What Factors Affect the Efficiency of a Siphon?
  • Thread starter Thread starter lapsaJ
    Efficiency
The discussion revolves around a practical investigation into the efficiency of a siphon, focusing on factors such as the rate of flow and the height difference between water levels. Participants explore various aspects of fluid dynamics relevant to the project.
  • Participants discuss the application of Bernoulli's equation to derive flow rates and consider varying the diameter of the siphon tube. Questions arise regarding the relationship between tube diameter and flow rate, particularly in the context of long thin tubes.
Some participants provide guidance on the complexities of fluid dynamics, emphasizing the need for a deeper understanding of concepts such as viscosity, laminar and turbulent flow, and Reynolds number. There is acknowledgment of the challenges in applying Bernoulli's equation to the results, indicating a productive exploration of the topic.
Participants express uncertainty about the project's viability and the original poster's teacher's unfamiliarity with similar investigations. There is a suggestion to read up on relevant theories and principles before proceeding with the investigation.
lapsaJ
(Hope this is in the right forum)
For my A Level coursework I have to do a practical investigation. I'm thinking of doing one looking at the efficiency of a siphon.
One relationship I am going to be looking at is the rate of flow vs height (difference between the two water levels).
Now I'm having a bit of difficulty thinking what else I can look at to give it some decent scope. My teacher hasn't seen this done before so we're a bit uncertain whether it's worth taking forward.
Any suggestions would be appreciated! Thanks.
You've chosen a rather difficult subject. The flow of liquids in pipes ( fluid dynamics) is a whole branch of physics with more equations than I could shake a stick at.
Thanks for your reply.
I was thinking of applying Bernouilli's equation to the separate parts to derive the flow rate, and possibly the maximum height.
Would it be worth varying the diameter of the siphon tube?
Yes it would. (You might expect the flow would be proportional to the cross section area of the tube, but it won't be, for long thin tubes).
Read up a bit about flow in pipes and the effects of viscosity, laminar and turbulent flow, and Reynolds number before you get into this. Otherwise, you will have a very hard time understanding your measurements.
It won't make a very good project when (not if!) you show that Bernoulli's equation doesn't fit any of your results, but you don't have any understanding of WHY that is the case.
Why isn't the diameter of the siphon tube proportional to the rate of flow for long thin tubes? I am just reading up on theories behind the siphon from journals etc..Just wondering why that's the case (altering the diameter).
Thanks
  • · Replies 17 ·
28K
