Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > General Physics
Reply
image Re: Can someone help me to better understand energy Share It Thread Tools Search this Thread image
Old Nov13-09, 07:31 PM                  #33
DaleSpam
DaleSpam is Online:
Recognitions:
I really don't think it is so complicated. Energy is the capacity to do work, work is force times distance. jambaugh is correct that there are all sorts of interesting advanced topics, but none of it changes the fundamental definitions, especially not at the level of the OP.
Old Nov13-09, 08:06 PM                  #34
Phyisab****
Phyisab**** is Offline:
I just want to say that Jambaugh, that was a very good explanation.
Old Nov14-09, 11:18 AM                  #35
stevefaulkner
stevefaulkner is Offline:
Would it be true to say that energy is the only conserved quantity that transforms as a scalar?
Old Nov14-09, 11:23 AM                  #36
Gerenuk
Gerenuk is Offline:
If you consider frame transformations, which is different from the time evolution transformations, then any product of two vectors is a scalar (rest mass of a particle, ...).
Not sure how this refers to time evolution transformation. I think in general energy, momentum and angular momentum are the only integrals of motion unless you deal with a special problem.
Edit: Oh, I see. You meant something that is both
Then in general only energy should be the conserved scalar. Unless the problem is a special one.
Old Nov14-09, 02:59 PM       Last edited by jambaugh; Nov14-09 at 03:03 PM.. Reason: clarification            #37
jambaugh
jambaugh's Avatar
jambaugh is Offline:
Recognitions:
PF Contributor PF Contributor
Not at all. Firstly it is only scalar in a non-relativistic setting. In SR energy is one component of the 4-vector energy-momentum. Electric charge and the other gauge charges are space-time scalars (with some slight qualification on weak isospin due to weak parity issues).
The nice part of the link between conserved quantities and symmetry transformations is that how the quantities transform (whether they are scalar, vector, tensor, ...) with respect to the various groups (rotation, Lorentz, Poincare, ...) is made explicit by how the symmetry transformations themselves transform. Consider that translation in the x direction can be rotated to translation in e.g. the y direction. Hence rotations act not only in concert with translations on objects, but also rotations act on translations. This is called the adjoint action of one transformation on another.
Since time translation is "scalar" i.e. invariant under spatial transformations (rotations and spatial translations) Energy is scalar in this non-relativistic setting. Since spatial translation in a given direction gets rotated by a rotation transformation so does momentum. Momentum is a vector quantity.
In the relativistic setting you can think of energy as "momentum in the time direction" and Lorentz transformations act on the four momenta as a 4-vector.
One final note. You can imagine for some system that you can "tweak" the dynamics to have any arbitrary symmetry or that you break a given symmetry. This does not interfere with the link between measurable quantities (which may or may not be conserved) and transformations (which may or may not be symmetries).
EDIT: In short the link is there without worrying about the quantity being conserved or the transformation being a symmetry :END EDIT
This is made most explicit in the formulation of quantum mechanics where the operators generating the transformations are identified mathematically with the operators corresponding to the observables.
The momenta ARE the generator of translations,
Energy (the Hamiltonian) IS the generator of time evolution,
Angular Momenta ARE the generators of rotations.
It is all very elegant and beautiful. That it also yields an accurate description of how nature behaves is gravy on the biscuit!
image image
Reply
Tags
energy
Thread Tools
Similar Threads for: Can someone help me to better understand energy
Thread Thread Starter Forum Replies Last Post
I don't understand anything. oscarkool2 Introductory Physics 1 Feb10-09 03:45 AM
I don't understand why this is wrong (Work and kinetic energy problem) frankfjf Introductory Physics 4 Feb23-06 07:48 AM
Help me understand this Reshma Introductory Physics 10 Apr28-05 02:44 AM
Help me understand! Amber Introductory Physics 9 Sep19-04 03:23 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
