| Thread Closed |
CIRCUIT ANALYSIS: 7 resistors, 2 Indep. Volt Source, V.C.C.S, V.C.V.S. - find I |
Share Thread | Thread Tools |
| Jan16-07, 05:09 AM | #1 |
1. The problem statement, all variables and given/known data
For the circuit below find [itex]I_1[/itex] and [itex]I_2[/itex]: ![]() 2. Relevant equations KVL KCL Ohm's Law 3. The attempt at a solution I tried the problem many times, but I always get crazy answers. It seems that every time I need one new equation to have a system of solveable equations, I have to add a new variable and hence I need another equation. It's a vicious cycle that when I get up to 13 variables for all of the V's at the resistors and different I's at nodes 1-4, I get a crazy answer like -1.35 mA for [itex]I_1[/itex]. Does that seem right? Any suggestion on what to do about the one-more variable, one-more equation problem? I tried a super-node between nodes 2 and 3. Didn't help though. |
| Jan16-07, 05:27 AM | #2 |
Recognitions:
Start by finding the voltages. You can write down the voltage at nodes 4, 3, 2 (two different ways) and 1 (in that order) without knowing any currents.
The two ways of getting the voltage at node 2 gives you a relation between Va and Vb, so eliminate one of them. Then start finding the currents in terms of the voltages. You don't need to add any more nodes. |
| Jan17-07, 04:47 AM | #3 |
Ok, so I get these for the node voltages(4,3,2,2,1):
[tex]V_4\,-\,0[/tex] [tex]V_3\,+\,5V[/tex] [tex]V_2\,-\,0[/tex] [tex]V_2\,-\,2\,-\,V_4\,=\,0[/tex] [tex]V_2\,=\,V_4\,+\,2[/tex] [tex]V_1\,-\,0[/tex] Are these right? If not, how am I supposed to make these voltage equations? Also, I am stuck again, I don't know where to go from here (even if the voltage EQs are correct)! Should I use KVL or KCL? I tried to add 2 current variables at Node 2. I used KCL there and I made some EQs for the currents there (that I had an R for) using [itex]i\,=\,\frac{V}{R}[/itex]. I am seriously stuck now though!!! Can someone walk me through the most logical way to proceed from here, I am really confused. Thanks |
| Jan17-07, 06:35 AM | #4 |
Recognitions:
I don't understand exactly what those expresssions are.
The way I would do this is by looking at the circuit and thinking about what you know, not trying to apply the K. laws in a mechanical way. It's "obvious" from the circuit diagram that V4 = VA V3 = V4 = VA (the current source has no internal resistance so no voltage across it) V2 = V4 - 2 = VA - 2 (from the 2V voltage source) and also V2 = VB so VB = VA - 2 V1 = V2 - 2VA = -2 - VA Now try and find a node which doesn't have the unknown currents I1 and I2 flowing into it: there is one, node 3. Find all the currents flowing into node 3 by Ohms law. By KCL they add up to zero. That will give you an equation for VA. Now you know all the voltages, you can use Ohms law and KCL to find the other currents. |
| Jan18-07, 12:04 AM | #5 |
Okay Vinny, we'll use nodal analysis or KCL for the problem if that is fine with you. And for the moment, let's avoid supernodes but stick with the conventional nodes.
To get you started, do this for me: Note down the 4 equations corresponding to the 4 nodes using KCL, i.e., the sum of currents entering/leaving the node equals zero. And do that with only the variables V1, V2, V3, V4, I1, I2 and no other variables. |
| Jan18-07, 12:08 AM | #6 |
OK, I have added 3 currents to the diagram (in green).
![]() [tex]V_4\,=\,V_a\,=\,V_3[/tex] [tex]V_2\,=\,V_4\,-\,2\,=\,V_b[/tex] [tex]V_b\,=\,V_a\,-\,2[/tex] [tex]V_1\,=\,V_\,2\,-\,2\,V_a[/tex] Just what you said above. Now, I use [itex]i\,=\,\frac{V}{R}[/itex] to get the new currents in green. KCL: [tex]I_3\,+\,I_4\,+\,I_5\,+\,\frac{V_b}{4K\Omega}\,=\,0[/tex] [tex]I_3\,=\,\frac{(5\,V)}{4000\Omega}\,=\,0.00125\,A\,=\,1.25\,mA[/tex] [tex]I_4\,=\,\frac{V_2\,-\,V_3}{2000\Omega}[/tex] [tex]I_5\,=\,\frac{V_1\,-\,V_3}{4000\Omega}[/tex] Now if I combine those four equations above: [tex]\frac{V_2\,-\,V_3}{2000\Omega}\,+\,\frac{V_1\,-\,V_3}{4000\Omega}\,+\,\frac{V_4\,-\,2}{4000\Omega}\,=\,-1.25\,A[/tex] How do you proceed? |
| Jan18-07, 12:23 AM | #7 |
Ok, lets try NODE 1 first:
[tex]\left(\frac{-V_1}{1000\Omega}\right)\,+\,\left[\left(\frac{V_3\,-\,V_1}{4000\Omega}\right)\,+\,\left(\frac{V_4\,-\,V_1}{3000\Omega}\right)\right]\,=\,I_1[/tex] Is that correct? |
| Jan18-07, 12:30 AM | #8 |
And yes, combine these terms into an equation. Note that Vb = V2. Also, at the moment, let's forget about V2 = V4-2. Now write down again the nodal equation for node 3. |
| Jan18-07, 12:32 AM | #9 |
| Jan18-07, 12:41 AM | #10 |
Cool! NODE 2 now:
[tex]I_1\,+\,\left(\frac{-V_2}{2000\Omega}\right)\,+\,\left(\frac{V_2\,-\,V_3}{2000\Omega}\right)\,=\,I_2[/tex] Is that right? Is [itex]V_b[/itex] still equal to [itex]V_2[/itex]? |
| Jan18-07, 12:52 AM | #11 |
| Jan18-07, 01:27 AM | #12 |
The mistake fixed?
[tex]I_1\,+\,\left(\frac{-V_2}{2000\Omega}\right)\,+\,\left(\frac{V_3\,-\,V_2}{2000\Omega}\right)\,=\,I_2[/tex] |
| Jan18-07, 01:29 AM | #13 |
That's right, now move on to the other 2 equations.
| Jan18-07, 01:36 AM | #14 |
OK, for NODE 3:
[tex]\left(\frac{V_1\,-\,V_3}{4000\Omega}\right)\,+\,\left(\frac{V_2\,-\,V_3}{2000\Omega}\right)\,+\,\left(\frac{5\,-\,V_3}{4000\Omega}\right)\,=\,\left(\frac{-V_2}{4000\Omega}\right)[/tex] And for NODE 4: [tex]\left(\frac{-V_4}{4000\Omega}\right)\,+\,\left(\frac{V_1\,-\,V_4}{3000\Omega}\,+\,I_2\right)\,=\,\left(\frac{V_2}{4000\Omega}\righ t)[/tex] Are those right? Or did I mess up the path with the 5V independent voltage source and 4Kohm resistor? |
| Jan18-07, 01:57 AM | #15 |
Very good. Now, I would like to have these equations simplified a bit. As an example, for node 4, you wrote:
[tex]\left(\frac{-V_4}{4000\Omega}\right)\,+\,\left(\frac{V_1\,-\,V_4}{3000\Omega}\right)\,+\,I_2\,=\,\left(\frac{V_2}{4000\Omega}\righ t)[/tex] I want it simplified to become: [tex]\frac{1}{3}V_1 - \frac{1}{4}V_2 - \frac{7}{12}V_4 + I_2 = 0[/tex] Specifically, I have ignored the '000 in the R's (the V's are still as before but the I's are now in milliamperes) and arranged the equations such that on the left side are the unknowns, ordered V1, V2, V3, V4, I1, I2 and on the right side, the constants. There's a reason for doing all these of course. :) Do the same for the other 3 equations and we will proceed from there. |
| Jan18-07, 02:21 AM | #16 |
NODE3: [tex]V_1\,+\,3\,V_2\,-\,4\,V_3\,=\,-5[/tex]
NODE2: [tex]2000\,I_1\,-\,2000\,I_2\,-\,2\,V_2\,+\,V_3\,=\,0[/tex] NODE1: [tex]-4000\,I_1\,-\,\frac{19}{3}\,V_1\,+\,V_3\,+\,\frac{4}{3}\,V_4\,=\,0[/tex] Right? |
| Jan18-07, 02:48 AM | #17 |
Okay, that's close enough. Let me edit a bit...
Node 1: [tex]-\frac{19}{12}V_1 + \frac{1}{4}V_3 + \frac{1}{3}V_4 - I_1 = 0[/tex] Node 2: [tex]-V_2 + \frac{1}{2}V_3 + I_1 - I_2 = 0[/tex] Node 3: [tex]V_1 + 3V_2 - 4V_3 = -5[/tex] Node 4: [tex]\frac{1}{3}V_1 - \frac{1}{4}V_2 - \frac{7}{12}V_4 + I_2 = 0[/tex] I prefer to have the equations in the manner above, with the I's in milliamperes. Now, note that there's a voltage source across nodes 1 and 2, similarly a voltage source between nodes 2 and 4. Due to that, we ought to form a supernode, that is, to combine nodes 1, 2 and 4 into a single supernode. The result is the elimination of the unknown variables I1 and I2. To do that, try combining equations 1, 2 and 4 above into a single equation such that the unknowns I1 and I2 disappear. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: CIRCUIT ANALYSIS: 7 resistors, 2 Indep. Volt Source, V.C.C.S, V.C.V.S. - find I
| Thread | Forum | Replies | ||
| CIRCUIT ANALYSIS: 2 resistors, Indep. Current Source, V.C.C.S - find v0 | Engineering, Comp Sci, & Technology Homework | 37 | ||
| CIRCUITS: Three resistors, two Indep. Voltage sources, one Indep. Current source | Introductory Physics Homework | 5 | ||
| CIRCUITS: Current Controlled Voltage source, Indep. Voltage source, Four resistors... | Introductory Physics Homework | 1 | ||
| CIRCUIT ANALYSIS: Use superposition - 2 Current source, 1 Voltage source, 4 resistors | Advanced Physics Homework | 6 | ||
| EECS: Find i_0 in a circuit with 4 resistors and 1 indep. current source | Engineering, Comp Sci, & Technology Homework | 5 | ||
