Trying to make a Superconducting tube
  • Context: Graduate
  • Thread starter Thread starter TimDubya
    Superconducting Tube
The discussion revolves around the fabrication of a superconducting hollow cylinder, specifically exploring methods to create such a structure using high-temperature superconducting (HTS) powders like YBCO and BSCCO. Participants consider practical manufacturing options and the implications of different materials.
  • Exploratory, Technical explanation, Debate/contested
  • One participant is seeking advice on how to form a superconducting hollow cylinder using HTS powders, considering options like pressing or using a binder, while acknowledging potential drawbacks of the binder on superconducting properties.
  • Another participant suggests purchasing a solid cylinder of niobium or aluminum and drilling a hole, implying this could be a simpler solution.
  • A later reply reiterates the suggestion of drilling a hole in a solid cylinder, while also noting the high cost of liquid helium, which may be a consideration in the experiment.
  • Another participant recommends using a commercially available niobium tube as an alternative to fabricating a YBCO tube.
Participants present multiple competing views on the best approach to create the superconducting tube, with no consensus reached on a single method or solution.
Participants express concerns about the costs associated with both the materials and the cooling methods required for superconductivity, indicating that economic factors may influence their choices.
TimDubya
I'm doing an experiment which requires the fabrication of a superconducting hollow cylinder but I am unable to find a firm which does custom manufacturing of this nature. I have found numerous which sell the high Tc powders (YBCO BSCCO). My question is if I do just buy the powders what could I do to form my cylinder? I was thinking I could either press it into shape or add a binder of some sort. However I recognize the binder idea may diminish some properties of the HTS.
Any and all insight appreciated.
Can't you just buy a solid cylinder of niobium or aluminum and then drill a hole?
Zz.
Zz.
Liquid helium is expensive.
Yes, but so is making a tube of YBCO that manages to superconduct. I was going to recommend a niobium tube. You can buy these commercially.
  • · Replies 0 ·
