| New Reply |
Calculating Nitrogen percentage in food products. |
Share Thread | Thread Tools |
| Jun22-11, 10:33 PM | #1 |
I just thought I would ask some people's opinions about this as I am stuck on what to do.
I am currently working for a food manufacturing company that pack their food with nitrogen gas to increase shelf life. However they have an acceptable limit of how much nitrogen can be within the product. Recently they have had some products that have come close to breaching this limit. The trouble is they do not know why every so often one item does. I took 100 samples of the products with two various nitrogen flow rates and it turns out that the deviation in the results of a higher flow rate is quite less then compared to the ones with a lower flow rate. However there still is the one or two randomly high values. The flow rates i tested were 16 and 14 m^3 / h with a pressure of about 3 bar. I am really stuck on what it could be. Does any one have any ideas? |
| Jun23-11, 03:25 PM | #2 |
Recognitions:
Off hand I would suggest a careful study of the equipment being used.
| Jun23-11, 03:50 PM | #3 |
Try getting the maintenance dept. to check for pipe blockages or obstructions, we have had this with some lines in the workshop recently
| Jun23-11, 10:02 PM | #4 |
Are you guys using 100% nitrogen or a mixture of different gases?
Also, what do you mean by "how much nitrogen within the product"? The amount that gets absorbed by the food? The amount in the packaging? |
| Jun26-11, 05:21 PM | #5 |
it is a test of how much is in the packaging, we measure the oxygen percentage in the pack by putting a prob with a seal through the package |
| Jun26-11, 05:23 PM | #6 |
| Jun26-11, 05:27 PM | #7 |
I have decided my next cause of action is to find out whether the packages have holes in them and this is the cause or to see whether the product has defects which are entrapping oxygen and then braking whilst within the packaging, releasing the oxygen.
What do you think, are these possible causes? |
| Jun27-11, 12:28 AM | #8 |
I really don't know, but it sounds like you are either getting too much flow rate or the process is going on for slightly too long, causing more nitrogen to build up. A leak wouldn't let ONLY the oxygen out.
| New Reply |
| Tags |
| flow rate, food, manufacturing, nitrogen, process |
| Thread Tools | |
Similar Threads for: Calculating Nitrogen percentage in food products.
| Thread | Forum | Replies | ||
| Calculating the corresponding percentage | Introductory Physics Homework | 1 | ||
| Calculate the percentage of nitrogen in air | Biology, Chemistry & Other Homework | 9 | ||
| Chemistry and Food Products | Chemistry | 3 | ||
| Calculating percentage yield lab..i really need help? | Biology, Chemistry & Other Homework | 1 | ||
| Calculating the percentage difference. | Introductory Physics Homework | 2 | ||
