| New Reply |
Japan Earthquake: nuclear plants |
Share Thread |
| Mar11-11, 06:50 PM | #1 |
Does anyone have any reliable info on the nuclear plants - the reports on the news seem garbled to me.
Edit by Borek: To All: Please stick to technical aspects and to things happening at the Fukushima Daiichi NPP. There are several other threads discussing different aspects of the disaster: Why is Fukushima nuclear crisis so threatening? Fukushima radiation detection and measurement The "more political thread" besides "Japan Earthquake: nuclear plants" scientific one Japan earthquake - contamination & consequences outside Fukushima NPP |
| Mar11-11, 07:11 PM | #2 |
Admin
Unless one has direct contact from someone in the plant, the best one can do is the releases by TEPCO or METI, but METI is probably getting it second hand. I haven't seen any official releases from METI though.
TEPCO press releases http://www.tepco.co.jp/en/index-e.html http://www.tepco.co.jp/en/press/corp...1031103-e.html http://www.tepco.co.jp/en/press/corp...1031104-e.html WNN - http://www.world-nuclear-news.org/RS...n_1103111.html IAEA - http://www.iaea.org/newscenter/news/...amiupdate.html WANO is behind the curve. I have not found any direct press release from METI, but Fukushima reactor pressure may have hit 2.1 times capacity: METI http://www.reuters.com/article/2011/...72A7DB20110311 Woah - not good. That's a big NO-NO. Problems at a second unit TEPCO: loses control of pressure at 2nd nuclear plant http://www.reuters.com/article/2011/...72A8GM20110311 If this is true, I can see a lot of managers getting sacked. And there is this AP article on Yahoo - http://finance.yahoo.com/news/Japan-...20057.html?x=0 |
| Mar11-11, 08:05 PM | #3 |
Is there any real chance at a meltdown or is that just the typical media hype?
| Mar11-11, 08:15 PM | #4 |
Admin
At the moment, I don't see a 'real' chance of a meltdown. It is a worst case scenario, which is what licensing space is all about.
Some of the worst case scenarios involve extraordinary, and not necessarily physical real situations. It's a bit like crash testing a car by dropping it out of an airplane at several thousand feet, knowing full well that such a car would never be able to achieve such a velocity on level ground since the engine could not achieve the speed or the tires would blow out well before the speed could be achieved. Some in the media will sensationalize the situation in order to grab the audience in order to sell commercials for useless stuff. But I digress. ![]() I'd like to keep the discussion here on the technical aspects - as soon as we learn from reliable sources. We have the earthquake thread in P&WA. |
| Mar11-11, 08:57 PM | #5 |
| Mar11-11, 09:19 PM | #6 |
Admin
They might airlift some generators, but I have not heard any details. A light water reactor (LWR) uses water coolant under pressure to both moderate the neutrons and cool the nuclear fuel. The Fukushima units are boiling water reactors (BWRs), in which the water is boiled in the core at a pressure of ~1055 psia at Tsat ~ 286 C. The steam is sent directly to a high pressure turbine, and then the exhaust of the high pressure turbine feeds a set of low pressure turbines. The units are about 33% efficient, so about 67% of the heat is rejected through condensers to the environment, which at Fukushima is the sea. When the reactor shutdowns, there is still some heat being generated from the decaying fission products. "At the moment of reactor shutdown, decay heat will be about 7% of the previous core power if the reactor has had a long and steady power history. About 1 hour after shutdown, the decay heat will be about 1.5% of the previous core power. After a day, the decay heat falls to 0.4%, and after a week it will be only 0.2%." Ref: http://en.wikipedia.org/wiki/Decay_h...rs_in_shutdown So it is important to cool the reactor for several days following shutdown. 5.4.6 REACTOR CORE ISOLATION COOLING SYSTEM (BWR) |
| Mar11-11, 09:35 PM | #7 |
Ok. Thank you for all of the information. Hopefully they can get the problems resolved soon.
| Mar11-11, 10:41 PM | #8 |
So the coolant system was knocked out, can't they scram the reactor?
| Mar11-11, 11:33 PM | #9 |
| Mar12-11, 12:07 AM | #10 |
So it's already off and wont explode? Cool, thanks.
| Mar12-11, 03:33 AM | #11 |
It looks like the containment building has exploded. My educated guess is, what they feared might happen at TMI has happened here. The core melted down, releasing lots of hydrogen gas in the chemical reaction with the cladding, which then ignited.
| Mar12-11, 04:41 AM | #12 |
Is it safe to assume the winds go towards the Pacific Ocean at the site? In case of an exposed meltdown?
| Mar12-11, 05:45 AM | #13 |
Admin
At the time of the explosion, the wind was apparently moving toward the northeast, so any vapor would be carried out to sea.
However, I understand that the building where the explosion has occurred is not associated with containment, but I have not been able to verify this. From World Nuclear News - http://www.world-nuclear-news.org/RS...s_1203111.html and |
| Mar12-11, 06:09 AM | #14 |
Caveat: my Japanese is not so great, so I may have misunderstood some of it. EDIT: after checking online, looks like I got most of it right, but it was a government official, not a TEPCO spokesperson |
| Mar12-11, 06:22 AM | #15 |
I have to say I don't understand how you can have a hydrogen explosion blowing apart the confinement building, and not the reactor vessel.
I also don't understand how you can let any pressure build up in the confinement building at the risk of rupture if it is slowly. One should prefer steam releases (even contaminated) in order to ensure the integrity of the confinement building if ever the reactor vessel breaks, no ? Now we are not very far from a full release of the core in the environment. |
| Mar12-11, 06:30 AM | #16 |
Recognitions:
I tried to consult the japanese dose rate surveillance site, but it appears they don't have information for the northern prefectures:
http://www.bousai.ne.jp/eng/ I don't know how they transmit their measurements, supposedly via internet. Did the internet break down completely in the northern part of japan? |
| Mar12-11, 06:32 AM | #17 |
Admin
See this article - http://mdn.mainichi.jp/mdnnews/news/...dm073000c.html If the containment is breached with an uncooled reactor, that is very serious. I have heard that Chief Cabinet Secretary Yukio Edano mentioned cooling unit 1 with seawater, but I don't know where he is getting the information. Cooling directly with seawater would be a drastic step. The news from the area is rather sketchy. |
| New Reply |
| Tags |
| japan, nuclear |
Similar discussions for: Japan Earthquake: nuclear plants
| Thread | Forum | Replies | ||
| 8.9 earthquake in Japan: tsunami warnings | Current Events | 671 | ||
| New Nuclear Plants | Nuclear Engineering | 9 | ||
| Gen IV Nuclear Plants | Nuclear Engineering | 10 | ||
| New Nuclear Plants | Nuclear Engineering | 14 | ||
| Astronomer Predicts Major Earthquake for Japan | General Discussion | 65 | ||
