| New Reply |
derivative of the pi function |
Share Thread | Thread Tools |
| Aug6-11, 02:10 AM | #1 |
What is the derivative of the pi function
| Aug6-11, 02:27 AM | #2 |
If you are talking about the prime number thing, I am not sure about the exact one but here is an approximation:
[tex]\pi(n)\approx \int_{2}^{n}\frac{dt}{\mbox{ln}(t)}[/tex] [tex]\frac{d}{dn}\pi(n)\approx \frac{d}{dn}\int_{2}^{n}\frac{dt}{\mbox{ln}(t)}[/tex] [tex]\frac{d}{dn}\pi(n)\approx \frac{d}{dn}\lim_{\delta t \rightarrow 0}\sum_{t=2}^{n}\frac{\delta t}{\mbox{ln}(t)}[/tex] As the derivative of a sum is the sum of the derivatives, [tex]\frac{d}{dn}\pi(n)\approx \lim_{\delta t \rightarrow 0}\sum_{t=2}^{n}\frac{d}{dn}\frac{\delta t}{\mbox{ln}(t)}[/tex] [tex]\frac{d}{dn}\pi(n)\approx \lim_{\delta t \rightarrow 0}\sum_{t=2}^{n}-\frac{\delta t}{n \; {\mbox{ln}}^{2}(n)}[/tex] [tex]\frac{d}{dn}\pi(n)\approx - \int_{2}^{n}\frac{dt}{n \; {\mbox{ln}}^{2}(n)} [/tex] So that is the approximate rate of change of the pi function of t as t changes. |
| Aug6-11, 10:55 AM | #3 |
Recognitions:
This is not quite right.
The proper derivative is: [tex]\frac{d}{dn}\pi(n)\approx \frac{d}{dn}\int_{2}^{n}\frac{dt}{\ln(t)} = \frac{1}{\ln(n)}[/tex] |
| Aug6-11, 07:29 PM | #4 |
| Aug6-11, 07:38 PM | #5 |
According to Wolfram Alpha,
[tex] \frac{d}{dn}(\int_{2}^{n}\frac{dt}{\ln(t)})=\frac{-n+n\; \mbox{ln}(n)+2}{n \;{\mbox{ln}}^{2}(n)}[/tex] that is, [tex] {\mbox{ln}}^{-1}(n)+(2{n}^{-1}{\mbox{ln}}^{-2}(n))-{\mbox{ln}}^{-2}(n)[/tex] But for Li(n) alone, it gives [tex]{\mbox{ln}}^{-1}(n)[/tex] which is your solution. And my solution gives [tex]- \int_{2}^{n}\frac{dt}{n \; {\mbox{ln}}^{2}(n)}[/tex] which is equal to [tex]\frac{n-2}{n\; {\mbox{ln}}^{2}(n)}[/tex] I guess all three solutions are equal to each other and thus, correct? |
| Aug6-11, 11:06 PM | #6 |
[tex]\frac{d}{dn}\pi(n)\approx \lim_{\delta t \rightarrow 0}\sum_{t=2}^{n}\frac{d}{dn}\frac{\delta t}{\mbox{ln}(t)}[/tex] The derivative operator [tex]\frac{d}{dn}[/tex] should operate on the sum. I am not even sure what it means to have delta t inside a sum where t is a dumby variable, and then taking a limit of it as it approaches zero, the notation here is quite problematic. |
| Aug7-11, 03:36 AM | #7 |
Recognitions:
This is not allowed, because the summation is dependent on n. You made another mistake when you differentiated the expression dependent on t with respect to n. Since the expression is not dependent on n, the result is zero. I do not get that. |
| Aug10-11, 04:51 AM | #8 |
I think I know what happened. It must have again considered d as constant rather than an infinitesimal.There seems to be a simpler solution using the second fundamental theorem of calculus and that would yield [tex]\frac{1}{\mbox{ln}(n)}[/tex] which is the answer given by you. |
| Aug31-11, 10:28 AM | #9 |
the derivative of the prime counting function is just the sum
[tex] \delta (x-p) [/tex] taken over all primes 'p' |
| Aug31-11, 07:21 PM | #10 |
I am confused; pi is a step function and is therefore only differentiable at the "interior" of a step at which point it is 0.
| Sep8-11, 10:32 AM | #11 |
yes but since the step function is discontinous delta function appear whenever the function has discontinuties, in the case of Pi function the discontinuities are located at the prime numbers
| New Reply |
| Thread Tools | |
Similar Threads for: derivative of the pi function
| Thread | Forum | Replies | ||
| prove that derivative of the theta function is the dirac delta function | Advanced Physics Homework | 3 | ||
| find derivative of floor function using limit definition of derivative? | Calculus & Beyond Homework | 10 | ||
| function --- derivative (help!) | Calculus & Beyond Homework | 2 | ||
| First & Second derivative of a function | Calculus & Beyond Homework | 5 | ||
| derivative of function | Calculus & Beyond Homework | 5 | ||
