Register to reply
Rotation of a rectangular prism.
by Fusiontron
Tags: prism, rectangular, rotation
Share this thread:
Fusiontron
#1
Oct27-11, 10:20 AM
P: 90
For some reason it is impossible for a rectangular prism to have pure rotation along one of its axises. For example, if you throw a hardback book in the air and try to spin it about its width then there is some distortion. What is the explanation for this?
Phys.Org News Partner Physics news on Phys.org
Engineers develop new sensor to detect tiny individual nanoparticles
Tiny particles have big potential in debate over nuclear proliferation
Ray tracing and beyond
phinds
#2
Oct27-11, 10:28 AM
PF Gold
phinds's Avatar
P: 6,364
Quote Quote by Fusiontron View Post
What is your evidence that this is so? I don't know one way or the other but I find it unlikely. I can certainly agree that it would be hard for a person to do it, but imagine a machine that spins the book about a line that give you the rotation that you want, and then it shoots the book straight up into the air. Why would that not work?
BruceW
#3
Oct27-11, 10:36 AM
HW Helper
BruceW's Avatar
P: 3,448
The distortion is probably due to air resistance. If you had a really dense rectangular prism (and your arm was strong enough), then I'm sure you could make it work.
nasu
#4
Oct27-11, 10:42 AM
P: 1,970
Rotation about one of the three principal axes is unstable. The "unstable" axis is the one with intermediate moment of inertia. The axes with maximum and minimum moment of inertia are stable. It is a general property, not related to air drag.
Try to throw the book when spinning around a different axis.
Andy Resnick
#5
Oct27-11, 11:43 AM
Sci Advisor
P: 5,528
nasu is correct; I do this demonstration in class.
http://www.aerostudents.com/files/dy...igidBodies.pdf
(section 3.3)
Fusiontron
#6
Oct27-11, 11:48 AM
P: 90
Quote Quote by Andy Resnick View Post
(section 3.3)
Thank you. I'll look through this document.
EDIT: Is there a more rigorous derivation of this? I was told it involves complex variables.
BruceW
#7
Oct27-11, 12:02 PM
HW Helper
BruceW's Avatar
P: 3,448
Interesting stuff. And thanks Andy for the pdf. Unfortunately, it doesn't give an explanation of why one of the principle axis is unstable, it simply says "It can be derived"
Andy Resnick
#8
Oct27-11, 03:47 PM
Sci Advisor
P: 5,528
Quote Quote by BruceW View Post
I'll look around and see what I can find.
Studiot
#9
Oct27-11, 05:39 PM
P: 5,462
http://forum.allaboutcircuits.com/sh...light=spinning
see post#14
AlephZero
#10
Oct27-11, 06:38 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 7,178
See http://farside.ph.utexas.edu/teachin...on/node71.html
Matterwave
#11
Oct27-11, 08:27 PM
Sci Advisor
Matterwave's Avatar
P: 2,853
This is sometimes called the "tennis racket theorem". It can be derived from a perturbative solution to Euler's equations (torque free).
If you have rotation around any of the 3 principle axes, perturbations about 2 of the axes will lead to nice oscillations in the rotation (I forget if it's called nutation or w/e), but perturbations about the intermediate axis will lead to exponential growth in the perturbation (and therefore violating the validity of your perturbative solution).
Euler's equations (torque free):
[tex]I_1\frac{d}{dt}\omega_1=(I_2-I_3)\omega_2\omega_3[/tex]
[tex]I_2\frac{d}{dt}\omega_2=(I_3-I_1)\omega_3\omega_1[/tex]
[tex]I_3\frac{d}{dt}\omega_3=(I_1-I_2)\omega_1\omega_2[/tex]
So, if we take the rotation to be almost all in the 1-axis (e.g. omega2 and omega 3 are small), and work to first order
We find that omega1 is roughly constant because we neglect the second order in smallness for the omega2*omega3 term; however, for omega 2 term (for example):
[tex]\frac{d^2}{dt^2}\omega_2=\left[\frac{(I_3-I_1)(I_1-I_2)}{I_3 I_2}\omega_1^2\right]\omega_2[/tex] (hopefully I did the algebra right).
We see then that for the omega2 term to remain small (and oscillate), then I1 must either be the largest or the smallest moment of inertia (thereby making the coefficient on the right hand side negative). If I1 is an intermediate moment of inertia, the coefficient on the right hand side is positive, and that means the solution for omega2 is exponential growth and not oscillatory.
One should note, though, that if you can PERFECTLY make the rotation ONLY on the 1-axis (with omega2 and omega3 being identically 0), then even if the 1-axis is the unstable axis, you won't get any wobbling. But this only works if you can make the rotation ONLY around the 1-axis.
Andy Resnick
#12
Oct28-11, 08:12 AM
Sci Advisor
P: 5,528
Thanks, Matterwave. I found derivations in Landau&Lifgarbagez (section 37) and Arnold's "Mathematical Methods of Classical Mechanics" (section 29), but they are both horribly ugly. The derivation in Goldstein (chapter 5.6) is close to what you posted.
Register to reply
Related Discussions
Angle of diagonal of a rectangular prism Differential Geometry 0
Moment of inertia of a rectangular prism Classical Physics 15
Moment of inertia for rectangular prism General Engineering 2
Related Rates (rectangular prism) Calculus & Beyond Homework 4
