| Thread Closed |
Heat exchanger forum |
Share Thread | Thread Tools |
| Jun25-10, 05:35 AM | #1 |
Hi all....
can anyone help me thru these questions... a) % of thinning allowance calculation of tubes while expansion b) standard drwg. for tube to tube sheet weld joints c) Inner Radius (Min.) calculation for floating Head Cover In AES Heat Exchanger d) Selection criteria for sliding strip/sealing strip width & thk only, length will be considered according to tube bundle length e) calculation for finding PULL OUT LOAD ( for conduct mock up test) kindly respond Thanks in Advance... |
| Jul3-10, 07:50 AM | #2 |
You need to read the ASME Section VIII Div.,1 code and the TEMA Standards.
Thanks Matt |
| Thread Closed |
| Tags |
| forums, heat exchanger |
| Thread Tools | |
Similar Threads for: Heat exchanger forum
| Thread | Forum | Replies | ||
| Can this be done with a heat exchanger? | General Engineering | 6 | ||
| Is the overall heat transfer coefficient constant for a certain heat exchanger? | Advanced Physics Homework | 0 | ||
| heat exchanger | Materials & Chemical Engineering | 0 | ||
| Is this even possible? (heat exchanger problem) | Mechanical Engineering | 4 | ||
| Heat Exchanger problem | Mechanical Engineering | 7 | ||
