Finding h2 Using Steam Tables and Enthalpy Equations
  • Thread starter Thread starter cookie85
    Steam
This discussion focuses on calculating enthalpy values h1 and h2 for water using steam tables and enthalpy equations in a piston system. The user has successfully calculated h1 using the formula h1 = hf + x(hg - hf) and seeks assistance in determining h2. The relevant equations for work and heat transfer, specifically w = -PDV and Q = m(h2 - h1), are also mentioned. The guidance provided includes using steam tables to find h2 based on the known h1 value.
  • Understanding of steam tables and their application in thermodynamics
  • Familiarity with enthalpy equations, specifically h1 = hf + x(hg - hf)
  • Knowledge of the work-energy principle, particularly w = -PDV
  • Basic grasp of heat transfer calculations, including Q = m(h2 - h1)
  • Research how to use steam tables to find enthalpy values, specifically hf2 and hfg
  • Learn about the relationship between enthalpy and work in thermodynamic systems
  • Study the P-V and T-S diagrams for better visualization of thermodynamic processes
  • Explore examples of heat transfer calculations in piston systems
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in heat transfer calculations in piston systems will benefit from this discussion.
cookie85
Hello again...i was wondering if you can help?
I am using enthalpy equations to try and find h1 and h2 to work out 'work and heat transfers' for water, for a piston type question.
I have calculated work done using: [w = -PDV]
To find the heat transfer i need to use: [Q=m.(h2-h1)]
i have obtained h1 using: h1 = hf + x(hg-hf) (using steam tables)
This has been calculated at 1826 kg/m3, from a revision guide all it states to calculate h2 is:
''From the steam table using h1 find h2?''
This is the only piece of information i need to complete the heat transfer calculation (to find h2) can you help at all? I don't now how to find h2.
I know m = 0.15, and h1 is 1826kg/m3 and Q is 223 kj
But h2?!
Guidance on how to look this up would be appreciated.
It would help if you could post the complete problem statement. For these types of problems, it usually helps to draw out the P-V and T-S diagrams. I suspect the equation relating enthalpy and work will help here, it should be somewhere in your text
Posting the whole question would have got the job done but anyway have you tried these formulas
h2=hf2+(x2hfg)
since hf2 can be found on the tables and hfg
or w=h1-h2
  • Poll Poll
