| New Reply |
Change in Density due to Temperature and Pressure Change |
Share Thread | Thread Tools |
| Feb15-12, 07:47 PM | #1 |
1. The problem statement, all variables and given/known data
Estimate the percent change in density of iron when it is still a solid, but deep in the Earth where the temperature is [itex]2000^\circ C[/itex] and it is under [itex]5000[/itex] atm of pressure. Take into account both thermal expansion and changes due to increased outside pressure. Assume both the bulk modulus and the volume coefficient of expansion do not vary with temperature and are the same as at normal room temperature. The bulk modulus for iron is about [itex]90\times10^9N/m^2[/itex]. We also know that the volumetric expansion coefficient of iron is [itex]35\times10^{-6}(^{\circ}C)^{-1}[/itex]. Also, [itex]1atm=1.103\times10^5N/m^2[/itex]. 2. Relevant equations [itex]\frac{\Delta V}{V_0}=-\frac{1}{B}\Delta P[/itex] where B is the bulk modulus. [itex]\Delta V=V_0\beta\Delta T[/itex] where [itex]\beta[/itex] is the volumetric expansion coefficient. 3. The attempt at a solution I'm assuming the change in volumes adds up so we have using the two equations successively, we have [itex]\frac{\Delta V}{V_0}=\left(-\frac{1}{90\times10^9}\right)\left(5000atm\right) \left(\frac{1.103\times10^5N/m^2}{1atm}\right)=-0.00563[/itex] and [itex]\frac{\Delta V}{V_0}=(4975^\circ C)(35\times10^-6\left(^\circ C\right)^{-1}=0.17413[/itex] So the total change in volume is [itex]0.17413-0.00563=0.168495[/itex]. Then we could easily get the percent change in density. However, I am unsure if I am applying this correctly. Am I allowed to add the change in volumes? |
| Feb16-12, 12:03 AM | #2 |
Recognitions:
ehild |
| Feb16-12, 05:20 PM | #3 |
Wait, so it should be (0.17413)(-0.00563)=-0.0009803519? That doesn't make intuitive sense to me. Why do we multiply the change in volumes?
| Feb16-12, 05:34 PM | #4 |
Recognitions:
Change in Density due to Temperature and Pressure Changeehild |
| Feb16-12, 06:15 PM | #5 |
Oh, I see now. Could you explain why it must be multiplied? I don't understand.
| Feb17-12, 12:06 AM | #6 |
Recognitions:
The formulae for volume change due to pressure and temperature refer to cases when the other quantity is constant. Pretend you put the piece of iron at high pressure first, when the volume decreases by Vo(ΔP/B). The new volume, V1=Vo(1-ΔP/B) is warmed up, and the new volume serves as "Vo" in thermal expansion. But the results are almost the same, and the the formulae are approximations anyway. So both ways should be accepted for the relative change of the volume, which is 0.168 with 3 significant digits by both methods.
ehild |
| Feb17-12, 10:42 AM | #7 |
Oh, thanks you so much. I understand now.
| New Reply |
| Tags |
| expansion, heat, pressure, temperature, thermodynamics |
| Thread Tools | |
Similar Threads for: Change in Density due to Temperature and Pressure Change
| Thread | Forum | Replies | ||
| Calculus problem (related rates) regarding change in temperature and change in speed. | Calculus & Beyond Homework | 3 | ||
| Work While Temperature Change and Heat while pressure and/or temperature change | Classical Physics | 0 | ||
| Thermodynamics: Calculating mass of air over a change in pressure/temperature | Advanced Physics Homework | 5 | ||
| Finding Pressure when given change in temperature | Biology, Chemistry & Other Homework | 2 | ||
| Calculating pressure change with temperature? | Introductory Physics Homework | 1 | ||
