| New Reply |
Coupling order in Fenman diagrams |
Share Thread | Thread Tools |
| Feb14-12, 11:54 PM | #1 |
Sorry if this appears a basic question,
but could you pls advise me is it possible to have a two identical vertexes but with different strength coupling? I have some toy Lagrangian and when I calculate Feynman rules I get for one vertex following expression: (M1+M2)*(combination of fields )+M1(combination of fields). Where M1 and M2 are coupling strength, so if I want to calculate some process in some order I should consider diagrams of the same order with respect to the coupling strenght. And in my case I am calculating diagrams with respect to M2 strength coupling.... so does it mean that for my vertex I should extract only M2 coupling part from that general vertex which wrote above: (M1+M2)*(combination of fields ) - > (M2)*(combination of fields ) ? |
| Feb15-12, 12:07 AM | #2 |
Just forgotten to mention (combination of fields) exactly the same . . . so identical field combinations in two vertex but different coupling strength . . .
| Feb15-12, 06:55 AM | #3 |
If I understand correctly you have two identical terms in the lagrangian, just different coefficients( coupling constants). Just add the terms into one, and you have one vertex with a coupling constant that is the sum of the two.
| Feb17-12, 12:10 AM | #4 |
Think about it as a taylor expansion. What is small?
If you're expanding in the fact that M2 is small, like you would in QED , then remember the leading order vertex is just M1, and the subleading the combination. But remember! Just because a VERTEX is subleading does not mean the DIAGRAM is subleading. (If you're expanding in coupling strength I believe its the same, but if you end up expanding in mass or momenta you can end up with powers canceling due to different vertices as well as propagators.) |
| New Reply |
| Thread Tools | |
Similar Threads for: Coupling order in Fenman diagrams
| Thread | Forum | Replies | ||
| Electron mass increased by electromagnetic coupling like it is by Higgs coupling? | High Energy, Nuclear, Particle Physics | 3 | ||
| Does coupling to stress-energy imply coupling to Ricci? | Special & General Relativity | 1 | ||
| Reducing third order ODE to a system of first order equs + 4th order runge-kutta | Differential Equations | 1 | ||
| Reducing third order ODE to a system of first order equs + 4th order runge-kutta | Calculus & Beyond Homework | 0 | ||
| Feynmann diagrams interpretation and diagramm symmetry order | Quantum Physics | 5 | ||
