| Thread Closed |
coefficients of a matrix |
Share Thread | Thread Tools |
| Jun24-04, 10:31 AM | #1 |
Hallo everybody.
I have a square matrix where the coefficients of the diagonal are 1, while the others are very small (say 10^-6). Of course the determinant of this matrix will be always one. This is my problem: the coefficients are functions of a variable (w, complex variable). So, the determinant of the matrix will be a function of w. I need to find the solutions, the roots w of this function (the determinant=0), but since the diagonal is made of 1 and the other coeffs are very small, this function will be constant and equal to 1. How can I avoid this problem...extracting the diagonal... I tried to normalize the other small coefficients using new variables but they still are very small. Thank you for your help, Ario |
| Jun24-04, 02:04 PM | #2 |
Recognitions:
Being small in abs value and being zero aren't the same thing. also what is the size of the matrix? if it is a 10**6 by 10**6 matrix then the small entries may contribute significantly to the determinant. other than this it appears you're just using numbers that are too small for your computer to handle.
| Thread Closed |
| Thread Tools | |
Similar Threads for: coefficients of a matrix
| Thread | Forum | Replies | ||
| Matrix manipulations/rank of a matrix | Calculus & Beyond Homework | 2 | ||
| Help! Diagonal matrix similar to upper triangular matrix? | Linear & Abstract Algebra | 1 | ||
| Give the ranks of both the matrix of coefficients and the augmented | Linear & Abstract Algebra | 1 | ||
| The stiffness matrix in matrix analysis of strutures | Classical Physics | 0 | ||
| Matrix, making R2 to R3, finding standard matrix A! where did i mess up? | Calculus & Beyond Homework | 1 | ||
