| Thread Closed |
Lagrangian for a charged particle in a magnetic field |
Share Thread | Thread Tools |
| Oct9-07, 09:20 AM | #1 |
Hey I have a question that was almost completely answered in this thread:
http://www.physicsforums.com/showthread.php?t=116098 Specifically someone interpreted his question to be how exactly do you get that the term in the Lagrangian corresponding to the magnetic potential is [tex]-q\vec{v}\cdot\vec{A}[/tex] on what happened at that point. I would assume he added in [tex]\partial \phi/\partial x[/tex] because the electric potential is zero and that expression will look more like the typical [tex]E_x[/tex] that you see. The part that loses me though is how did he turn the term [tex]\dot{x}\frac{\partial A_x}{\partial x}+\dot{y}\frac{\partial A_y}{\partial x}+\dot{z}\frac{\partial A_z}{\partial x}[/tex] into [tex]\dot{y}(\frac{\partial A_y}{\partial x}-\frac{\partial A_x}{\partial y})+\dot{z}(\frac{\partial A_z}{\partial x}-\frac{\partial A_x}{\partial z})[/tex] Just from the looks of things it might be that: [tex]\dot{x}\frac{\partial A_x}{\partial x} + \dot{y}\frac{\partial A_x}{\partial y} + \dot{z}\frac{\partial A_x}{\partial z} = 0[/tex] I don't really see why that should be true, so is there another way he could have done that, or what is the reasoning behind that equation? Also, sorry in advance. I did take a look at Jackson but he jumps into some relativistic stuff that I'm not ready for right now and we don't have a copy of Franklin in our library. |
| Oct9-07, 10:18 AM | #2 |
It's explained in the book: "The Classical Theory of Fields" by Landau and Lifschitz.
| Oct9-07, 11:34 AM | #3 |
Recognitions:
[tex]
m\frac{d{\vec v}}{dt}= q[-\nabla\phi-\partial_t{\vec A}+{\vec v}\times(\nabla\times{\vec A})] = q[-\nabla\phi-\partial_t{\vec A}-({\vec v}\dot\nabla){\vec A} +\nabla({\vec v}\cdot{\vec A})] =\nabla[-q\phi+q{\vec v}\cdot{\vec A}]-q\frac{d{\vec A}}{dt}. [/tex] |
| Oct9-07, 11:38 AM | #4 |
Lagrangian for a charged particle in a magnetic field[tex]\frac{d}{dt}(m\dot{x}+qA_x)=q\frac{\partial}{\partial x}(\dot{x}A_x+\dot{y}A_y+\dot{z}A_z)[/tex] when I assumed that you could take that derivative of [tex]A_x[/tex] with respect to time partially. If I had taken a total derivative I'd have seen instead: [tex]m\ddot{x}+q\frac{\partial A_x}{\partial t} + q(\dot{x}\partial_x A_x + \dot{y}\partial_y A_x + \dot{z} \partial_z A_x) =q(\dot{x}\partial_x A_x +\dot{y}\partial_x A_y+\dot{z}\partial_z A_z)[/tex] and that gives me what I was hoping for: [tex]m \ddot{x}=-q\frac{\partial A_x}{\partial t}+q[\dot{y}(\frac{\partial A_y}{\partial x}-\frac{\partial A_x}{\partial y})+\dot{z}(\frac{\partial A_z}{\partial x}-\frac{\partial A_x}{\partial z})]=qE_x+q(\dot{y}B_z-\dot{z}B_y)[/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Lagrangian for a charged particle in a magnetic field
| Thread | Forum | Replies | ||
| why magnetic field deflects a charged particle.? | General Physics | 1 | ||
| How can a magnetic field move a charged particle? | Introductory Physics Homework | 1 | ||
| Charged particle in a magnetic field | Special & General Relativity | 26 | ||
| Charged Particle in Magnetic Field | Introductory Physics Homework | 5 | ||
| Charged Particle in Magnetic Field | Advanced Physics Homework | 2 | ||
