| Thread Closed |
complex numbers (practice exam questions for exam in 2 days) |
Share Thread | Thread Tools |
| Jun22-06, 07:48 AM | #1 |
Hey if anyone could help me to understand wat to do in this question I would be appreciative!
Find in the complex plane the fourth roots of -64, Use the result to factor Z^4+ 64 into i) a product of four linear factors I kinda thought that you could write something along the lines of this froman example id seen! (z+64)(z+b)(z+c)(z+d), but I wouldnt know how to find the rest! If I can be helped to work out this answer then I could work out the next most likely! ii) a product of two quadratic factors with real coefficients! |
| Jun22-06, 08:10 AM | #2 |
Recognitions:
| Jun22-06, 12:44 PM | #3 |
Simply consider that the equation Z^4 + 64 = 0 can be rewritten as (z^2)^2 - (i8)^2 = 0 and that the 4 solutions to this equation are the 4 fourth roots of -64. In this way you do both parts of the q together. Another approach would be to find the square roots of -64 and the square roots of those directly. Molu |
| Jun22-06, 05:17 PM | #4 |
z+ 64 is certainly not a factor of z4+ 64! One way you could do this is write z4+ 64 as (z2)2-(-64) so that z4+ 64= (z2-8i)(z2+8i) and then factor those.
However, since the problem says to first find the fourth roots of -64, you are obviously intended to use De Moivre's formula: [tex](re^{i\theta})^\frac{1}{n}= r^\frac{1}{n}e^{\frac{i\theta}{n}[/tex] Of course, [itex]-64= 64e^{i\pi}[/itex]. (I just noticed that that is essentially what nrqed told you!) |
| Jun22-06, 09:02 PM | #5 |
I aint quite following, its kinda confusing wat I was even gettin at!
I am really confused, I know De'Moivre's theorem. Find the fourth roots! Okay so this is wat I thought or did now! 1st root is 64e^i*Pi 2nd root is 8e^i*Pi/2 3rd root is 4e^i*Pi/3 4th root is (64^1/4)e^i*Pi/4 Now then is that right and then I would write something along the lines of (z+64e^i*Pi)(z+8e^i*Pi/2)(z+4e^i*Pi/3)(z+(64^1/4)e^i*Pi/4) Then thats all right for the first part! The second part would just be (z^2+8i)(z^2-8i) as shown in one of the replies or I could just times the first two brackets together and the last 2 to get the quadratic! So if this is right then I should be fine! Thanks for your help! But yeah can you tell me whether I am right! |
| Jun22-06, 09:34 PM | #6 |
wait a second that is wrong anyhow!I would do it like this
1st root is (64^1/4)e^-i*pi/4= 64^1/4(1/sqrt2+i/sqrt2) and so on! then couldnt I say that (z-(64^1/4(1/sqrt2+i/sqrt2)) |
| Jun22-06, 09:48 PM | #7 |
this will be the answer to the quadratic part I think
(z^2-(128^3/4)+4)(z^2+(128^3/4)+4) |
| Thread Closed |
| Thread Tools | |
Similar Threads for: complex numbers (practice exam questions for exam in 2 days)
| Thread | Forum | Replies | ||
| URGENT: Complex Numbers Problems: HELP NEEDED FOR MY FINAL EXAM!!? | Precalculus Mathematics Homework | 8 | ||
| Maths exam in 3 days | Precalculus Mathematics Homework | 6 | ||
| practice exam question HELP PLEASE!! | Engineering, Comp Sci, & Technology Homework | 12 | ||
| plz help with static equillibrium TEE exam in a few days | Introductory Physics Homework | 14 | ||
