| New Reply |
Covariant and Contravariant Tensors |
Share Thread | Thread Tools |
| Jun15-11, 11:28 AM | #1 |
Hey everyone, I am reading a Schaum's Outline on Tensor Calculus and came to something I can't seem to understand. I'm admittedly young to be reading this but so far I've understood everything except this. My question is: what is the difference between a contravariant tensor and a covariant tensor, and what do these terms mean conceptually? I've gone online and searched a variety of articles with no luck. I appreciate it, thanks in advance.
| Jun15-11, 11:45 AM | #2 |
First, there are covariant and contravariant vectors. A multilinear function acting on covariant vectors is a contravariant tensor. A multilinear function acting on contravariant vectors is a covariant tensor. A multilinear function which acts on both is a mixed tensor.
| Jun15-11, 12:07 PM | #3 |
Adding to what dx has said, a particular system/structure of tensors is defined with respect to a particular vector space. Vectors of this vector space are called contravariant vectors. Vectors of its dual space (i.e. scalar-valued linear functions of one vector each) are called covariant vectors (or covectors, dual vectors, linear functionals, etc.). As such, covariant vectors are the simplest kind of covariant tensor.
Similarly, contravariant vectors can be thought of as scalar-valued linear functions of one covariant vector each, with the following definition: If w is a covariant vector, and v a contravariant vector, then v(w) is defined as w(v). Thus contravariant vectors (often called simply "vectors") are the simplest kind of contravariant tensor. |
| Jun15-11, 07:36 PM | #4 |
Ok I think I'm starting to understand this, thanks guys. So what would be some typical examples of contravariant and covariant vectors?
| Jun15-11, 07:43 PM | #5 |
The gradient would be a pretty good example of a covariant vector (although if you know the formalism of differential forms you could just use the more modern definition of a covariant vector as a one - form which actually makes more sense intuitively) and there are countless examples of contravariant vectors (or simply vectors) but in keeping with the previous example, one example of a contravariant vector is the directional derivative along a curve. Evaluated at some point p, this type of vector can form a basis for the tangent vector space that Rasalhague talked about. The gradient then, at that point, can form a basis for the cotangent space (this is all to some manifold).
| Jun15-11, 07:49 PM | #6 |
Ok I can visualize that without trouble, thanks WannabeNewton :)
Yeah as far as I can see this book doesn't cover the modern definition of the one-form, though I do believe I've heard of that, maybe that'd clear things up a bit too.. |
| Jun15-11, 07:49 PM | #7 |
Recognitions:
I never know which is which, but you can think of contravariant and covariant vectors as row and column vectors. By matrix multiplication, a row vector can be thought of as a function that takes column vectors as input and produces a number as an output.
| Jun15-11, 07:57 PM | #8 |
| Jun15-11, 09:18 PM | #9 |
| Jun15-11, 09:18 PM | #10 |
| Jun16-11, 02:35 AM | #12 |
The terminology does seem deceptive. The principle of covariance is that 2 different views or perspectives of the same phenomenon should be symmetric or inversely related to one another. Ideally the term covariant tensor would have been used for the pair of tensors which are together covariant concerning a particular phenomenon.
| Jun16-11, 11:31 PM | #13 |
Thanks Fredrik, yeah so many terms to understand.. that's great to have them all lined up in a single post :)
I see, so if covariance is symmetrical or inversely symmetrical, what would contravariance be? |
| Jun16-11, 11:52 PM | #14 |
Recognitions:
Or if we are allowed to change definitions mid-sentence, both covariant and contravariant vectors transform covariantly:P OK, to be more serious, let's imagine we have a 2D surface covered by coordinates (x,y). Imagine that each point has a different temperature f(x,y). A vehicle, carrying a clock which reads time t moves across the surface making a curve (x(t),y(t)). The variation in temperature versus time that the vehicle experiences is df/dt which is just one dimensional calculus. At a point p, df/dt=df/dx.dx/dt+df/dy.dy.dt, a scalar which we can rewrite as a a row vector (df/dx,df/dy) multiplied by a column vector (dx/dt,dy/dt), with all derivatives evaluated at p. The column vector or contravariant vector is something like the velocity, and the row vector or covariant vector is something like the gradient of the temperature. We don't conceive of the velocity at that point as belonging to only one curve, since many curves can have the same velocity at that point. We also conceive of the velocity of any particular curve being the same under a change of coordinates from (x,y) to (U(x,y),V(x,y)). The same temperature variation is now described by f(U,V), and the same path is now described by (U(t),V(t)). So the new column vector representing the same velocity will be (dU/dt,dV/dt)=(dU/dx.dx/dt+dU/dy.dy/dt,dV/dx.dx.dt+dV/dy.dy/dt), which is how the coordinate representation of a contravariant vector transforms. Similarly, the new row vector representing the same gradient will be (df/dU,df/dV)=(df/dx.dx/dU+df/dy.dy/dU,df/dx.dx/dV+df/dy.dy/dV), which is how the coordinate representation of a covariant vector transforms. df/dt=df/dU.dU/dt+df/dV.dV/dt remains unchanged. Something to keep in mind for later, when the metric is introduced: at this stage, we can multiply row and column vectors, but we haven't defined what it means to "multiply" column vectors, which is a job the metric can do. |
| Jun17-11, 03:49 PM | #15 |
| Dec31-11, 11:08 AM | #16 |
1) I understand the diff between co variant and contra variant coordinate system but not sure why velocity is considered contra where as grad is considered "co"variant. What does that have to do with how we lay out coordinate system? 2) Why do we always write covariant basis for contra variant components? |
| Dec31-11, 05:29 PM | #17 |
Mentor
| New Reply |
| Thread Tools | |
Similar Threads for: Covariant and Contravariant Tensors
| Thread | Forum | Replies | ||
| Covariant and Contravariant Tensors | Differential Geometry | 2 | ||
| Covariant & contravariant tensors | Calculus & Beyond Homework | 1 | ||
| Covariant and Contravariant Rank-2 Tensors | Differential Geometry | 2 | ||
| covariant vs. contravariant | Special & General Relativity | 6 | ||
| covariant and contravariant ? | General Physics | 15 | ||
