Object Motion in 2D: Dimensions, Velocity, and Acceleration
  • Thread starter Thread starter ch00se
    2d
The discussion revolves around an object moving in 2D space, with its coordinates defined by the equations x=2t and y=4t^2. Participants are exploring the dimensions of the coefficients 2 and 4, as well as the object's velocity, speed, acceleration, and the angle between velocity and acceleration at t=0.
  • Participants are attempting to determine the dimensions of the coefficients in the equations and question the validity of their substitutions. Some are exploring how to combine the equations into a standard form, while others are discussing the implications of the dimensions of time and distance on the coefficients.
The discussion includes various interpretations of the problem, with some participants providing guidance on the dimensional analysis required for the coefficients. There is acknowledgment of confusion regarding the relationships between the variables and the physical meanings of the coefficients, but no consensus has been reached on the correct approach.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an emphasis on understanding the physical dimensions involved in the equations.
ch00se
the coordinates of an object moving in the 2D space are given by x=2t and y=4t^2. what are the dimensions of the numerical coefficients 2 & 4, respectively? What are the objects velocity, speed and acceleration and the magnitude of the acceleration at t=0. what is the angle between the velocity and the acceleration at t=0
have been through my textbook god knows how many times and cannot decide which to use
i have honestly tried for hours and haven't managed to get anywhere
however, for the dimensions i substituted 2 and 4 in respectively, but i doubt this is correct
I think you meant y = 4t^2 in the second equation.
For the fist equation, what are the dimensions of x and t. Having found that, what should be the dimension of 2, for the equation to be valid?
edited, thanks
i got :
x=2 = 4
x=4 = 8
y=2 = 64
y=4 = 256
however, like i said, i doubt this is correct...or is it?
with those equations, should you put them together to get a y=mx+c styled equation?
i get y = x^2 and then go from there maybe?
You can write the following: [tex]\vec{r}(t) = x(t)\vec{i}+y(t)\vec{j}[/tex]. Plug the given functions in, and use the following relations: [tex]\frac{d\vec{r}(t)}{dt}=\vec{v}(t)[/tex], [tex]\frac{d\vec{v}(t)}{dt}=\vec{a}(t)[/tex].
ch00se said:
edited, thanks
i got :
x=2 = 4
x=4 = 8
y=2 = 64
y=4 = 256
Nope, it's not.
The DIMENSION of x is Length(L) and the dimension of t is Time(T). Now, what is the coefficient's dimension to make a physically meaningful equation?
Whichever textbook you may be using, the first or second chapter probably covers the topic of units and dimensions. Give it a read.
its adding vectors?
i think for x(t)
you put 2 into x=2t, so you get 4?
then for y( t)
you put 4 into y=4t^2, so you get 74 (4x16)
so r( t) = 4i + 74j ?
ch00se said:
its adding vectors?
i think for x(t)
then for y( t)
Is WHAT "adding vectors"? Which question are you answering here?
t is the TIME, measured, say, in seconds. Why should the time be 2 seconds for x and 4 seconds for y? Those equations give the (x,y) coordinates of the point at time t seconds.
The first question, which I think you are trying to answer, asks "the coordinates of an object moving in the 2D space are given by x=2t and y=4t^2. what are the dimensions of the numerical coefficients 2 & 4, respectively?
What kind of UNITS should they have, not numerical values. In x= 2t, t will have TIME units, x will have DISTANCE units. Think of it as multiplying fractions: (Distance/Time)(Time)= Distance. That "2" factor must have units of Distance/Time (so it's really a "speed" factor), for example meters/sec if t is measured in seconds and x in meters, or miles/hour if x is measured in miles and t in hours.
Now look at y= 4t^2. Again, t is a TIME, y is a DISTANCE. t^2 will be Distance^2. To get Distance= ( )(Time^2), that ( ) must look like Distance/Time^2 so that the "Time^2" terms cancel and leave "Distance". The "4" must have units of Distance/Time^2 (so it's really an 'acceleration' factor), for example meters per second per second or miles per hour per hour.
thanks, that was a very useful post
i made sense of that!
for the velocity, how would you get a direction on the force?
also can you reach an answer or should the answer be displayed in equation format?
thanks!
If you go back to post number 5 by radou he explains exactly how to complete the question. The speed is the magnitude of the velocity and is given by using pythagoras' theorem.
[tex]|\mathbf{v}|= \sqrt{x(t)^2+y(t)^2}[/tex]
Of course its made rather simple by the fact that its all at time t=0.
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 35 ·
  • · Replies 20 ·
