Can a Photon Orbit a Black Hole?
The discussion centers on the nature of photon orbits around black holes, particularly focusing on the Schwarzschild radius and the stability of these orbits. Participants explore theoretical implications and various types of orbits, including circular and non-circular paths, in the context of general relativity.
  • Some participants reference MTW, noting that a photon can orbit a black hole at a radius of r=3M, while questioning the nature of orbits at r=2M.
  • It is proposed that circular orbits occur at r=3M, with r=2M representing a lightlike surface where photons can "hang" but not in a stable circular orbit.
  • Participants discuss the stability of orbits, indicating that both the circular orbit at r=3M and the outgoing photon at r=2M are unstable.
  • There is a query about the possibility of circular orbits at r=2M, with clarification that such orbits do not exist as they do not meet the criteria for circular motion.
  • One participant raises the question of whether the wavelength or energy of a photon affects its orbital stability, suggesting a connection to concepts like Bohr orbits.
  • Another participant questions if a photon could possess enough energy to become a black hole, leading to a discussion on the intersection of quantum theory and general relativity.
Participants generally agree on the instability of photon orbits at both r=2M and r=3M, but there is no consensus on the existence of circular orbits at r=2M or the implications of photon energy on orbital stability.
Participants note limitations in understanding the implications of photon energy and its relationship to black hole formation, as well as the distinction between classical and quantum theories in this context.
RobtO
In MTW it is derived that a photon can orbit a black hole at a radius r=3M. However, the surface at the Schwartzschild radius r=2M is lightlike, isn't it? So can a photon orbit at both radii? What am I missing?
Circular orbits occur at r=3M. There are plenty of other possible general orbits. The photon "hanging" at r=2M on an outgoing geodesic is just one interesting and somewhat extreme example of a non-circular orbit.
But these orbits are not stable right? At least I think that is what you claimed a month or two ago.
The circular orbit of a photon at R=3m is not stable, and the photon hanging at r=2m is also not stable. There are a lot of different possible orbits for a photon. If the photon doesn't pass too close to the black hole, most photon orbits will tend to be nearly hyperbolic. Close to R=3m, one will see orbits that either spiral into the black hole, or spiral out. MTW has some pictures of some of the spiral orbits, I believe.
But what about circular orbits at r=2M? Are they possible, too?
does the wavelength of the photon have anything to do with its orbital stibility? like if you have something like bohr orbits only with light waves.
[tex]n \lambda = 2 \pi r[/tex]
Are there any stable orbits? is there a continuous or discrete spectrum of them if there are any?
The "orbit" of an outgoing photon at R=2m in Schwarzschild coordinates (r, theta, phi, t) is a single point:
r=2M
theta=phi=constant
This is not a circular orbit, because the angles are constant. There are other orbits that start at R=2m and propagate in different directions - all of these orbits wind up at the central singularity. Only the outgoing photon escapes this fate, if the photon starts off at even a small angle away from outgoing, it will get sucked into the black hole.
A circular orbit, by comparison is
r=3M
theta=constant
phi = w t
where w is the angular frequency
Does the wavelength/energy of the photon have anything to do with its orbital stability? What if a photon had the same energy as the black hole itself... hypothetically? could a photon have so much energy that it itself is a black hole?
Stable and unstable photon orbits
Hi, Jonny,
Looks like pervect already answered your original question, but you then asked:
A fundamental principle in gtr is that the "path" taken by a monochromatic light beam does NOT depend upon its wavelength. (If this weren't true, gtr would be in serious trouble!) See for example section 15.4 of D'Inverno, Introducting Einstein's Relativity.
Well, the notion of a "photon" belongs to the domain quantum theory, but gtr is a classical field theory, so this question doesn't quite make sense in the context of gtr. So let's modify it: "can a laser pulse have so much mass-energy that it becomes a black hole?" You can probably now figure out what is the answer from gtr :-/
Chris Hillman
  • · Replies 57 ·
  • · Replies 51 ·
  • · Replies 22 ·
  • · Replies 20 ·
