New Reply
Mathematics for electronics engineer
Share Thread Thread Tools
Feb7-12, 09:52 AM   #1
Hello all,
I am currently working on modelling organic FETs. I would like to know if there exists any book that can help me in modelling i.e. I have a curve and I need a method or approach as to how this can be represented using an eqn. Also I need some literature recommendation for approximations (Taylor's expansion etc. ) to dilute complex eqns to simpler ones.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb7-12, 11:26 AM   #2
Recognitions:
Quote by write2rammy View Post
how this can be represented using an eqn..
You aren't making it clear what "this" refers to. You say that you doing modelling. A model for a physical situation can be a complicated representation that contains many equations and algorithms. Or it could be one equation fit to some empirical data.
Exactly what sort of model are you dealing with? In the math section, there might be a shortage of experts on Field Effect Transistors, so don't assume your readers know about them. As to "organic" FETs, I don't know what those are.
Feb7-12, 03:14 PM   #3
Hello Tashi,
Thank you for your reply. My task is to develop a empirical model that is simple and closely mimics the current (Ids) behaviour of the transistor. Organic field effect transistors (FET) are a kind of MOSFET but with an organic semiconductor. The current output when plotted looks like that of a silicon MOSFET but with more non-linearities. My task is to use the same model eqns of a silicon MOSFET and supplement with appropriate equations to model the non-linearitites present in organic FET. I have read something similar in few semiconductor modeling books, where the author uses a funtion [sqrt(Vds + Const) - sqrt(Vds)] to model the short channel effect (a kind of non-linearity) in the case of silicon MOSFET. I can visualize when the function is a simple sqrt, square, exp etc. But it gets hard, when there is superposition of 2 or more functions.
Moreover, we have come across hundreds of mathematical functions. But only a handful of this is required to model the real world systems emphirically. Is there any book that explains in detail the mathematical (emphirical) modeling of real world systems in a systematic way.
New Reply
Tags
approximation, modeling, taylor expansion
Thread Tools
Similar Threads for: Mathematics for electronics engineer
Thread Forum Replies
Electrical, Electronics or Mechanical engineer? General Engineering 11
What does an electrical and electronics engineer do? Career Guidance 0
Electronics and Communication Engineer Academic Guidance 20
How much electronics/chemistry does a Mechanical Engineer have to know? Academic Guidance 0
