Why the plane of the rings is vertical to the rotation axis of Saturn?
The discussion centers on the orientation of Saturn's rings in relation to its rotation axis, exploring why the rings are positioned vertically to this axis. Participants consider various aspects of planetary formation, the nature of accretion discs, and gravitational influences on ring stability. The conversation includes theoretical implications and comparisons to other celestial bodies.
  • One participant questions whether the vertical alignment of Saturn's rings is coincidental, drawing parallels with the orbital planes of planets and galaxies.
  • Another participant suggests that the material for the rings likely originated from accretion discs, but seeks clarification on why the plane of the rings is vertical to the rotation axis.
  • Concerns are raised about the gravitational effects of a planet's rotation, which may pull ring particles toward the equator, potentially explaining the vertical alignment.
  • Some participants propose that while rings can form in various orientations, those not aligned with the rotation axis would be unstable and likely disintegrate quickly.
  • One participant mentions the Phoebe ring of Saturn as an example of a ring that may not conform to the typical alignment, suggesting that variations exist.
Participants express differing views on the stability of rings not aligned with the rotation axis, with some arguing that such configurations are possible but unstable, while others emphasize the likelihood of rings forming in alignment with the rotation axis. The discussion remains unresolved regarding the exact reasons for the vertical orientation of Saturn's rings.
Participants acknowledge the influence of gravitational forces and rotational dynamics on ring formation, but the discussion does not resolve the underlying assumptions or the mathematical details involved in these processes.
This discussion may be of interest to those studying planetary formation, celestial mechanics, or the dynamics of ring systems in astrophysics.
Chris2MIT
I don't think this is a coincidence, because the orbits of the 8 planets in our Solar System is roughly in a plane, and some galaxies are like a plate, so does the accretion plane of the black hole. But as we know, satellites rotating around the Earth can go in the orbit whose rotation axis is not coincide to that of the earth. So why couldn't the rings tilted at an angle to the rotation axis of Saturn?
Therefore, I guess that: Is the phenomenon of Saturn's rings indicates that suppose we do nothing to the Earth's satellites, they will all end up rotating Earth in a plane vertical to the rotation axis of earth?
P.S.:
Now I can understand and imagine why the ring appears like a plant instead of some other shape, but this problem remains to be solved.
I am a Chinese student, and I don't know if I had described my questions clearly. It would be great if you can also offer some suggestions about my English.
And finally, thank you very much.
Astronomy news on Phys.org
Planets are believed to form from accretion discs. The obvious explanation is the source material of rings originated in these accretion discs.
That's true. Rings and accretions are sure to form. But what I want to know is that why the plane is vertical to the rotation axis? Can it not be vertical?
I think it would be hard. The rotation creates a bulge which will pull particles toward the equator.
The disc is a disc! All the matter that becomes the planet and the rings is rotating about the same axis before it forms.
I think your words can only explain why ring appears. Why can't it be like this in my attachment?
"The rotation creates a bulge which will pull particles toward the equator."
Well, could you say my theory is wrong?
And can you explain why?
When a planet is rotating it's equator will be slightly larger than the pole - pole circumference is. Unless the rings are closely aligned with the rotation and hence the equator, the areas of the ring near the equator experience a greater pull from gravity than they do elsewhere. This creates instability in the rings and would most likely cause them to come apart very quickly.
I would say that it is entirely POSSIBLE that rings can form like your example has them. A moon or collection of other orbiting bodies that were broken up somehow into tiny pieces could have been orbiting differently than they normally do. However the rings would be unstable and would not last long at all. It is simply much more likely that rings will form in the same axis as the rotation for the reasons mentioned in the above posts.
Such as Saturn's Phoebe ring, if you count it as a ring.
Thanks, I think your words helped me a lot. You are very possibly right.
  • · Replies 16 ·
  • · Replies 27 ·
