| New Reply |
Aeronautical Engineering Summer Project |
Share Thread | Thread Tools |
| May13-08, 11:32 AM | #1 |
I'm a mechanical engineering student who loves aircraft. I want to work on a project this summer so I'll learn more about aircraft/aeronautical engineering.
I have a few ideas so far. Here's just a few off the top of my head for now; Design, build, and test a jet engine Study aircraft icing, maybe perform some wind tunnel tests Examine the design of an aircraft wing, and look at designing an improvement. Design an aircraft and build and test it in X-Plane I know some of those ideas will cost a bit, but if I think it's worth it, I'm willing to spend a little bit. I might be able to get my college to pay for things too, if I can convince them it's worth it. I haven't yet covered fluid dynamics in college, but I'll learn as I go along. Something involving aerodynamics definitely appeals to me. I'd like to hear your ideas and suggestions. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| May14-08, 11:52 AM | #2 |
Hi, designing and building model jet turbines can be hellishly complicated, and expensive. I'd say you definately need an advanced knowledge of solid and fluid mechanics/dynamics to build one. I've looked into it before myself, and found these things out.
| May14-08, 03:50 PM | #3 |
How about design, build, and fly your own custom R/C plane? maybe look into more "exotic" designs like v-tails, delta wings, or even flying wings... There are many interesting things that can be done with propulsion without getting into jet engines also, like pusher fans or ducted fans.
Could be a good experience in design of aerodynamic surfaces, power/weight ratios, COG, and control systems. You could probably complete the entire thing for $500-1000, including controller and electrical components on the plane itself. |
| May17-08, 02:38 PM | #4 |
Aeronautical Engineering Summer ProjectI'd really appreciate if someone could recommend good resources and books on aircraft design. Thanks |
| May22-08, 03:12 PM | #5 |
Sorry about the double post, I can't edit my previous one.
I've just had a quick look for books that could help. I'll be able to start the project properly after next week. I couldn't find any specifically for RC aircraft, but I didn't really expect to. I found a few reputable books; Aircraft Design: A Conceptual Approach - Dan Raymer Synthesis of Subsonic Airplane Design - Torenbeek Series of books on aircraft design by Roskam Has anybody used any of these books, and what your opinions on them. I'm looking to buy one of them, so I want to make sure it's worth it. Please recommend any other resources/books which you think will be useful. |
| Jun6-08, 05:43 PM | #6 |
Would be also interisting to use some computerīs help. Something like SolidWorks or ansys. Booth can be really helpful.
| Jun6-08, 06:36 PM | #7 |
One idea that i have never tried, but you might look into, stems from an older encyclopedia with a picture diagram of airflow over a stationary tube, the air breaks even as it flows past the tube, but if the tube is set in motion in a turning action, the air, due to friction will divide with the greater amount of flow moving over the tube in the direction of rotation. If the leading edge of a wing had an active turning surface it might produce a benefit to the airfoil design. (just a thought) maybe it has been tried already.
| Jun7-08, 07:01 PM | #8 |
Crawl, walk, then then run. You need to study the fundamentals of fluid dynamics first. I'd say save your time and your money on these projects. You're not going to get anything technical out of it.
| Aug27-10, 09:24 AM | #9 |
hi,
your ideas are the basic thoughts that crosses every aeronautics student,but its implementation needs more than just basic knowledge on subject. but i can help u in designing a wing.If u know software such as catia ,ansys then u won't be needing a wind tunnel and with the idea of cfd u can design almost anything and stimulate everything.I am not familiar with catiaV5 so if u know ay of the cfd stimulating softwares please do mail me.Presently i am working in synthesing a different kind wind energy, a design similar to Savonius and Darrieus vertical axis wind turbines (VAWTs) to increase it efficiency ,can u help me with gearing ,bearing attachments with its shaft to generate power |
| Aug27-10, 09:27 AM | #10 |
| Aug27-10, 09:49 AM | #11 |
| Sep3-10, 08:31 AM | #12 |
not good answered
| Sep3-10, 11:49 AM | #13 |
that would give you all the stuff you need to get started, with a proven fly-able plane, then you can experiment with design changes, or build a new airframe, with the experience of how to fly it already under your belt good luck dr |
| Sep3-10, 11:56 AM | #14 |
| Sep9-10, 10:18 PM | #15 |
| Nov9-10, 08:27 AM | #16 |
What's the status? Were you able to make the project work? :)
| New Reply |
| Thread Tools | |
Similar Threads for: Aeronautical Engineering Summer Project
| Thread | Forum | Replies | ||
| Aeronautical or Mechanical Engineering? | Academic Guidance | 10 | ||
| Aerospace / aeronautical engineering | Academic Guidance | 3 | ||
| CalTech and Aeronautical Engineering | Academic Guidance | 3 | ||
| Aeronautical and astronautical Engineering | Aerospace Engineering | 6 | ||
| Aeronautical Engineering and Universities | General Engineering | 5 | ||
