| New Reply |
What is "Little Group"? |
Share Thread |
| Feb20-12, 08:58 PM | #1 |
In my Quantum Field Theory class, I too often meet with the term "Little Group".
Unfortunately, I cannot find a good description of Little Group until now. I just know it is a subgroup of Lorentz Group. Can anyone have any brief description of this concept? Or any good reference on it? Thanks a lot. |
| Feb21-12, 02:34 AM | #2 |
Recognitions:
No, it is not a subgroup of the Lorentz group but rather of the Poincare group although it is also used in other context such as in crystallography.
It is the group which leaves a given k vector invariant. Hence different k vectors have different little groups. See, e.g. Gordon Hamermesh, Group theory or Eugene Wigners book on group theory as he introduced the concept in relativistic QM. A more modern introduction is Sternberg, Group theory |
| Feb21-12, 07:56 AM | #3 |
No, in its usual application in quantum field theory, the "little group" is a subgroup of the Lorentz group. In general if you have a group G which acts on a space X, and an element x in X, the little group of x is the subgroup of G that leaves x invariant.
For example the Lorentz group acts on the space of 4-vectors. If x is taken to be a timelike vector, the little group is the SO(3) subgroup of the Lorentz group in the 3-space orthogonal to x. If x is spacelike or null, the little group will be SO(2,1) or E(2) respectively. |
| Feb21-12, 09:36 AM | #4 |
Or if you're talking about massless particles, you can write their momentum as the product of two spinors \lambda \tilde{\lambda}
Then if you multiply lambda by t, and tilde lambda by 1/t, you leave the momentum unchanged. |
| Feb21-12, 10:58 AM | #5 |
More group-theoretically, a little group is the group that leaves some particular state invariant. Poincare transformations act on good old quantum mechanical states; the little group of the state of one massive particle in its rest frame is therefore the SO(3) of rotations around it.
| Feb21-12, 11:15 AM | #6 |
Recognitions:
Anyhow, what I really wanted to say was that the little groups are used to construct representations of the Poincare group and not of the Lorentz group. |
| Feb21-12, 07:09 PM | #7 |
Mentor
| Feb22-12, 02:03 AM | #8 |
Recognitions:
| Feb22-12, 06:02 AM | #9 |
hi yicong2011!
![]() see it free online at http://books.google.co.uk/books?id=h...group%22&hl=en
| Feb22-12, 09:56 AM | #10 |
You can also find in Wigner little group details on E2 and T2
| Feb22-12, 10:36 AM | #11 |
Recognitions:
| Feb22-12, 10:51 AM | #12 |
Mentor
Give me a bit of time, and I'll post the explicit construction.
| Feb22-12, 11:50 AM | #13 |
Mentor
The universal cover of the restricted Lorentz group is [itex]SL\left( 2,\mathbb{C}\right)[/itex]. If a 4-vector is written as [itex]X=x^{0}+x^{i}\sigma _{i}[/itex], then the action of [itex]A \in SL\left( 2,\mathbb{C}\right)[/itex] on [itex]X[/itex] is [itex]A X A^\dagger[/itex]. The little group of the lightlike 4-vector [itex]X=1+\sigma_3[/itex] is the subgroup of [itex]SL\left( 2,\mathbb{C}\right)[/itex] that consists of matrices of the form
[tex] \begin{pmatrix} e^{i\theta} & b\\ 0 & e^{-i\theta} \end{pmatrix}, [/tex] where [itex]\theta[/itex] is an arbitrary real number and [itex]b[/itex] is an arbitrary complex number. [tex] \begin{pmatrix} e^{i\theta} & b\\ 0 & e^{-i\theta} \end{pmatrix} \rightarrow \begin{pmatrix} e^{i2\theta} & b\\ 0 & 1 \end{pmatrix} [/tex] is a two-to-one homomorphism between groups of matrices. Write [itex]b = u+iv[/itex] for real [itex]u[/itex] and [itex]v[/itex], and [itex]\left( x , y \right) \in \mathbb{R}^2[/itex] as the column [tex] \begin{pmatrix} x+iy\\ 1 \end{pmatrix}. [/tex] [tex] \begin{pmatrix} e^{i2\theta} & u+iv)\\ 0 & 1 \end{pmatrix} \begin{pmatrix} x+iy\\ 1 \end{pmatrix} = \begin{pmatrix} x\cos2\theta - y\sin2\theta + u + i\left( x\sin\theta + y\cos2\theta +v \right)\\ 1 \end{pmatrix} [/tex] |
| Feb23-12, 01:56 AM | #14 |
Recognitions:
Thank you George, very interesting.
So setting theta=0 yields the pure translations by b. The elements A are of the same form as the X, [itex]X=x^{0}+x^{i}\sigma _{i}[/itex]. If I remember correctly, imaginary parts of the x^i correspond to boosts. So a pure translation is of the form [itex]X=x^{0}+b/2\sigma _{x}+ib/2 \sigma_y[/itex]. So the translation is a 50/50 mixture of rotation and boost. |
| Feb23-12, 03:39 AM | #15 |
Recognitions:
The explicit generators of the E2 little group are [tex] J_3 ~,~~~~ A ~:=~ J_2 + K_1 ~,~~~~ B ~:= -J_1 + K_2 [/tex] so the commutation relations are [tex] [J_3, A] = iB ~,~~~~ [J_3,B] = -iA ~,~~~~ [A,B] = 0 ~. [/tex] |
| Feb26-12, 05:58 PM | #16 |
Recognitions:
The A and B, acting on a momentum in the z-direction, represent centrifugal accelerations K compensated by counter rotations J. The total effect of A or B is therefor zero. The general case is. [tex] A\cos \phi ~+~B\sin\phi [/tex] Where [itex]\phi[/itex] is the angle which determines the direction in the x-y plane of the centrifugal acceleration. Small nitpick about his signs: In a right-handed coordinate system they should be: [tex] J_3 ~,~~~~ A ~:=~ J_2 - K_1 ~,~~~~ B ~:= -J_1 - K_2 [/tex] Note that if you reverse the direction of the momentum, (k,0,0-k) instead of (k,0,0,k), that the signs of the generators also change. In this case you get indeed. [tex] J_3 ~,~~~~ A ~:=~ J_2 + K_1 ~,~~~~ B ~:= -J_1 + K_2 [/tex] One should expect this because under spatial inversion K behaves like a vector and J like a pseudo vector. Regards, Hans |
| Feb27-12, 12:48 AM | #17 |
Ah, Thanks a lot, guys. Thanks for glorious detail explanation.
| New Reply |
| Tags |
| little group |
Similar discussions for: What is "Little Group"?
| Thread | Forum | Replies | ||
| In binary can we have a value with "deci" "centi" "mili" or more lower valued prefix? | Computers | 14 | ||
| "No prior geometry" and the group field theory vehicle | Beyond the Standard Model | 6 | ||
| Qs: How "Group" and "Period" affect semiconductors | Atomic, Solid State, Comp. Physics | 6 | ||
| Question on "Two theorems for the group velocity in dispersive media" | Classical Physics | 4 | ||
| Questions on Freidel's "Group Field Theory (hep-th/050516)" | Beyond the Standard Model | 3 | ||
