Troubleshooting Laptop Battery Detection Issues
  • Thread starter Thread starter R.Harmon
    Battery Laptop
The discussion revolves around troubleshooting battery detection issues in Sony VAIO laptops. Participants explore potential causes for the laptop not recognizing the battery, including hardware failures and user actions that may have led to the problem.
  • One participant suggests swapping batteries with another VAIO to determine if the issue lies with the battery or the laptop itself.
  • Another participant mentions a recall of Sony batteries, proposing that the user check if their battery is part of that recall.
  • A participant shares a personal experience where their laptop battery was not recognized after being removed while on AC power, and describes a reset procedure that resolved their issue.
  • A different participant recounts a similar experience with their VAIO, noting that after performing a reset procedure, the battery was still not detected and expresses skepticism about the battery being faulty.
Participants do not reach a consensus on the cause of the battery detection issue, with multiple competing views and proposed solutions remaining unresolved.
Some participants mention specific actions taken to troubleshoot the issue, but there are no definitive conclusions about the effectiveness of these actions or the underlying cause of the problem.
R.Harmon
Hi,
So I have a Sony VAIO laptop, and recently the batterys decided to stop being recognised by the computer (if I go to the power meter in the control panel, it reads the battery as "not present"), so I run off of AC power and disconnect the lead, the laptop just turns off. The problem is sony want £139 for a new battery, which is a little steep, and the last thing I want to do is replace the battery when that's not the issue. So I suppose my question is, is there anything else that could be causing the battery to not be recognised like this, other than the battery itself being faulty? Thanks for any help!
Rob
Computer science news on Phys.org
Do you know anybody else with a Vaio? You could swap batteries to see if the problem follows the battery or the laptop. If it stays with your laptop, it should be a pretty easy fix for a repair place familiar with Vaios. If the problem follows the battery, then a new battery would probably be the cheapest fix.
There was a huge recall of Sony batteries last year (or was it 2 years ago), is it possible you might have one of these batteries? If the machine is a couple of years old then you might want to check out the serial numbers against those of recalled batteries.
My Acer Timeline laptop battery stopped being recognized after I pulled it out while on AC power. It may be that your battery or the measuring circuit of the battery needs some kind of a reset.
I solved my problem by shutting down the laptop, then I pulled out the AC power cord AND the battery. Then I put the battery back in and rebooted. Now the battery was recognized.
ok so i have a similar problem. my vaio laptop (about 2.5 years old) recently froze while it was shutting off, so i pulled out both the battery and the ac adaptor and it shut down. i then put both back in and it turned back on, but in the bottom right corner it said änd still says "No battery is detected." i tried smallphi's solution, turning the computer off, taking both out, then putting both back in, but the same problem occurred. i know that the battery can't be the problem, because it has had no problems at all up until i did this. is there any other quick fixes to this?
  • · Replies 24 ·
