C++ simpson's method -loop doesn't stop
  • Context: C/C++
  • Thread starter Thread starter ggeo1
    C++ Method
The discussion revolves around a C++ implementation of Simpson's method for numerical integration, specifically addressing an issue where the loop intended to stop based on a convergence criterion continues indefinitely. Participants explore the code structure, variable usage, and the mathematical correctness of the implementation.
  • One participant points out that the loop condition 'fabs(error-exact)>eps' is always true because the 'error' variable is not updated within the loop.
  • Another participant highlights that the for loop's condition may lead to it not executing when 'n' is 1, as the comparison involves a double, which could lead to unexpected behavior.
  • A participant suggests changing the loop condition to check 'fabs(result-exact>' instead of 'error', which allows the loop to stop correctly at a certain iteration.
  • One participant mentions that the implementation of Simpson's Rule requires 'n' to be an even integer, which is not guaranteed in the current setup.
  • Another participant shares that their Mathematica implementation of the same logic works correctly, indicating a potential issue with the C++ code rather than the algorithm itself.
  • A suggestion is made to double 'n' in each iteration instead of incrementing it by 1, which may improve convergence behavior.
  • Participants discuss the output of the modified code, noting that it still produces correct results at certain steps but continues beyond the necessary iterations.
Participants express differing views on the correct implementation of the loop and the requirements for 'n' in Simpson's method. There is no consensus on a single solution, as multiple suggestions and corrections are proposed without agreement on the best approach.
Limitations include the potential misunderstanding of how 'n' should be treated in the context of Simpson's Rule, as well as the implications of using floating-point comparisons in loop conditions. The discussion also highlights the importance of updating variables used in loop conditions to ensure proper termination.
ggeo1
c++ simpson's method --loop doesn't stop
Hello, i have done the simpson's method and it works fine.My problem is that it doesn't stop when it gives me the desired result but the loop continues for ever..
Code:
#include <iostream>
#include <cstdio>
#include <cstdlib>
#include <iomanip>
#include <cmath>
using namespace std;
double f(double x){
double y;
y=sqrt(x-0.1);
return y;
double simpson (double down,double up,int n){
    double h,sumeven,sumodd,all,result;
    h=(up-down)/n;
     sumeven=0.0;
    for (int i=1;i<=n/2.0-1.0;i++){
        sumeven+=f(down+2.0*i*h);//coefficients
    sumodd=0.0;
    for (int i=1;i<=n/2.0;i++){
     sumodd+=f(down+h*(2.0*i-1.0));//coefficients
    all=4*sumodd+2*sumeven;
    result=(h/3.0)*(f(down)+f(up)+all);
    return result;
int main()
    double eps=1e-6;//accuracy
    double exact=1.1767695;//exact solution for the integral
    double error=1.0;
    double result;
    int n=1;//initial point
    result=simpson(1.0,2.0,n);
    while (fabs(error-exact)>eps) {
        cout <<"\nFor n = "<<n<<",error = "<<fabs(error-exact)<<",value = "<<result;
    n++;
    return 0;
I have done other methods too like that and they stop,but this one not.
Thanks!
Technology news on Phys.org
In your main function, you define
Code:
    double error=1.0;
but then in your while-loop you don't change any of those variables, so the condition 'fabs(error-exact)>eps' is always true.
This loop looks flaky to me.
Code:
In the first iteration of the while loop in main, n is 1, so the test expression in the for loop above is false, so the for loop doesn't execute.
When n == 1, n/2.0 - 1.0 is 0.5 - 1.0 == -.5, and i <= -.5 is false. You should not have to compare the counter in the for loop (i) with a double.
Hello,you are right but
if i do :
Code:
    while (fabs(result-exact)>eps) {
        cout <<"\nFor n = "<<n<<",error = "<<fabs(result-exact)<<",value = "<<result;
    n++;
then the loop stops at step n=8 ,but the problem is that at step n=2 it gives me the right solution and then goes over again.
Ok, i changed the for loops : for (int i=1;i<=n/2-1;i++)
for (int i=1;i<=n/2;i++)
(it was a mistake ,i didn't want to insert double values in the loops!)
But now again , it gives me the exit as a say above..
I think that you are not using Simpson's Rule correctly. Each time you call simpson(), the 3rd argument should be an even integer.
In each iteration of Simpson's Rule the interval [a, b] should be broken up into an even number of subintervals.
I used the same code in mathematica and it works fine.It gives me the right answer after 2 iterations.The same is happening here but it continues to step 8.(it gives me the right result every "even" steps)..
Instead of incrementing n by 1 in each while loop iteration, try doubling n each time.
So instead of doing this: n++;
Do this: n *= 2;
See if that makes a difference.
You've changed your code since the first post. Can you show us what you have now?
Also, it would help to see the exact output.
Here is my code :
Code:
#include <iostream>
#include <cstdio>
#include <cstdlib>
#include <iomanip>
#include <cmath>
double f(double x){
double y;
y=sqrt(x-0.1);
return y;
    h=(up-down)/n;
     sumeven=0.0;
    for (int i=1;i<=n/2-1;i++){
    sumodd=0.0;
    for (int i=1;i<=n/2;i++){
    return result;
int main()
    double error=1.0;
    double result;
    n++;
    return 0;
and the exit is :
For n = 1,error = 0.401073,value = 0.775696
For n = 2,error = 0.000110833,value = 1.17666
For n = 3,error = 0.424624,value = 0.752146
For n = 4,error = 8.23034e-06,value = 1.17676
For n = 5,error = 0.263326,value = 0.913444
For n = 6,error = 1.67268e-06,value = 1.17677
For n = 7,error = 0.190651,value = 0.986119
For n = 8,error = 5.17684e-07,value = 1.17677
If i use n*=2 instead of n++ ,it gives :
which is the same but with step 2 of course.
  • · Replies 36 ·
  • · Replies 17 ·
  • · Replies 39 ·
13K
  • · Replies 22 ·
  • · Replies 35 ·
