Advantage of frequency domain analysis?
The discussion centers on the advantages of frequency domain analysis compared to time domain analysis, particularly in the context of signal processing and system stability. Participants explore the reasons for using Fourier transforms and the implications of analyzing signals in different domains.
  • Some participants suggest that frequency domain analysis allows for techniques that can determine system stability and transient responses, which may not be as easily analyzed in the time domain.
  • Others argue that time domain analysis provides more information, questioning the necessity of converting to frequency domain.
  • A participant mentions that certain circuit responses, such as skin effect losses in coax cables, cannot be accurately represented in the Laplace domain.
  • One participant provides a practical example of using frequency domain analysis to identify engine detonation through recorded signals, highlighting the clarity it provides in distinguishing different sound frequencies.
  • Another participant notes that the choice between time and frequency domains often depends on the specific needs of the analysis and the available equipment.
  • There is a mention of the historical context of frequency domain analysis being more convenient for certain engineering applications, particularly in audio and TV signal processing.
  • Some participants express that while frequency domain analysis simplifies the mathematics of circuit behavior, the phase response can be significant and is sometimes overlooked.
  • A later reply introduces a question about the Laplace transform, seeking clarification on its purpose and the transition from time to frequency variables.
Participants express differing views on the advantages of frequency domain analysis versus time domain analysis, with no consensus reached. Some advocate for the frequency domain's utility in specific contexts, while others emphasize the richness of information available in the time domain.
Participants acknowledge that both domains can fully describe signals, but the choice of domain may depend on practical considerations and the specific characteristics of the signals being analyzed.
learner07
hello,
i am new here and this is my first post so please bear with me for any mistakes or so..
now my question is about time domain analysis and frequency domain analysis .
why should one convert from time domain into frequency domain by using Fourier transform ? and what are the advantages of frequency domain analysis?
Is this homework?
no i m interested to know why do u we actually deal with frequency domain a lot...rather time domain which furnishes more information ?
please help me out i am new to this subject and want to learn it clearly..?
Frequency domain allows for techniques which could be used to determine the stability of the system. Also, these techniques can be use in conjunction with the S-domain (Laplace transform) which gives more insight to the stability of the system, transient response, and steady state response.
learner07 said:
...time domain which furnishes more information ?
I wouldn't say this is the case.
The time domain response of some circuits cannot be represented by Laplace functions. One example is the skin effect losses in coax cables, because the loss is proportional to √f.
Can you write the Fourier transform of a square wave? Can you write the Fourier transform of a square wave and include skin effect losses in a coax cable? See my post #11 in
https://www.physicsforums.com/showthread.php?t=462924
Bob S
You should probably re-read the introduction chapter in your textbook, but maybe this example will help you on your way.
Look at this signal, y(t):
Looks pretty random, right? For example, what frequency is that signal? The truth is that, unless you have a pure sinusoidal (e.g. a tuning fork), a real signal is often made up of many frequencies. The Fourier transform is a tool that tells you which frequencies a signal consists of and to what degree (read: amplitude).
The noisy signal shown above is actually the sum of a sine wave, g(t) = sin(2πft) , and a normally distributed (a.k.a "white") noise function, n(t), with amplitude 1.7:
y(t) = g(t) + 1.7*n(t)
where the "white"-ness of n(t) means that its power is uniformly distributed across all frequencies (much like white light which consists of all colors). The frequency of g(t) is f = 100Hz. Because I've chosen the noise amplitude so that it doesn't drown out the 100Hz signal, a Fourier transform of y(t) reveals the following picture:
The signal is decomposed into it's various frequency components. Pretty cool, I'd say. If you have MATLAB available, you can copypaste this code into a m-file and hit run. Play around with the noise amplitude and see how it affects the spectral density plot.
Code:
% Power spectral estimation of noisy signal
t = 0.0:0.002:0.5;
% Sine frequency
f1 = 100;
% Noise amplitude
a = 1.7;
% Generate the sine portion of signal
g = sin(2*pi*f1*t);
% Generate a normally distributed white noise
n = a*randn(size(t));
% Add the noise to the signal to get a noisy signal
y = g + n;
% Plot the noisy signal
subplot(211), plot(t(1:50),y(1:50)),
title('Nosiy time domain signal')
% Power spectral estimation:
yfft = fft(y,256)
len = length(yfft);
pyy = yfft.*conj(yfft)/len;
f = (500./256)*(0:127);
subplot(212), plot(f,pyy(1:128)),
title('Power spectral density'),
xlabel('Frequency in Hz')
EDIT: A perhaps more practical example would be a noisy signal where the noise was of a fixed frequency (60 Hz, for example). You could then use FFT to find the culprit and then add a notch filter to remove that noise.
Here is a real life example of why to choose frequency domain over time domain.
On my Subaru late last winter, I added a turbo/intercooler and a MegaSquirt engine controller. The car ran good after some tuning but on a hot day in summer I heard the engine detonate badly. I connected my laptop's microphone to the knock sensor and recorded engine knock.
Here is the time domain signal
Here is the frequency domain of that signal - ignore the yellow signal.
And here is the frequency domain of regular engine noise
It was very obvious for me to go after the spike at 5.9 kHz to determine if the engine is experiencing detonation.
There is also a rolling display of frequency domain.
Here is the engine being reved up
and here is detonation while being reved
The cool thing about frequency domain is that you get to see all the sounds.
I think this is largely practical and historical. Either domain is sufficient to describe any signal or channel characteristic, completely, but one is often more convenient than the other. 'The Maths' was known long before the engineering realisations came along.
In the beginning, there were oscillators and there were filters made of Ls, Rs and Cs. There were also moving coil meters. The natural way to analyse circuits was in the frequency domain. The performance of audio equipment was described in terms of 'frequency response' and 'harmonic distortion' - very satisfactorily, because phase/ timing is of secondary interest, subjectively, at audio frequencies.
TV came along and the effect of a channel on pulses became very relevant. The CRO gave a time domain display of a signal but, until the '90s, temporal filtering was not convenient most filtering was with lumped components. Simple delay line filters did exist but, until DSP arrived,you couldn't make transversal filters with arbitrary characteristics anything like as easily as you could make in 'the conventional' way.
The choice of f or t domain for any particular occasion depends upon what you need to find out and what equipment you have. You need to be able to slip out of one into the other, at will, to get the best understanding of the performance or design of any system.
The simple answer: the math and intuitions about how a circuit works are often simpler in the frequency domain rather than the time domain.
I agree with you, largely. For audio and TV signals, the frequency / amplitude response is often enough to give you a good idea about performance. However, the phase response may be very relevant but it is often neglected. The power spectrum of some signals is totally inadequate (digital streams, for instance) but the time variation, as already mentioned, also can be totally confusing.
You take your pick.
Thanks for the intuition about Fourier transform i have learned something new and now got another doubt that why was laplace transform developed i have googled it and found that it is something about shaping a family of exponential and vector projections etc i couldn't get it. some simply said that it was used to make a linear differential equation to algebraic equation but i couldn't understand how the variable t(time ) went in and how the 's' variable popped out. could you guys please explain me about how this laplace transform actually works? and when u say L(1)=1/s what does that actually mean ?
  • · Replies 68 ·
  • · Replies 31 ·
13K
