Oxidizing iron bacteria made to work in reverse
The discussion centers around the potential for reducing ferric iron (Fe^+3) back to ferrous iron (Fe^+2) using bacteria that typically oxidize iron in a biological water filtration process. Participants explore the feasibility of manipulating the conditions under which these bacteria operate, particularly in anaerobic environments, to achieve this reduction. The context includes biological treatment processes, microbial behavior, and potential biochemical mechanisms.
  • One participant describes the operation of a biological water filtration plant where bacteria oxidize ferrous oxide to ferric oxide, leading to rust buildup that requires backwashing.
  • The same participant proposes adding glucose to create anaerobic conditions, suggesting that the bacteria might reverse their typical function and reduce ferric iron back to ferrous iron.
  • Another participant references an article related to iron bacteria, expressing interest in the mechanisms involved and the enzymes that facilitate the reactions, indicating a need for further investigation into the biochemical processes.
  • A different participant mentions a specific bacterium, Brachybacterium sp Mn32, without elaborating on its relevance to the discussion.
  • One participant suggests conducting a literature search to identify the reactions and mechanisms involved, recommending collaboration with a biochemistry department for further insights.
Participants express varying degrees of curiosity and propose different approaches, but there is no consensus on the effectiveness of the suggested methods or the specific mechanisms involved in reversing the oxidation process.
Participants note that the bacteria in question are not thermophiles and are operating at around 10 degrees Celsius, which may influence their behavior and the feasibility of the proposed methods.
Rexmundi
My employer operates a biological water filtration plant. The first stage of filtration has the raw water passing through a filter embedded with bacteria, the processes used here is aerated biological treatment where oxidizing processes (bio-oxidation) are used and the microbes gain energy when they transform the ions from a reduced to an oxidized state.
Specifically in the first filter the bacteria oxidize all ferrous oxide to ferric oxide (Fe^+2 to Fe^+3) which is caught in the filter and when the water moves on to the next stage it is completely free of iron.
The large amount of rust build up in the first filter must be periodically cleansed by backwashing. When water is pumped backward through the filter it comes out with both a very very high concentration of Fe^+3 and a portion of the bacteria population.
What I am looking for is a way to reduce the iron in a sample of this backwash water back to Fe^+2. It has been suggested that perhaps an alternative energy source such as glucose could be added then the sample sealed so the bacteria would use all of oxygen present and create anaerobic conditions. In this environment might the very same bacteria that oxidized the iron begin to reduce it?
If not, are there other suggestions on how to accomplish this?
Biology news on Phys.org
If it helps I'll link to an article by Toni A. M. Bridge and D. Barrie Johnson
http://aem.asm.org/cgi/content/abstract/64/6/2181?maxtoshow=&HITS=10&hits=10&RESULTFORMAT=&titleabstract=iron+bacteria&searchid=1&FIRSTINDEX=0&resourcetype=HWCIT
This describes the process I'd like to emulate but my bacteria are living in water at about 10 degrees Celsius so are definitely not thermophiles.
Curious me, have you heard of Brachybacterium sp Mn32? :smile:
Interesting article. I only skimmed it, but there does not appear to be a mechanistic explanation for the reaction- what enzymes are involved? Once you know the players in the reaction, you can start to ask how to run the reaction in reverse.
I'd recommend doing a literature search (PubMed is a good place to start) to see if you can identify the reaction. And hie thee to a biochemistry department- someone there would be able to help.
12K
  • · Replies 37 ·
9K
16K
35K
