Basic Question about angle of inclination of a circle
The discussion centers on calculating the angle of inclination of a circular ring observed in the sky, specifically in the context of supernovae measurements. The key takeaway is that a circle viewed at an angle appears as an ellipse, where the longest diameter (x) and shortest diameter (y) can be used to determine the inclination angle (θ). The formula to calculate this angle is cos-1(y/x). This geometric approach simplifies the process of deriving the inclination from angular measurements.
  • Understanding of basic geometry principles
  • Familiarity with angular measurements in arcseconds
  • Knowledge of trigonometric functions, specifically cosine
  • Concept of elliptical shapes as projections of circular objects
  • Study the properties of ellipses and their relation to circles
  • Learn about angular diameter measurements in astronomy
  • Explore trigonometric identities and their applications in geometry
  • Investigate practical examples of inclination calculations in astrophysics
Astronomy students, astrophysicists, and anyone interested in understanding geometric projections of celestial objects.
kungfuscious
I've seen some measurements of supernovae, and they often mention a ring that's expanding. I can follow that. What is often stated is that they assume the ring is a circle, but of course it's seen at an angle from Earth.
One such example was a ring that looks like it's a certain size in the sky (x arcseconds, by y arcseconds). Assuming it was a circular ring, the auther just jumps to a conclusion, something like: "using geometry, we can see that the ring is inclined at an angle of e.g. i=29 degrees to face-on"
This should be simple geometry, and yet I'm stumped as to how to get the angle of inclination of the ring, assuming it's circular and looking at it's size in the sky in arcseconds.
Does anyone have any ideas?
Astronomy news on Phys.org
Welcome to PF!
kungfuscious said:
… One such example was a ring that looks like it's a certain size in the sky (x arcseconds, by y arcseconds). Assuming it was a circular ring, the auther just jumps to a conclusion, something like: "using geometry, we can see that the ring is inclined at an angle of e.g. i=29 degrees to face-on"
Hi kungfuscious ! Welcome to PF! :smile:
Yes, it's simple geometry …
a circle seen at a angle is an ellipse …
take a vertical circle of angular diameter x, and turn it round the vertical diameter, through an angle θ …
the vertical diameter will have the same angular size, x, but the horizontal diameter will be reduced to angular size y = x cosθ …
so just measure the longest and shortest diameters, x and y, and the angle is cos-1 y/x :smile:
