| New Reply |
Single Phase |
Share Thread | Thread Tools |
| Apr16-10, 01:00 AM | #1 |
Single Phase
Hi,
I am struggling with finding info on Electrical Phases. I understand that Single Phase is simply one ac signal, and I understand that 3 phase is 3 independent ac signals, all of which are exactly 120 degrees out of phase. My struggle comes in when I think about 220 volt dryer hookup in my house. There are 3 legs...2 'hots' and a ground. The 2 hots are each 110 volts. 1. But are they in phase or out of phase? I think they are out of phase in order to get 220 volts between the hot legs, right? 2. Are they 180 degrees out of phase? 3.What makes them 180 degress out of phase? |
| Apr16-10, 04:00 AM | #2 |
Recognitions:
What you have in your house is nothing to do with the 3 phase high voltage power distribution system.
Out in the street somewhere there is a transformer that converts the voltage between two phases of the high voltage power supply to a centre-tapped 220 volt output from a single winding. The opposite ends of this are out of phase with each other by 180 degrees. When one end swings positive relative to the centre tap, the other swings negative. Other appliances and lighting in your house use the centre tap (as a neutral) and one of the outside legs (as an active) of this winding to get 110 volts. This system is fairly unique to North America. Most other countries bring one of three phases or all three phases into the house at about 230 volts. High power (at about 400 volts) is available between the phases. Three phase motors are more efficient than single phase ones and self starting, too |
| Apr16-10, 07:41 AM | #3 |
I think this is mostly a terminology problem.
Two wires will just have an alternating voltage (say 50Hz) between them. You might call this a 'single phase system'. Another two wires may have another 50Hz AC between them. These two signals may not be in phase with each other; there is a 'phase difference'. You can have three pairs of wires with 120 degrees of phase difference between them. Let's make the amplitudes of the voltage on all three pairs the same. If you take the appropriate wire of each pair and join them together, you will have a 'three phase' system. The common point is called the Neutral. Somewhere in the system, this is usually connected to an 'Earth' . If you take the three pairs and connect them to equal loads then very little current (zero) will flow into the Earth connection because the neutral currents will add up (in phase and amplitude) to zero at the common point. There will be a voltage between any two of the phases which is √3 times the voltage on one pair. This is the Vector Difference between the two so-called Phasors. The three 'live', physical connections are referred to as 'phases' - which could be viewed as an unfortunate choice of name. If you have just two pairs carrying AC and the signals are in phase, you can connect one of each pair to a common point and you will get Zero Volts difference, connecting one way round and twice the voltage, connecting the other way. Again, this is the vector difference between the two signals. The US domestic system (above) seems very bizarre, to me, but it is just the consequence of the way the system grew and the fact that someone chose 110V as the operating voltage. Cables would need to be so thick for supplying large loads that 'they' had to introduce this strange 'two phase' system which can deliver four times the power with the same cable thickness by supplying twice the voltage as an option. (Power = V2/R). It has caused a lot of confusion - especially to non US observers! - but it serves a purpose and allows a lower (and a bit safer) operating voltage for most domestic equipment. It is the three phase system that is used, worldwide, for generation, distribution and large motors and it is this system which is most elegant and useful. The other system just gives you twice the volts. |
| Apr16-10, 01:22 PM | #4 |
Single Phase |
| Apr16-10, 02:06 PM | #5 |
The voltage between two wires can't be "out of phase" it is just an alternating voltage between them. You can only compare the phases of two signals. If you refer the voltages of two of the three phase supply to Earth, then they will be 120 degrees out of phase. But, using one as a reference, the other will just have an alternating voltage. The magnitude of that voltage is given by the trigonometry of the Phasors.
It's a matter of terminology. |
| Apr16-10, 02:20 PM | #6 |
A typical house in the US uses this setup:
One of the power company's three-phase legs comes to an individual house. Power companies try to distribute the legs equally so that they each have the same load but that's a different story. If I remember correctly, a leg may be around 4kV at distribution level. The leg is connected to center-tapped transformer at the house. The primary side is a single coil that connects to the distribution voltage. The secondary side of the transformer is a center-tapped coil and the tap is connected to the house's ground which ties it to 0V. The center-tapped coil is arranged so that the ends of the secondary coil are +120V on one side and -120V on the other side with respect to the grounded center-tap. Note, I don't mean that the voltages are literally positive or negative, instead they are out of phase by 180 degrees. Smaller appliances can connect across one of the split 120V legs to ground. Larger appliances can connect across both 120V legs, and because they are out of phase by 180 degrees, they will get 240V. Go look inside the circuit breaker box (carefully, after opening the main switch outside your house at the main box under the meter). You'll see that the box has three buses. The center bus is the 0V ground an the sides are the +/-120V legs. Look at how the big appliance lines and small appliance lines are connected. ETA: Scratch that last part about looking inside the breaker box. Don't try this at home kids. (Are you a kid?) |
| Apr16-10, 03:58 PM | #7 |
| Apr16-10, 04:09 PM | #8 |
Mentor
| Apr16-10, 04:48 PM | #9 |
Fame at last chaps!
| Apr16-10, 06:14 PM | #10 |
Recognitions:
Good move.
Variations on this question come up all the time. |
| Apr16-10, 06:41 PM | #11 |
| Apr16-10, 06:47 PM | #12 |
| Apr16-10, 09:33 PM | #13 |
Recognitions:
It doesn't make much difference. In the US, as I understand it, the high voltage distribution system does not include a neutral. In other countries it does.
You can take the voltage between phases to the primary of the transformer or you can take the voltage from one phase to neutral to the primary of the transformer. |
| Apr17-10, 10:59 AM | #14 |
If you connect between two phases you will get 'root three' times the voltage.
But either the so called Star or Delta connections can be used. In the UK, it is more common, afaik, to have a three phase HV transformer to produce three low voltage , single phase supplies with a common Neutral. These are then distributed around a neighbourhood, houses being supplied with phase 1,2,3,1,2,3,1,2,3, alternately as you go down the road. It is discouraged to connect electrical supplies from a house to the adjacent house as this will involve the existence of 400V between points in the same premises and this is a potential hazard if you are not prepared for it. |
| Apr17-10, 11:07 AM | #15 |
If you consider the potentials of the two legs relative to some other reference, then there could be a different value of phase difference - but this is not a likely scenario unless you happen to be a power engineer waving a phase meter around in a substation and connecting, willy-nilly to all possible terminals in sight! |
| Apr17-10, 12:32 PM | #16 |
The advantage of delta is that it only requires three wires as opposed to wye's 4 wires. The advantage of wye is that it can survive being unbalanced. Wye can be safer too because you can ground it. That's why both are used. Deakn, maybe you could look at a diagram for a delta-wye transformer to get an idea of delta and wye are related. A "leg" is simply a sampling of one voltage difference. Let's circle back around to your original question. I think there was a bit of initial confusion because the US system is totally different from European systems. The three-phase system is not important inside a US home. You won't have to deal with any three-phase power unless you work at an industrial park that uses lots of juice. You were right about the phases of the two buses being out of phase by 180 degrees. Vk's drawing shows how the transformer accomplishes that. |
| Apr18-10, 07:11 PM | #17 |
In that picture drawing can i get more info explained on how the two phases that are taking from the powerplant that are 120 degrees out of phase relative to neutral are then changed to 180 degrees out of phase
| New Reply |
| Thread Tools | |
Similar Threads for: Single Phase
| Thread | Forum | Replies | ||
| Alternator Problems (3 phase and single phase AC Motor) | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Wye 3 phase to single phase distribution woes | Electrical Engineering | 9 | ||
| 3 phase vs. single phase power | Electrical Engineering | 13 | ||
| Alternator Problems (3 phase and single phase AC Motor) | Engineering, Comp Sci, & Technology Homework | 0 | ||
| 3 phase 240 Delta Vs single phase 240 | Electrical Engineering | 18 | ||
