| Thread Closed |
Lowing boiling point of water |
Share Thread |
| Dec2-09, 02:41 AM | #1 |
Is there any catalyst or substance that can do this?
| Dec2-09, 03:22 AM | #2 |
Admin
A lot depends on what you mean by "water". Obviously you are ready to accepts some mixture - vodka is such a mixture, and it boils at much lower temperature.
That is assuming by "lowing" you meant "lowering". So short question, so many meanings ![]() -- chemical calculators - buffer calculator, concentration calculator www.titrations.info - all about titration methods |
| Dec2-09, 03:40 AM | #3 |
Hmmm I seem to remember that in my time the boiling point was defined as the boiling temperature of the pure liquid at one atmosphere (or sea level). But it seems to be defined as the normal boiling point now
Any fluid boils at reduced temperatures at reduced ambient pressure. That limited us from flying above 62.000 feet, then blood starts to boil. |
| Dec2-09, 04:23 AM | #4 |
Admin
I suppose the question is meant to be understood as "lower boiling point after something has been added all other things being equal". But it is as vague as a question can be.
![]() -- buffer calculator, concentration calculator pH calculator, stoichiometry calculator |
| Dec2-09, 07:13 AM | #5 |
As Borek wrote, is impossible to lower the BP of water without significant amounts of another chemical (so, "catalythic" amounts are excluded).
Here there are some values of BP of mixes water + other liquid: http://en.wikipedia.org/wiki/Azeotrope_(data) From these data you see how is difficult to lower the BP of water: if you want to use little amounts of chemicals, you could, e.g. use 9% benzyl alcohol, but the BP lowers of 0.1°C only.; or you could use cyclohexanol and you lower the BP of 2.2°C, but you have to use at at 20%... |
| Dec2-09, 07:30 AM | #6 |
Admin
Note that many substances will not lower, but raise the boiling point; that depends on the vapor pressure of the substance.
| Dec2-09, 09:36 AM | #7 |
If you mean regular tap water, I would imagine that removing some of the ions (Ca2+, Mg2+, etc.) would lower the boiling temperature slightly because of colligative properties. You can do this with a Brita filter, but the boiling point depression depends on the initial concentrations of the ions in this case. I'm pretty sure this isn't what OP meant though.
| Dec5-09, 12:21 AM | #8 |
Hmm yes it was what I thought. It would probably against conservation of energy unless for some instance energy going into boiling water was wasted by a large degree.
| Thread Closed |
Similar discussions for: Lowing boiling point of water
| Thread | Forum | Replies | ||
| Time to bring water to its boiling point? | Introductory Physics Homework | 8 | ||
| Raising boiling point of salt water | Classical Physics | 3 | ||
| Calculating the boiling point of water | Classical Physics | 5 | ||
| Boiling point/freezing point | Biology, Chemistry & Other Homework | 1 | ||
| boiling point vs. freezing point | Biology | 3 | ||
