| Thread Closed |
URGENT variable name matlab help |
Share Thread | Thread Tools |
| Oct2-09, 12:15 AM | #1 |
How do i change the variable, so it saves all the values, even if it must happen for 6 different variables name. This is because when i run it, it only saves the values for v_max when n=10 as this is the last iteration. How can i make all the values be saved. My coding is below:
radius=1:0.5:2.5; total_flow_velocity=5 for n=5:1:10 v_max = (total_flow_velocity.*(1+n).*(1+(2.*n)))./((2.*pi)*((radius.*n).^2)) end Thanks |
| Oct2-09, 03:06 AM | #2 |
probably the best way is to store them in a vector. You define a vector called v_max with a length equal to the amout of values, in your case that is 6:
v_max=[1:6]; then you can store each value in one of the positions of the maxtrix like: for n=5:1:10 v_max(1,n-4) = (total_flow_velocity.*(1+n).*(1+(2.*n)))./((2.*pi)*((radius.*n).^2)) end I used n-4 to define column number 1 because you start with n=5. After that you can recall any value by typing: v_max(1,1) .... v_max(1,6) good luck! |
| Oct2-09, 03:34 AM | #3 |
ive tried it but i get the error "Subscripted assignment dimension mismatch." ? Also why did u do vmax=[1:6] because for each r value ive made it so i get an answer at each n value, so shouldnt the matrix be a 6x4?
| Oct2-09, 08:00 AM | #4 |
JeroenS' code has a mistake inside for loop. v_max(1,n-4) ==> indicate member (1, n-4) of array v_max. However, in the calculation, he forgot to delete the operator for array: (radius.*n). This operator (.*) will return an array radius multipled by n. So, in the left-side, you have 1 variable, not an array but in right side, there is an array. That's the reason matlab throws an error.
My code is: Code:
vM = [];
j = 0;
radius = 1 : 0.5 : 2.5;
tfv = 5;
for n = 5 : 1 : 10
j = j + 1;
nR = 2 * pi * (radius * n).^2;
vM(j, :) = (1 + n) * (1 + 2*n) * tfv ./ nR;
end
p/s: i am totally confused when i read your code. There are many unnecessary parentheses and operators. |
| Oct2-09, 06:41 PM | #5 |
Thanks so much, yeh i don't know why i use so many brackets and that, buts it because im use to the calculator and have only been learning MATLAB for a few weeks now :P but im beginning to learn to use less brackets :P
| Thread Closed |
| Thread Tools | |
Similar Threads for: URGENT variable name matlab help
| Thread | Forum | Replies | ||
| MATLAB - changing variable name with each iteration? | Math & Science Software | 16 | ||
| Matlab: Use string variable as variable name | Math & Science Software | 5 | ||
| MATLAB char array with variable names | Math & Science Software | 2 | ||
| matlab user input variable name | Math & Science Software | 1 | ||
| Stochashic variable result(Please verify) Urgent | Calculus & Beyond Homework | 0 | ||
