Originally Posted by berkeman
Don't think you can solder to stainless steel. You should probably be reading about how to weld to stainless steel instead.
Sure you can, but you need to use special
flux made for soldering stainless steel (I quite often have to solder SMA connectors to stainless steel coax). You don't need any special equipment or special solder, but you DO need to flux in order to make a good joint (it IS possible to get it to stick without flux but the joint are weak).
When you say "wet", what does that mean? Immersed in seawater or something that might occasionally get sprayed by fresh water.
Although If you are already using a copper plate I can't see any reason normal copper wire wouldn't be ok.
