Electron spin and chemical bonding
The discussion centers on the relationship between electron spin and chemical bonding, particularly in the context of sodium (Na+) and chlorine (Cl-). It clarifies that the bond between these two ions is ionic, driven by electrostatic attraction rather than the need for opposite spins, which is relevant in covalent bonds governed by the Pauli exclusion principle. The conversation shifts to the behavior of hydrogen atoms, questioning whether they will react only half the time when brought together, due to their electron spins. One participant suggests that hydrogen atoms will adjust their spins to achieve a lower energy state before bonding, likening this to the alignment of magnets. The potential impact of spin states on bonding and the role of energy in this process are also discussed, with a reference to the Woodward-Hoffmann rules for further exploration of the topic.
chroot
Staff Emeritus
I am relaying this question from rtharbaugh1, who originally posted it to a thread in the Quantum Physics forum:
https://www.physicsforums.com/showthread.php?s=&postid=98040
Originally posted by rtharbaugh1
I first read that paired electrons in an atomic shell must have opposite spin. Does this mean that a chemical bond will not form between, say, Na+ and Cl-, unless the two atoms have electrons of opposite spin? Wouldn't this mean that two such atoms brought sufficiently close together would only form a bond half the time? Can we manipulate single atoms of sodium and chlorine to test this idea? Has it been done?
Can any of you chemistry nerds answer this? :smile:
- Warren
Chemistry news on Phys.org
There is no chemical bond between chlorine and sodium. That is to say it is only electrostatic attraction, an ionic bond as opposed to a covalent bond. The pauli exclusion principle applies to electrons that occupy the same orbital, such as in a covalent bond.
If you bring an atom of sodium near a atom of chlorine, the sodium will give its electron to chlorine, resulting in the sodium cation and the chloride ion, which bind ionically.
But that skirts the question. If you bring a hydrogen atom, a radical, together with another hydrogen atom, will they only react half the time? Is this a better question? What do you think will happen?
The typical train of thought (as I understood it) is that the total spin of the reactants must be equal to the products in order for a reaction to occur. The well worn example is that of recombination after radical pair generation by photolysis/radiolysis - there needs to be a conversion from the triplet state into the singlet state for the diamagnetic starting product to be formed.
spin states and bonding
Thanks for not leaving me with a skirted question. I appreciate the correction, and agree that the H-H covalent bond is a better example of the process I am curious about.
As for what I think will happen, I suspect that the hydrogen atoms will rotate in 3space until the electron spins match up to give the lowest energy state. Then they will bond together in that spatial relationship. I imagine this process as being similar to a pair of macroscopic magnets sufficiently close together re-aligning to match their magnetic fields. In fact, I would speculate that magnetism in general may have much to do with spin states.
There may be some small factor of energy taken to effect the rotation, and that may cause some small delay in the bonding of some atoms with certain others, but given the very small mass of an atom, I doubt if the rotation delay could be measured.
Thanks for the answer. I will watch for your reply about the magnetizm thing.
Richard
Search "Woodward-Hoffman rules;" there are a couple decent sites on the first page of the list, 224 hits = 127 actual sites.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
