' West and sets in it East and thus Venus is said to have a retrograde rotation. (Interestingly, this means Venus' "day" is longer than its "year".)
I think both Uranus and Pluto rotate clockwise (axial tilts > 90 degrees). As for Venus, its solar day (i.e. the day as seen from someone on the surface) is ~117 days, suggesting that that it would also be rotating clockwise from a stationary vantage point north of the solar system.
  • · Replies 41 ·
  • · Replies 27 ·
  • · Replies 40 ·
  • · Replies 31 ·
