| New Reply |
Very confused about path of light from distant galaxies :-( |
Share Thread | Thread Tools |
| Dec22-11, 05:04 PM | #1 |
Hello there!
Sorry for the dumb question, but for years I have been very curious and confused about this: I just read that they discovered a galaxy 13.7 Bn light-years away -- therefore its light was emitted 13.7 Bn years ago and travelled 13.7 Bn light-years in some line. But, 13.7 Bn years ago, the universe was only 750 M years old - so if Earth had existed by then the visible universe had a radius of at most 750 M light-years and that galaxy would be at most 750 M light years away. So, either the light made several "loops" around (what sounds silly), or the visible universe was bigger than 750 M light-years when it was only 750 M light-years old (what also sounds silly), or that galaxy was not in the visible universe by then and now it is (what sound even sillier). So how come its light took 13.7 Bn years to travel a distance that was at most 750 M light years? Where have these photons been all that time? |
| Dec23-11, 04:43 AM | #2 |
The universe is expanding. So when the light started out the distance between galaxies was a lot less than it is when we measure it now.
| Dec23-11, 09:45 AM | #3 |
Imagine running towards something that is getting steadily further away. Say you run at 10 miles/hr, and start running toward something that is 10 miles away. You will get there in 1 hour, right? But suppose the object is moving away from you. By the time you cover the original 10 miles, the object has moved further away, so you have to keep running to reach it. This is analogous to what is happening with light from the distant galaxies. The initial distance was much less than the distance that the light ultimately ended up traveling.
| Dec23-11, 09:52 AM | #4 |
Very confused about path of light from distant galaxies :-(Precisely. So, those rays of light started to travel 13.7 Bn years ago. By that time, the galaxy was say 500 M light years away. So those rays of light had 500 M light years to travel.. should have taken 500 M years, not 13.7 Bn years....? I imagine that there is some sort of time dilatation effect to be considered, but I can't see where, given our reference system is stationary, so when the ray of light was emitted from the galaxy's reference system, from our point of view that was just another ray of light emitted from 500 M light-years, travelling towards us at speed = c. |
| Dec23-11, 09:59 AM | #5 |
Right, but speed of light is absolute... so a ray of light emitted from a galaxy moving at 90% of the speed of light will still travel with speed = c, even if it will be hightly shifted to red. fbs7 = very confused.. :-( |
| Dec23-11, 10:10 AM | #6 |
Light moves at c in its local reference frame, but the space through which the light is moving is expanding. No flat reference frame covers the whole system, you need the equations of General Relativity to describe the expanding universe.
Try reading these two articles. The first is a popular article, the second more technical. http://msowww.anu.edu.au/~charley/pa...DavisSciAm.pdf http://arxiv.org/abs/astro-ph/0310808v2 |
| Dec23-11, 10:22 AM | #7 |
| Dec23-11, 10:56 AM | #8 |
Ah, I'm getting it now. Cannot just expand my reference frame to far away galaxies, neither to far away back in time.
Those articles are quite interesting - will be quite some time reading them. Thank you both! |
| Dec23-11, 10:59 AM | #9 |
Mentor
And that's for a simple, non-expanding universe. Now add in the expansion of space and you get something truly bizarre. |
| Dec23-11, 12:02 PM | #10 |
| Dec23-11, 12:47 PM | #11 |
No, they take exactly the same time. However a signal from two sources co-locating, one at rest and the other in motion relative to the receiver does not, the one in motion takes less time. |
| Dec23-11, 12:58 PM | #12 |
So, D_H's point is that, even in the simplest representation of the universe, we still have the effect, regardless of any theoreticals. |
| Dec23-11, 01:17 PM | #13 |
A sees B moving away, B emits a light pulse, how does the light path gets "stretched out" as you cal it? |
| Dec23-11, 01:18 PM | #14 |
Isn't space a measure of de-coherence, after all? Only partly joking. |
| Dec23-11, 01:24 PM | #15 |
A related question on this issue - and very sorry if that will sound dumb, this whole thing is mind-boggling.
When the Universe was say 1 year old, does it make sense to say that the galaxy was at say 0.5 light-years away at that moment (from Earth's point of view)? I assumed that I could because I thought the visible universe couldn't have a radius of more than 1 light-years, given it was only 1 year old. If the light from that galaxy actually would actually take 10 B years to reach Earth as measured by the local time on Earth, then perhaps we could say that it was 10 B light-years away, even if the universe was only 1 year old? After all, if somehow I could take a big ruler and measure the actual distance to that galaxy at that moment, from Earth's point of view, and found that it was, err, 0.5 light-years away... that wouldn't mean anything, because even if it was much closer its light would still take 10 B years to reach us. ps: somehow I think I'm again falling into that trap of trying to extend my local reference frame to long distances (even when those distances were by then much closer) |
| Dec23-11, 01:57 PM | #16 |
Mentor
In that alternative universe, galaxies would still be receding from one another and it would still take considerably longer than the initial separation distance divided by c for the light from some remote galaxy to reach our (alternative) galaxy. All that the continued expansion of space does is to add to the confusion. For example, in our universe, the remote galaxy that we are seeing just now is "now" 65 billion light years away from ours. |
| Dec23-11, 03:31 PM | #17 |
Up until about 400,000 years there were NO stars/planets/galaxies, etc and there CERTAINLY was no earth ... that didn't form until billions of years later. |
| New Reply |
| Thread Tools | |
Similar Threads for: Very confused about path of light from distant galaxies :-(
| Thread | Forum | Replies | ||
| Brightness of distant galaxies problem | Advanced Physics Homework | 7 | ||
| Why might light from distant galaxies not reach us? | General Physics | 31 | ||
| Distant Galaxies - observation methods | Astrophysics | 3 | ||
| Question about distant galaxies | Classical Physics | 1 | ||
| physics in distant galaxies - same as on Earth? (history question) | General Astronomy | 10 | ||
