New Reply
How to Normalize a simulated dataset to fit the actual dataset?
Share Thread
Feb19-12, 06:46 AM   #1
Can someone tell me how I can 'normalize' my dataset?
My scenario is as follows.
I have two datasets, A (real-life data) and B (simulated data).
Dataset A contains 4 numerical values (from an actual experiment):
-> E.g. 4 leaves from a binary tree each assigned with values 12.5,13.5,20.0 and 45.0.
Dataset B contains 40 numerical values (from a simulation done by the computer):
-> E.g. 40 leaves from a total of 10 binary trees where each tree produces 4 leaves with randomly assigned numerical values for each leaf.
For both datasets, I have computed their respective cumulative frequencies and plotted their respective charts using MS Excel e.g. [Cumulative frequencies of leaf values VS Leaf values]. This was to observe how similar/different are both of these data sets, where the smaller the vertical displacement between the two plots implies that both datasets are less different.
I was instructed to normalize my data from Dataset B and re-plot the chart for a better comparison between set A and set B.
How can I do this (and why is this important?)?
An example based on the situation described here will help a great deal. Thanks in advance.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb19-12, 11:42 AM   #2
Recognitions:
Unfortunately "normalize" is an ambiguous instruction. It might mean to convert each data value [itex] v [/itex] to it's "z-score" by computing [itex] \frac{v - \mu}{\sigma} [/itex] where [itex] \mu [/itex] is the mean of the sample in question ( real or simulated) and [itex] \sigma [/itex] is the standard deviation of the sample.
It could mean something as simplistic as converting each data value [itex] v [/itex] to a sort of ranking by computing [itex] \frac{v - v_{min}}{v_{max} - v_{min} } [/itex] where [itex] v_{max} [/itex] and [itex] v_{min} [/itex] are, respectively, the max and min values in the sample.
We'd have to know more about what the data and the simulation represent to know what makes sense - (and we'd have to assume the person who told to do this gave sensible advice!). If you use z-scores you can probably defend that choice as a common meaning for "normalize". If both your historgrams had a roughly a bell shaped appearance, I'd guess that this was was your advisor meant.
New Reply
Tags
excel, normalisation
Similar discussions for: How to Normalize a simulated dataset to fit the actual dataset?
Thread Forum Replies
Peer-Reviewed Journal Question w/ Dataset needed Set Theory, Logic, Probability, Statistics 0
EEG dataset Medical Sciences 5
Numerical Integration of a dataset (what is the best method?) General Engineering 2
Predicting dataset Set Theory, Logic, Probability, Statistics 0
Finding an oscillator's period with a dataset in Mathematica Introductory Physics Homework 1
