| New Reply |
Multi-Core Vs Clock Speed |
Share Thread | Thread Tools |
| Jan31-12, 07:05 PM | #1 |
I'm not sure I understand the advantages or disadvantages of each.
I imagine Multi-core (in the dual case) as two processors working on the same information to complete the task (reading, writing, whatever) in half the time. I imagine Clock Speed (I'm not sure if this is what you call it: ie: 3.4Ghz processor) as the rate at which it processes the information. If the above definitions are correct, then couldn't a high multi-core unit (with low clock speed) complete the same information in the same amount of time as a single core (with high clock speed)? Yet the single core is much cheaper? If this is the case, when why is everything going multi core and not increased clock speed? I have read Wikipedia and different articles, but I just need a down to earth definition. Thanks! |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Jan31-12, 08:09 PM | #2 |
In multi core like the intel core 2 series, each core could process a 1 and a 0. So it would take two separate cores to process a 1 and a 0. However with the new series of Core I7s and other cpus before the core 2 supports hyperthreading. This means that each core, or cpu if you will, will be able to process a 0 and a 1 using the same core rather then the old architecture that needed two separate cores. We are moving to multi core cpus because they can handle more information at a given time and especially with the same speed. So that means more information done faster. The single core could technically keep up, but the speed to do so would have to be very high. I hope this answers your question, and anyone correct me if I am wrong. |
| Jan31-12, 08:19 PM | #3 |
Mentor
The multi-core advantage is not n*x as some calculations are linear, with the next calculation based on the results of the last. Such operations can't easily be split to run in parallel.
| Jan31-12, 08:23 PM | #4 |
| Jan31-12, 08:34 PM | #5 |
As you increase a CPUs core speed, you generate a lot of heat. At some point it becomes impractical to continue pushing the envelope. With smaller architectures, it became possible to embed two or four or eight cores onto a single chip. Creating a 4GHz processor for personal computers is a much less convenient task for chip designers than putting two 2GHz processors on one chip. Now you have 8-core CPUs that, even at 2GHz, would be impossible for CPU makers to match and turn into a commercial product (16GHz?).
The catch with multi-core processors is the fact that not all software can use them. Back in the day when they were first coming out they were practically useless. Very few programs were able to use parallel processing and one core would go completely untouched. I can't say for sure, but I would bet it's not a trivial task to redesign software to use parallel processing. |
| Jan31-12, 08:48 PM | #6 |
It's not easy to rewrite software to be parallel by itself, so not many individual applications get much of a speed increase with mutlicore -- BUT it is pretty easy to split the work of multiple independent programs across cores.
Basically, your spreadsheet doesn't go 8x faster, but it doesn't slow down because you are also chatting on skype, playing an MP3, filtering e-mail, browsing the internet, etc at the same time. |
| Jan31-12, 10:29 PM | #7 |
It would make sense then, that multi core processors are also more efficient then high clock speed single core processors as a single core will generate more heat to do the same amount of work?
Overclocking a multi core would destroy the efficiency gains. Alas! Performance will always prevail! Thank you gentlemen for your input. |
| Jan31-12, 10:38 PM | #8 |
| Jan31-12, 10:45 PM | #9 |
Sure. It would make sense that a processor that could perform that same work in the same amount of time with less heat is more efficient in its power consumption? I would assume that you are referring to the limiting factor? As in why we do not create higher frequency CPUs? I suppose that you could look at it on a thermodynamic perspective. Also, if a Multi Core processor says that it has a clock speed of 2.8Ghz, does that mean that each core operates at this speed? Or is it that the combined output is equal to that speed? Maybe I am looking at it wrong. . . if it is an operating frequency, then they must be that same? Right? I guess I was thinking that each processor (in the dual case) would be 2.8Ghz/2. . . |
| Jan31-12, 11:47 PM | #10 |
| New Reply |
| Thread Tools | |
Similar Threads for: Multi-Core Vs Clock Speed
| Thread | Forum | Replies | ||
| Multi-Core vs Coupled Single-Core | Computers | 3 | ||
| Are your OS/system/background tasks fully multi-threaded through a quad-core CPU? | Computers | 5 | ||
| Some compatibility questions about DirectX 10, Windows Vista/7, and multi-core CPUs. | Computers | 5 | ||
| What does a multi-core processor mean? | Computers | 5 | ||
| MULTI CORE CPUs to run many programs ? | Computers | 6 | ||
