Wormholes - A way to violate energy conservation?
The discussion revolves around the implications of wormholes on the conservation of energy, particularly whether a particle traversing a wormhole can gain energy without violating conservation laws. Participants explore theoretical scenarios involving charged objects and gravitational fields, as well as speculative ideas about communication in science fiction contexts.
  • One participant proposes that a particle could lose potential energy while being attracted to a charged object and then regain energy by traveling through a wormhole, suggesting this might violate conservation of energy.
  • Another participant argues that the electrostatic field is conservative, indicating that any change in potential energy must be accounted for within the wormhole, which would require work to traverse.
  • A different viewpoint expresses skepticism about the claim that general relativity prohibits discontinuities in the metric, suggesting that the reasoning presented does not necessarily follow from Einstein's field equations.
  • One participant suspects that maintaining a stable wormhole would require a significant amount of energy, which would need to be considered in the overall energy balance of the system.
  • Another participant speculates on the possibility of wormhole mouths acquiring negative mass, suggesting that energy could be redistributed among the wormhole mouths and the moving object.
  • In a side discussion, participants explore how science fiction addresses the challenge of interstellar communication, with ideas ranging from using wormholes to send electromagnetic waves to hypothetical concepts like subspace communication.
Participants express differing views on the implications of wormholes for energy conservation, with no consensus reached on whether the scenarios presented are valid or if they adhere to established physical principles. The discussion remains unresolved regarding the theoretical underpinnings of these claims.
Participants acknowledge the complexity of the issues at hand, including the assumptions about energy requirements for wormhole stability and the nature of fields within wormholes. The discussion reflects a range of interpretations of general relativity and energy conservation principles.
MrNerd
I'm sure someone has already thought of this somewhere, but can a wormhole violate the conservation of energy IF the object takes two paths?
I mean like this:
Imagine a wormhole near a charged object, one closer, the other farther. Then imagine the particle being attracted to the charged object(Path 1) It has now lost potential energy. BUT then it goes back away through the wormhole, a shortcut in space(Path 2). The object travels the full distance relative to an outside observer. The object travels a shrunken distance relative to itself(Doesn't it?) Would it not take less energy through the wormhole to gain back the initial potential energy? This is also not relying on gravitational acceleration, which is technically nonexistent and only curves paths. The only thing I can reasonably think of is that either wormholes are impossible, thus negating this paradox entirely, or the field is kind of 'condensed' into the wormhole passage thingie.
On an unrelated note, how has no one ever thought of an explanation in science fiction for being able to communicate with extremely distant ships and bases? The whole point of the warp drive or whatever is to get them to places that are further than light can reach in traversable time. Since em waves travel at light speed, they should probably die before the messages even reach them(depending on distance). Unless they have a permanent wormhole for the communications, or they generate one everytime they send a message and just send a communications probe thing through, this just seems completely, even in science fiction reasoning, unreasonable.
I mean like this:
The electrostatic field is conservative. This means that the potential energy of a particle depends solely on its position. The "paradox" is resolved by realizing that if a wormhole connects a weak field region with a strong field region, the field must smoothly change from weak to strong within the wormhole. The shorter the wormhole "neck", the more abruptly must this change occur.
The same "paradox" occurs for the gravitational field in presence of wormholes. You might want to check out this item in this http://www.webfilesuci.org/WormholeFAQ.html":
"Is a wormhole whose mouths are arranged vertically in a gravitational field a source of unlimited energy?
No. The argument in favor of such a wormhole being an energy source is this: An object falls from the upper mouth, gains kinetic energy as it falls, enters the lower mouth, reemerges from the upper mouth with this newly acquired kinetic energy, and repeats the cycle to gain even more kinetic energy ad infinitum. The problem with this is that general relativity does not permit discontinuities in the metric – the descriptor of the geometry of spacetime. This means that the gravitational potential of an object at the lower mouth must continuously rise within the wormhole to match the potential it had at the upper mouth. In other words, this traversal of the wormhole is “uphill” and therefore requires work. This work precisely cancels the gain in kinetic energy."
The FAQ is an excerpt of https://www.amazon.com/dp/0984150005/?tag=pfamazon01-20.
I have rather strong doubts about the accuracy of the above answer, though it is in "genuine print". So far, I haven't found anything really clear that resolves this issue in the literature.
The argument that GR "doesn't allow discontinuities in the metric doesn't seem to me to prove the point in question. I do suspect that the author of the book believes his remarks to be true, but I'm not convinced that the statements made in this FAQ follow from Einstein's field equations.
The reasons why I think the approach is wrong are a bit technical, but boil down to the fact that the only way to "thread" an electric field, or by analogy a gravitational one, is by passing a charge, or mass through it.
This is incompatible with the author's idea that it would "always be uphill" if the wormhole connected two regions of differing Newtonian gravitational potential - the author would have us believe that there must always be a field threading the wormhle in this case, it's not consistent with the idea that the only way to generate such a field is to pass an object with charge (or mass) through it.
I suspect that there is an assumption in how much energy it takes to keep a wormhole both stable and at a discrete separation. I suspect this energy will be non-trivial.
This is where the energy will come from. When the net energy of the whole system, including a working wormhole, is taken into account, it will surely respect the LCE.
I'd be willing to bet that the total ADM mass of the pair of wormhole mouths plus the "energy at infinity" of the moving object was constant. Assuming we can separate the ADM mass of the pair of wormholes into separate parts.
But it's possible for one of the wormhole mouths to acquire negative mass. So it's possilbe (and perhaps even expected_ that wormhole A gains +1 unit of mass/energy, B gains -1.1 unit of mass/energy, and the moving object C gains .1 unit for instance.
For pure story-writing purposes, having the energy come from the stabilizer is a good idea. We are a ways away yet from being able to do any experiments :-).
I'll let people smarter than I answer the question about wormholes (although my knee-jerk reaction is no) but as for interstellar communication, I have seen some forms of sifi use typically two methods.
The first is what most people would think. They just beam em waves through an active wormhole. Although this would draw a ridiculous amount of power for a simple message, it should work, at least in theory.
The second idea relies a little less on science and a little more on fiction. The writers presume that there is some sort of underlying fabric of the universe we have yet to discover dubbed subspace. Their hope in this is that by accessing this subspace, we should be able to send messages down into this area, to the predetermined point relative to space, and back into space in little to no time at all relative to both observers.
I apologize if I botched any of this, but those are the only two ways I've seen of rapid interstellar communications and, as I said, the first seems to hold more potential than the second even though the amount of energy needed to convert it to widespread use borders on the need for access to zero point energy, cold fusion, or both. :wink:
xXIHAYDOIXx said:
... as for interstellar communication, I have seen some forms of sifi use typically two methods.
Let's just stick to science, guys. There's plenty of sci-fi fora out there.
Happy to. :) Although, many advances in science did begin in, and are first explained through, fiction. I'll try to keep it a little more on the science side though.
The answer you are referring to is completely accurate. The reason this doesn't appear much in literature is because if you understand enough geometry and topology to know what a wormhole is, it's absolutely obvious how any conservative field will behave in its vicinity.
I'm afraid I don't find your answer very convincing, and I suspect that you are most likely making the error of applying ideas based on Newtonian energy conservation to the conservation of energy to general relativity, most especially if you think the answer is "obvious", and that if you think that gravity is a "conservative field". (I'm assuming that's what you meant, it'd be a bit snippy to say that the answer was obvious for any conservative field if you knew already that gravity wasn't a conservative field in the usual sense, the only way your remark would avoid being a non sequitur is if you did think gravity was a conservative field).
If you do think the answer is obvious, perhaps you can explain how it's consistent with the total flux through the wormhole is altered by a charge passing through it - to wit:
I.e. http://www.npl.washington.edu/AV/altvw69.html
Cramer said:
If a positive electric charge Q passes through a wormhole mouth, the electric lines of force radiating away from the charge must thread through the aperture of the wormhole. The net result is that the entrance wormhole mouth has lines of force radiating away from it, and the exit wormhole mouth has lines of force radiating toward it. In effect, the entrance mouth has now been given a positive electric charge Q, and the exit mouth acquires a corresponding negative charge -Q. Similarly, if a mass M passes through a wormhole mouth, the entrance mouth has its mass increased by M, and the exit mouth has its mass reduced by an amount -M.
How do you reconcile this with the idea that one direction must always be "uphill", based on some Newtonian idea of local gravitational potential (which appears to be the somewhat naive argument given in the so-called FAQ) when the argument above shows that you can change which way is "uphill" only by passing a mass through the wormhole - .i.e you can thread electric field lines through the wormhole by sending a charge through it, similarly you can thread gravitational field lines through the wormhole by sending a mass through it, changing which direction is "uphill".
The charge case is somewhat easier to deal with,so let me recap it in those terms:
Specifically, imagine a wormhole pair far far away from any other charge, set up so that there are no fields threading it.
Now, bring the wormhole pair close to a charge, so that the two ends are at different potentials.
The field line argument shows that bringing a wormhole close to a charge won't change the field in the throat, it won't make one direction "uphill", because no charge has threaded the wormhole, and that's the only way to get field lines in the throat threading the wormhole.
The field lines have to stay "hooked up", they must be continuous - if you drag a charge th rough the wormhole, the field lines come with it, and that's the one and only way to change the flux through the wormhole.
I'm using the charge argument here rather than the mass one, because it's slightly more rigorous and because it's really easy to deal with, given that electromagnetism is a two-form and we can talk rigorously about "field lines". But you can ask the same question about bringing a field-less wormhole close to a large mass.
BTW, there's lots of FAQ's and literature about the conservation of energy in GR out there, as well as some more technical expositions. I could list a few, but it seems premature, and I suspect that if you get over thinking that the answer is "obvious", you can track them down well enough yourself and you'll find it more convicing if you do the legwork.
I will mention one, however, that's helpful on a historical note rather than a technical one.
The issues with the conservation of energy in General relativity have been known since Hilbert's time, when he talked Emily Noether into investigating the problem for him. See for instance http://www.physics.ucla.edu/~cwp/articles/noether.asg/noether.html.
In the general theory, energy is not conserved locally as it is in classical field theories - Newtonian gravity, electromagnetism, hydrodynamics, etc.. Energy conservation in the general theory has been perplexing many people for decades. In the early days, Hilbert wrote about this problem as 'the failure of the energy theorem '. In a correspondence with Klein [3], he asserted that this 'failure' is a characteristic feature of the general theory, and that instead of 'proper energy theorems' one had 'improper energy theorems' in such a theory. This conjecture was clarified, quantified and proved correct by Emmy Noether.
Wow, I feel proud of myself. I thought of a question on my own that was important enough to warrant controversies of its own accord, even if it was originally thought of decades ago. I just hope I'm not acting as a sponge sobconsciously. It really sucked when I realized a tune I thought I made by myself was actually a part of Gilgamesh's theme from Final Fantasy. So it seems the main arguments are, the field goes through the wormhole as it does the outside, or the field is brought about by the presence of the charged particle already inside the wormhole.
Too bad we don't have a wormhole to experiment with(or do they...(they probably don't)). Either way, it would be neat to one day attempt to find a method to create an artificial wormhole, even if it's untraversable, resulting in ridiculous deadliness, because it would be the first. After all, an opportunity to fail is an opportunity to succeed! Ironic, being created by me, a pessimist, isn't it(the sentence, that is, I made up the saying).
Pervect, you are making an elephant out of a fly.
[tex]\partial^\mu \partial_\nu A^\rho = \mu J^\rho[/tex]
So long as J is uniquely defined, A is uniquely defined. You can substitute any differential geometry you want, the potential is still unique for given charge distribution and boundary conditions.
That's it. That's the whole discussion right there.
Actually in curved space-time, this formula isn't quite right. See for instance Wald, "General relativity", pg 71 eq 4.3.15
[tex]\nabla^a \nabla_a A_b = R^{d}{}_{b} A_{d} = -4 \pi J_{b}[/tex] where R is the Ricci tensor.
Note that we've replaced the partial derivatives [itex]\partial_a[/itex] with the covariant derivatives [itex]\nabla_a[/itex]
The important thing is that [itex]\nabla_a J^a = 0[/itex]. (Which is true for the expression above, and not true for your expression, see Wald's discussion.
Wald said:
In this instance, we can decide in favor of equation (4.3.15) over the alternative equation without the [itex]R^{d}_{b} A_{d}[/itex] term because equation (4.3.15) implies current conservation ... while the alternative equation conflicts with it.
Furthermore this equation, [itex]\nabla_a J^a = 0[/itex], sometimes called the continuity equation, is what prevents you from changing the flux through a wormhole without passing a charge through it.
The argument is clearer in the intergal form, rather than the differential form.
Consider a wormhole that has no charge on either mouth, and no charge inside it. Then if you draw a sphere, around either wormhole mouth, or anywhere in the throat, there is no flux through the sphere, no electric field.
This remains true even if you bring the wormhole close to another charge. You can't induce a flux through the throat of the
But without a flux going through the wormhole, you can't have a net change in the energy by passing through the wormhole. (You can change the flux through the throat by passing a charge through it, but that's the only way to change the flux).
So the explanation for how energy gets conserved in a wormhole is a bit trickier than postulating some sort of field threading the throat - which just can't happen according to the laws of physics.
If we assume that the wormhole is static, it doesn't get that much more complicated for the gravitational case than it does for the electric case described above, you just need to replace charge with Komar mass.
Hm... Alright. Maybe I need to take a closer look at this. Covariant derivatives taking place of ordinary derivatives does make sense intuitively, but I've never considered the consequences.
It still looks like it should reduce to something simpler, but maybe I have to add constraints, like no time-dependence and maybe no frame-dragging in the metric.
Thank you for pointing this out.
And hey, I have Wald's book right here. Going to go read.
Wald has a good chapter on energy in GR, as well. But not much on wormholes ...
As I understand it, a discontinuity in the metric would imply an infinitesimally thin, infinitely dense surface of mass-energy at the site of the discontinuity. [That is, if you put a discontinuous metric into left side of Einstein's equations, the unphysical "delta function" surface pops out of the right side.] In the absence of such an unphysical surface, a discontinuous metric could not exist. No surface ==> no discontinuity.
"'thread' an electric field"?
Bold added for emphasis.
A gravitational field does exist before any object passes through the wormhole. The wormhole meteric is the gravitational field in my understanding. [I seem to remember from Kip Thorne's book that the Newtonian scalar field is normally identified with the logarithm of g00(x).]
The red lines in the diagram below are electric field lines threading a wormhole - it's a 2d wormhole, as that's the only sort I can draw.
The electric field lines on the diagram are red. The wormhole geometry is sketched in black.
Electric field lines point in the direction of the electric field. The magnitude of the force is given by the density of the lines - double the lines per inch is twice the force.
Note that field lines threading the wormhole are the only way to have a potential difference when traveling down the wormhole. With no field lines, there is no electric force.
Remember Gauss's law. The integral of the normal electric field over a surface is equal to the enclosed charge.
Let's look at and end view of the left wormhole mouth.
Applying Gauss's law, we can see that the circle must enclose a negative charge.
Gravity isn't a simple two-form like the electromagnetic case. But if you have a static wormhole, the Komar mass is a conserved quantity, like the charge is, expressible as a surface integral (or as a volume integral) so you can use the same argument, as long as everything is static (or at least stationary).
Pervect,
The gravitational field of the wormhole itself is completely distinct from the gravitational field of a massive test particle that passes through the wormhole.
Yes, Gauss' Law does tell us that if a wormhole connecting Universe A and Universe B swallows a massive particle in Universe A, then observers in Universe A will see the wormhole acquire this mass, even after the mass has traveled light years away in Universe B from the wormhole's mouth.
This has absolutely nothing to do with the continuity of the gravitational potential within the wormhole. Continuity persists, gravity remains conservative. Travel through the wormhole from a low potential to a high potential would still be "uphill". That's my understanding, anyway.
HarryRool said:
Pervect,
I would certainly agree that the metric coefficients are continuous. I would disagree that this implies that there would be an "uphill" direction if you moved one end of a wormhole to a region of lower Newtonian potential.
A few things should be clarified, I think.
1) You mention "the potential". What potential are you talking about? Currently, I'm assuming you are basically importing the Newtonian potential into General relativity - and assuming that gravity in GR can be expressed in the same way that you are used to as the gradient of a scalar potential function. It's also possible that you mean "the metric" coefficeints by "the potential", but I don't quite see how your argument follows if we assume this is what you mean by "potential".
2) You mention that gravity "is conservative". What are you basing this on? Are you assuming that the usual Newtonian ideas, or have you read some of the FAQ's or the technical literature on how and when energy is conserved in General Relativity?
For instance the sci.physics.faq: http://www.desy.de/user/projects/Physics/Relativity/GR/energy_gr.html
The somewhat related faq here on PF https://www.physicsforums.com/showthread.php?t=506985 (the focus is on cosmology though)
Also the paper about Noether's theorem I mentioend earlier:
Or for a textbook source, Wald's general relativitiy, chapter 11 section 2
3) How do you explain away Cramer's argument given in http://www.npl.washington.edu/av/altvw69.html
It should be clear that passing charges through the wormhole can change the direction of "uphill" and "downhill" at will, which will play havoc with any attempt to say that "one direction must always be uphill".
By "gravitational potential" at a point I mean that part of the metric that most contributes to the maximum kinetic energy that a test mass would acquire (relative to the wormhole's center of mass frame) were it released from rest from that point. I believe that this usually works out to be ln(-g00)/2.
"Conservative" in this context has nothing to do with the conservation of energy. It simply means that the metric is exclusively a function of position.
The most that this effect could produce, assuming that a fantastically massive object passed through the wormhole, is to add dips or bumps in the gravitational potential that briefly counters the general trend from high potential to low or low potential to high. Kind of like a roller coaster that goes upward briefly on its way down.
HarryRool said:
By "gravitational potential" at a point I mean that part of the metric that most contributes to the maximum kinetic energy that a test mass would acquire (relative to the wormhole's center of mass frame) were it released from rest from that point. I believe that this usually works out to be ln(-g00)/2."Conservative" in this context has nothing to do with the conservation of energy. It simply means that the metric is exclusively a function of position. The most that this effect could produce, assuming that a fantastically massive object passed through the wormhole, is to add dips or bumps in the gravitational potential that briefly counters the general trend from high potential to low or low potential to high. Kind of like a roller coaster that goes upward briefly on its way down.
That argument doesn't really make any sense to me. It matches the original author's claims,but the logic chain starting from "having a continuous metric" to "having the path integral being independent of path" isn't at all clear. Personally, I don't believe it is a valid argument, even if it is in genuine print.
But let me present a related argument that does make sense to me, and show why it fails. It took some thought to see where the issue was, but it's rather interesting.
Consider the electromagnetic case. If we have an electrostatic field, we expect the line integral of E around a closed curve vanishes (i.e. assuming the magnetic flux through the curve is constant). This is why we expect the electrostatic field to be "conservative", and by conservative we really mean that the integral of the electric field along a closed path vanishes.
The usual proof of this involves Stokes theorem.
We break up a large area into small cells as below, and we can integrate [itex]\nabla \times E[/itex] in each cell, to get the line integral of E over the outside of the curve. And since we are considering the electrostatic case, [itex]\nabla \times E[/itex] = 0, therefore the integral vanishes.
The reason that this works is that all the interior terms cancel, i.e. for every left arrow in the interior, there is a right arrow, for every up arrow in the interior , there is a down arrow. Only the exterior arrows contribute to the integral.
If we're not in flat space, we have to replace[itex]\nabla \times E[/itex] with something like dF, the exterior derivative of the Faraday tensor. But the same sort of idea applies. The spatial components of dF in some flat "cell" are just equal to [itex]\nabla \times E[/itex] anyway.
This doesn't have anything to do at all with the "continuity of the metric", but it seems like a valid argument.
So, let's try to apply this argument to a wormhole.
We pick one path around the "outside" of the wormhole from A to B, and one path that goes through it, and we draw the closed curve.
Now, we start trying to picture drawing the cell diagram that we did before. But, we run into a problem. The cells fill all of space-time, there isn't any inside and outside of our closed curve, due to the topology.
And if we start drawing our cells, starting in the throat, we don't run into the exterior curve, but back into the throat again.
We expect a closed curve to have an inside, and an outside - but when we examine the topology of the wormhole case, this doesn't happen.
Studying the diagram, we can see that we can have have dF (or if you prefer [itex]\nabla \times E[/itex]) equal to zero everywhere - but it no longer implies that the integral from A to B through the throat equals the integral from A to B traveling outside the wormhole.
I had a better idea how to illustrate the problems with applying Stoke's law with a multiply connected topology.
The wormhole is topologically represented by the torus in the diagram, the same as in my line drawing sketch.
If you imagine the thick red band around the torus as representing an inside path "through a wormhole" and "around the wormhole", you can see that because of the way the topology is multiply connected, the red band doesn't divide the torus into an "inside" and an "outside" the way the circle on a plane does - and how this causes problems with the Stoke's law construction.
http://www.edforall.net/courses/29/mult_conectd_reg.pdf also has some information on the line integral in multiply connected topologies. Their conclusion : even with a zero curl, you can get non-zero line integrals around a closed curve. In general the result can depends on the topological properties of the curve (i.e. the winding numbers around the holes in the topology), and only on the topological properties of the curve.
RE: Field Potential
If we truly have a conservative field, then it should be propagated by some particles with some energy density, and thus a pressure. As we move the ends of the wormhole through this field, the pressure difference across the wormhole should drive enough of the mediating particles through the wormhole to establish equilibrium and produce the required "uphill" fields inside the wormhole.
RE: Metric
If we don't truly have a field, and are talking about topologies in the metric, then the question appears to resolve to whether one can have a closed time-like curve.
It is hard to imagine a wormhole without one, after all we could time dilate one of the ends and bring them back together.
utesfan100 said:
RE: Field Potential
RE: Metric
You can view fields as particles if you like, but that's in the context of QM. And viewing fields as being made of particles shouldn't introduce any additional phenomenon, such as "pressure".
There's a pretty good chance wormholes can become time machines, but that's not really relevant to this thread. Basically, when you have a multiply connected topology , you expect to have a multi-valued potential function. The gradient of the potential function still gives the force in any local area, but in general th ae value of the potential will depend on the winding number.
Any real field will be in the context of QM. Otherwise it is a pseudo force created by a non-Euclidean metric in GR.
The energy density of a field can be shown to be equivalent to a uniform pressure of the particles at that location. Further, the higher potential should have a higher flux of particles on an area than the lower potential.
Note: as the energy of the particles are dependent on winding number, there is some room for short term variance, but over time equilibrium should be approached.
Can you show me a multiply connected topology without closed time-like curves?
It is seems to me that his argument follows from certain contextual assumptions:
1) The wormhole is human-traversable (weak gravity)
2) The wormhole is static
3) The wormhole is not rotating
4) The wormhole is being traversed at speeds much lower than that of light
When these assumptions hold, the gravitational force reduces to the gradient of a scalar field(= ln(-g00)/2) This gradient is only defined as long as the metric is continuous. In that case, the work required to move between any two point is path-independent, i.e. a conservative situation. [Assumptions + metric continuity ==> gravity force is a gradient ==> path-independent work = conservative.]
It seems pretty clear to me that these assumptions must be in effect. Otherwise, the gravitational field is not conservative. You could imagine, for example, flying your spaceship through a rapidly rotating wormhole from high-Newtonian-gravitational-potential planet A to low-Newtonian-gravitational-potential planet B (nominally a downhill trip) in an way that goes uphill. All you'd have to do is have your spaceship spiral inward and through the wormhole in a direction counter to the wormhole's rotation.
Because you'd be traveling against the rotating wormhole's frame dragging, an arbitrarily large number of spirals (revolutions) within the wormhole would burn an arbitrarily large amount of fuel. This would turn your downhill trip to uphill.
Same with traversing at speeds close to that of light. [Then you'd have to work against velocity-dependent tidal forces.]
Same with strong gravity. [Then ln(-g00)/2 isn't a good stand in for a Newtonian-like gravitational potential (though I think that g00 itself might work)]
Same with a non-static wormhole. [Then the force on test particle doesn't look like the gradient of a component of the metric.]
Yes, the application of Stoke's theorem for paths that traverse a wormhole is a most interesting problem. I don't know what relevence that has to gravity, though. Unless your point is that EM is not in general conservative and neither is gravity (except in most cases of interest, see above). So gravity might have a similar pathology as EM with regard to wormholes.
Realize, however, that the nonconversevative aspects of gravity mentioned above, have little to do with wormholes. I pretty sure that if you pilot your ship around a Kerr black hole against its rotation, you'll use more energy than if you travel around this black hole in the same direction in which it spins. So you have path-dependent work.
But I don't think that these scenarios apply to traversals of (non-rotating) Morris-Thorne-style wormholes. Obviously, I'm not a physicist, just a physics enthusiast. But I think that this is the context of that short FAQ answer.
  • · Replies 21 ·
  • · Replies 25 ·
