| New Reply |
What is our Solar System's orbital plane around the Milky Way? |
Share Thread |
| Dec2-09, 04:48 PM | #18 |
The topic of crossing the "galactic plane", coinciding with the Mayan calendar, and the catastrophe of "world's end in 2012" are a mixed muddling of mythology.
The Mayan calendar comes to an end (in linear counting mode) in 2012. However, the calendar itself is a circle and the Mayans thought in this circular pattern, much the same way astrology and the Chinese calendar are cyclic patterns. Crossing the galactic plane is speculation, but also a cyclic event. Much is still unknown about the electrical nature of the cosmos as far as "action at a distance". The concern from some theorists is that the "plane" transit is related to our magnetic field shift, which is also a cyclic pattern. Since we've only inhabited this rock as semi-sentient beings for a short time, we have yet to experience that effect first-hand. Hard data is difficult to find and there is a lack of consensus among those who are "supposed" to know these things... I'm just a knucklehead... woolf |
| Dec2-09, 07:03 PM | #19 |
Recognitions:
Magnetic field reversals are not at all regular (and are probably chaotic) but occur at an interval of < 1Myr. |
| Dec27-09, 10:32 PM | #20 |
Have you ever looked out into the night sky and seen the Milky Way Galaxy? Did you notice the obvious tilt? It is at a steep angle to the straight line of the horizon. Why? It turns out that our solar system appears to belong to another galaxy that is colliding with the Milky Way. This was recently discovered when scientists were trying to figure out sources for "Dark Matter" that would account for forces we can measure but not see visibly. Using near-infrared a huge sister galaxy circling the Milky Way was discovered. It's called the Sagittarius Dwarf Galaxy,(SGR for short). For those keen on the 2012 data, this is the reason our entry point to the rift, center, heart of the Milky Way is thru Sagittarius. The two collide at this point. This explains why our solar systems is at a angle to the plane of the galaxy and why we dip above and below that center line every 12,000 years or so. After slow, continuous gnawing by the Milky Way, Sagittarius will be whittled down to the point that it cannot hold itself together much longer!
| Dec27-09, 11:37 PM | #21 |
| Dec28-09, 12:37 PM | #22 |
For those who talk about the "plane of the galaxy" as an actual plane, we can be fairly certain that the earth has passed through it. For those who use that term to refer to the general area of increased star density of the galaxy, we are passing through it. Just a difference in semantics, I think. |
| Dec29-09, 12:36 AM | #23 |
Amusing. The 26,000 year cycle relative to what? Earth completes a 26,000 year wobble cycle every second, minute, hour, day, month ... etc. It would be an eerie coincidence if earth's precessional cycle coincides exactly with the frequency the sun crosses the 'galactic plane' Just how often does this happen? I believe an 'alignment' event also occured in 1998 - so it appears an earth-sun alignment with the plane of the galactic center can occur in as few as 14 years apart. Read between the hoof prints.
| Dec30-09, 12:02 PM | #24 |
I recall reading that periodic mass extinctions of life may be caused by the sun's orbit of the galaxy, when the orbit crosses through the galactic plane. This crossing of the galactic plane happens every 120 million years, twice during each 240 million year orbit. The greater density of objects in the galactic plane causes gravitationally-induced perturbation of the Oort cloud, which then rains down a comet bombardment on the earth. Since the dinosaurs vanished 65 million years ago, I dont think we will get back to the galactic plane by 2012! Also, I would expect the duration of the crossing to last on the order of a million years, because the galactic plane is 1000 light years thick (galactic diameter is 100,000 light years).
| Dec30-09, 12:52 PM | #25 |
Recognitions:
The sun doesn't move in a perfect plane relative to the galaxy, it wobbles above and below it's incline - these wobbles may be linked to extinction events. But if you are free to choose which wobbles you want to include then you can get them to match any sequence of events you like. |
| Dec30-09, 05:40 PM | #26 |
Mentor
Our galaxy has angular momentum, which determines a rotation axis; the galactic plane would be perpendicular to that axis. Our galaxy also has a center-of-mass, which would lie within the galactic plane. Since we can in principle specify the plane's orientation as well as a point that it contains, the plane is defined. However, actually measuring the necessary quantities (angular momentum and center-of-mass location) are another matter. |
| Dec30-09, 05:56 PM | #27 |
Recognitions:
We do define 'a' galactic plane, it's the basis of the galactic coordinates
It's not quite accurate, for instance the black hole at the centre of the galaxy isn't quite at 0,0 Defining the exact plane is tricky because it becomes a question of which objects you count as being in the galaxy (eg the LMC/SMC) and how far out you include the halo. |
| Dec30-09, 06:08 PM | #28 |
Mentor
| Dec30-09, 06:12 PM | #29 |
Recognitions:
We pick the sun and the centre of the galaxy as two points to give a coord system
http://en.wikipedia.org/wiki/Galactic_coordinate_system The mass distribution of the galaxy is pretty well known from rotation curves, at least as far out as we can see stars. The centre of the galaxy is pretty well defined, it helps that there is a couple of million solar mass black hole there! The extent of the galaxy is like defining the edge of the atmosphere - it's pretty wooly. |
| Dec30-09, 07:10 PM | #30 |
| Jan1-10, 07:59 AM | #31 |
Dear MGB,
Thanks for the info on sun's journey within galactic disk - you are better than Google! You surprised me when you said we are near the midway point within the disk. A look at the Milky Way or photo of same shows a very obvious half-dome marking the half of the spherical galactic center that shows above the dust lanes; the other half of of the galactic center shows as mostly obscured by dust lanes. Are the dust lanes themselves are below (or above?) the mid-point of the galactic disk? On the sun passing through the galactic disk, when I Googled that one, the real story is that mass extinctions line up with the one end of the "bar" of our barred spiral galaxy, passing by our sun. Another view is that a spiral arm passes through the area of our sun. The time periods match within 50% margin of error, so its not definitive, but still a possibility. In my original post I didnt want to get mired in all that detail, thanks for calling me on that - I hate laziness! |
| Feb6-10, 05:51 PM | #32 |
| Feb7-10, 01:35 AM | #33 |
| Aug30-10, 12:40 AM | #34 |
This article is about the Sun and its planetary system. For other systems, see planetary system and star system.
| New Reply |
Similar discussions for: What is our Solar System's orbital plane around the Milky Way?
| Thread | Forum | Replies | ||
| The ecliptic planes of the Milky Way and the solar system | General Astronomy | 4 | ||
| Voyager 2 Detects Odd Shape of Solar System's Edge | General Astronomy | 3 | ||
| Mutual solar-extrasolar orbital foci | Astrophysics | 2 | ||
| Extra-solar Planets : Mass vs. Orbital Distance | General Astronomy | 6 | ||
| D orbital XY plane Wavefunction | Quantum Physics | 0 | ||
