Thread Closed
Graph descriptions of velocity, acceleration, speed and time
Share Thread
Oct1-10, 06:29 PM   #1
I can't understand the choices or the questions properly. And I want to know which of the following is right. I would appreciate it if you gave a hint or explanation. Thanks
1)For an object moving with constant positive acceleration, the displacement over a period of time could be found by taking:
a) integral of the velocity vs time graph.
b)integral of the acceleration vs time graph.
c)derivative of the velocity vs time graph.
d)derivative of the acceleration vs time graph.
2)For an object moving with constant positive velocity, the displacement vs time graph is:
a)parabolic with an intercept of zero.
b) linear with slope which is equal to the acceleration.
c)linear with slope which is equal to the velocity.
d)horizontal.
Sorry that I didn't add the template
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Oct1-10, 06:48 PM   #2
Mentor
You can use simple dimensional arguments to figure out these questions. Imagine if the velocity were constant. Then the velocity-time graph would be flat, and the displacement would just be velocity*time, which would correspond to the area under the graph (a rectangle). You know this is right, because speed*time has units of length. The units have to work out. Now you're just considering a genaralization of that case to NON constant velocity (the graph is not flat anymore). The displacement is still given by the area under the curve, which still has the right units. It's just that a simple multiplication is no longer sufficient to calculate the area underneath a curve of arbitrary shape. You have to integrate.
Oct1-10, 06:54 PM   #3
fss
Quote by asz304 View Post
This is just a question about the relationship between acceleration, velocity, and displacement. If you know (or look up) how you go about finding one from another using basic calculus, you'll be able to get this quite easily.
d)horizontal.
What does a graph of constant positive velocity look like? How do you get a displacement graph from a velocity graph?
Thread Closed
Similar discussions for: Graph descriptions of velocity, acceleration, speed and time
Thread Forum Replies
Graph descriptions of velocity, acceleration, speed and time Introductory Physics Homework 1
Drawing the angular velocity graph from the acceleration vs. time graph? Introductory Physics Homework 5
how to do velocity-time graph to distance graph/acceleration to velocity graph? Classical Physics 1
How do I calculate speed in a velocity-time graph? Displacement-time graph? Introductory Physics Homework 1
Converting velocity/time graph to acceleration/time Introductory Physics Homework 2
