General Relativity: Comparing Newtonian and Einstein Circular Orbits
  • Context: Graduate
  • Thread starter Thread starter charybdis
    Gr Newtonian Orbits
The discussion centers around comparing circular orbits predicted by Newtonian mechanics and general relativity, specifically addressing a problem from the book "Exploring Black Holes: Introduction to General Relativity" by Edwin F. Taylor and John Archibald Wheeler. Participants explore the derivation of expressions for stable circular orbits and the conditions under which the two theories yield indistinguishable results.
  • Homework-related
  • One participant expresses confusion regarding the derivation of the radius of stable circular orbits and seeks verification of their answers.
  • Another participant provides an effective potential for general relativity and Newtonian mechanics, suggesting a comparison of the two to find stable circular orbits.
  • A different participant derives a radius expression for circular orbits using centripetal acceleration and gravity, noting the use of geometrized units.
  • Clarifications are made regarding the effective potential equations, with some participants pointing out potential discrepancies in notation and definitions.
  • Discussion includes the need to consider the specific angular momentum and the implications of using different signs in the general relativistic expression for radius.
  • Participants discuss the relevance of Taylor series and asymptotic series in the context of stable circular orbits far from the gravitational source.
Participants have not reached a consensus on the derivation of the expression for q in terms of M and rNewt, and there are differing interpretations of the effective potential equations. Confusion remains regarding specific steps in the problem-solving process.
Some participants note potential typos and differences in notation that may contribute to confusion. There is also mention of the need for careful consideration of the definitions of radial coordinates in both Newtonian and relativistic contexts.
charybdis
i am a physics enthusiast studying general relativity on my own with the book: "Exploring Black Holes: Introduction to General Relativity" by Edwin F. Taylor and John Archibald Wheeler. I am having the hardest time with the fourth chapter of the book and especially the 4th question in that chapter (i seem to have a thing with 4's). I have no knowledge of tensors, but that is not required for the book. The answer that i get for the first part of the problem is confusing and i want to verify that what i have as an answer is either right or wrong and then proceed from there.
the problem states:
Under what circumstances are circular orbits predicted by Newton indistinguishable from circular orbits predicted by Einstein?
A. Find the Newtonian expression similar to:r=((L/m)^2/2)[1+/-(1-(12M^2)/((L/m)^2))^(1/2)] for the radius of a stable circular orbit, starting with V(r)/m=-M/r+(L/m)^2/(2r^2).
B. Recast for the general relativistic prediction of r for stable orbits in the form:r=rnewt(1+q)
Where r¬Newt is the radius of the orbit predicted by Newton and q is a small quantity. This expression neglects differences between the Newtonian and relativistic values of L/m (angular momentum) when expressed in the same units. Use the approximation:
(1+d)^n ≈1+nd provided |d|<<1 and |nd|<<1.
To derive a simple algebraic expression for q in terms of M and rNewt.
as a little aside how do you type equations into this the equation editor i have apparently does not work for html.
thank you.
As luck would have it...
One of the few currently popular gtr books which I typically don't have easily available to me :rolleyes:
Try left clicking with your mouse on any formula you see at PF to see the latex pseudocode used to format it.
You should have an effective potential which looks something like
[tex] V_{\rm GTR}(r) = \left( 1- \frac{2m}{r} \right) \; \left( 1 + \frac{L^2}{r^2} \right)<br /> = 1 \, - \, \frac{2m}{r} \, + \, \frac{L^2}{r^2} \, - \, \frac{2 m \, L^2}{r^3}[/tex]
where the last term is the gtr correction to the corresponding Newtonian effective potential
[tex] V_{\rm Newton} (r) = 1 - \frac{2m}{r} + \frac{L^2}{r^2} [/tex]
where [itex]2m/r[/itex] is the gravitational term and [itex]L^2/r^2[/itex] is the centrifugal term. In both cases, m is the mass of the central object, L is the (specific) angular momentum of the test particle, and r is a radial coordinate. (It looks like Taylor & Wheeler might have tossed in the mass of the test particle, but this should drop out of the problem.)
For both potentials, sketch the graph for typical values of m, L. The place (value of Schwarzschild radial coordinate r) where the graph has a local minimum is the location of the stable circular orbit for a given L. So differentiate wrt r, set the result equal to zero, and solve for r, obtaining
[tex] r_{\rm GTR} = \frac{L}{2m} \, \left( L + \sqrt{L^2-4 m^2} \right),<br /> \; \;<br /> r_{\rm Newt} = \frac{L^2}{m}[/tex]
Now you want to compare the two radii [itex]r_{\rm GTR}, \; r_{\rm Newton}[/itex] for a given m, L. Are you familiar with Taylor series? Or better yet, asymptotic series? (Hint: we want to consider stable circular orbits far from the horizon, so take the case L much larger than m.)
This is a very good problem, because it should cause you to think hard about the operational meaning of a "radial coordinate". In the Newtonian case, r is the usual euclidean radial coordinate, but in the Schwarzschild vacuum case, r is Schwarzschild radial coordinate (do you recall its geometric significance?), so you should be worried that we are trying to compare apples and oranges. Are we?
(So how come everyone is posting about Schwarzschild geodesics all of a sudden? Did something happen in the popular press that I don't know about?)
To find the radius of the circular orbit, set to zero the derivative with respect to r of the effective potential. I got
[tex]r = \frac{(L/m)^2}{M}[/tex]
The same result can be obtained by more elementary methods by solving
centripetal acceleration = acceleration by gravity
and expressing the speed in terms of angular momentum L = mvr. Don't forget that the book uses geometrized units in which G =1.
I'm a little confused by what you are confused about and what answers you say you are getting.
So far all I've seen is a problem statement, but not much indication of what work you've done with it or why you are confused.
I've also seen a lot of helpful posts by others in this thread, but I've also seen some minor differences in notation and (I think) some typos, which might not be helping your state of confusion any.
The bottom line is that I'm not sure how much you've been helped, and I'm not sure why you're confused or what you're confused about.
First, thank you for such a quick response. A couple of things;
1. Chris Hillman: according to my book the equation you gave:
Is the book for the square of the effective potential. The equation for the effective potential is:
[tex] V_{\rm GTR}(r) = - \frac{2M}{r} + \frac{L^2}{2r^2}[/tex]
2. Pervect: my confusion with part A, is resolved. But, my confusion with part B remains. My confusion with part B is how do I derive an expression for q, in terms of M and r¬newt. The book says to start with the equation:
[tex] r= \frac {L^2}{2M} (1 \pm \sqrt{1- \frac{12M^2}{L^2}0)[/tex]
And put in the equation:
[tex] r=r_{\rm newt}(1+q)[/tex]
I guess I put the rnewt equation I derived earlier into rnewt, but then, how do I get q?
I don’t know where to start is all I think the problem is.
All I ask right now is to be pointed in the right direction.
OK, so you know that
[tex] r_{newt} = \frac{\tilde{L}^2}{M}[/tex]
where [tex]\tilde{L} = L/m[/tex], i.e. the tilde means we want the specific angular momentum, the angular momentum per unit mass of the orbiting body, which is just velocity * orbital distance.
And you are happy with that and how it was derived from Newton's law?
The first thing to note is that you need to use the plus sign in the GR expression for r. The minus sign will put the orbit inside the body for any non-black hole, and will be an unstable orbit for any black hole.
See for instance http://www.fourmilab.ch/gravitation/orbits/
or your textbook.
The next thing you need to know is that [tex]\frac{12 M^2}{\tilde{L}^2}[/tex] is "small". Consider the Earth's orbit around the sun, for instance
The mass of the sun in geometric units is 1.5 km. The specific angular momentum of the Earth is the orbital velocity of the Earth times the semi-major axis.
http://hyperphysics.phy-astr.gsu.edu/hbase/solar/soldata2.html
puts the orbital velocity of the Earth at about 30 km/sec, that's 10^-4 c. And the orbital radius is about 1.5*10^8 km. So[tex]\tilde{L}[/tex] = v*r = 1.5*10^4 km in geometric units. Thus, because of the large orbital radius L >> M.
This means you know M^2/L^2 is small, and you can do a taylor series expansion.
[tex]\sqrt{1 - \epsilon} \approx 1 - \frac{\epsilon}{2}[/tex]
with [itex]\epsilon = \frac{12 M^2}{L^2}[/itex]
Oops!
Oops, I did mean to write [itex]V^2[/itex]. Thanks for pointing this out.
Let me try again: (25.16) in Misner, Thorne, & Wheeler, Gravitation (the first "modern" GTR textbook, the book from which your book--- same Wheeler, BTW--- and all more recent modern textbooks derive) states
[tex] \dot{r}^2 = E^2 - V(r)^2,[/tex]
[tex] V(r)^2 = \left( 1- \frac{2m}{r} \right) \, <br /> \left( -\varepsilon + \frac{L^2}{r^2} \right) [/tex]
where [itex]\varepsilon=-1, \, 0, \, 1[/itex] for timelike, null, spacelike orbits respectively. This expression--- which is standard, trust me--- is also given as (11.10) in Schutz, A First Course in General Relativity, as (10.7.12) in de Felice and Clarke, Relativity on Curved Manifolds, and as the second equation on p. 314 of Landau and Lif****z, The Classical Theory of Fields.
(EDIT: that's pretty funny, PF autobleeped the name of a distinguished physicist. His name is also sometimes transliterated Lifschitz, but the publishers of the translation left out the Germanic "s".)
But Carroll, Spacetime and Geometry: An Introduction to General Relativity, gives in (5.66) the potential as the square, as does Clarke, Elementary General Relativity in (21), Chapter 4. So while the method of effective potentials is completely standard, the quantity called "the effective potential" is not!
Note that in mathphys, a "potential" is just something which when "differentiated" in some fashion gives a quantity of interest, such as velocity vector field or electromagnetic field. So there's no convention stating that potential must have given units, unlike potential energy which of course has the units of energy.
Dunno if this helps answer your question, which unfortunately it seems we are having difficulty understanding.
my question has been answered. thank you both very much
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 62 ·
  • · Replies 20 ·
  • · Replies 42 ·
