| New Reply |
Solution to quadratic equation doesn't look right |
Share Thread | Thread Tools |
| Feb22-12, 05:54 PM | #1 |
1. The problem statement, all variables and given/known data
distance = rate * time 3. The attempt at a solution So the speed of the ball I have as: [t = time] 5 + 32t Which I believe makes sense because the ball is initially traveling @ 5 ft/sec, and after 1 second, the ball is traveling 37 ft/sec, then after 2 seconds the ball is traveling @ 69 ft.sec, etc. I assume we use d = rt (which is distance = rate * time). So the total distance the ball travels is 85 feet which is equal to the total rate of 5 + 32t * time. The equation I set up like this: 85 = (5 + 32t) * t I set up the quadratic like so: 32t^2 + 5t - 85 = 0 I solved it and got: (1/64) * (sqrt(10905) - 5) which is approx. 1.55. I worked it out to check, and 1.55 seconds is much too low for the value: 5 feet + (32 feet * 2 seconds) = 69 feet So after 2 seconds, the ball has only traveled 69 feet, while the quadratic equation states that the ball has traveled 85 feet after 1.55 seconds. What gives? |
| Feb22-12, 06:09 PM | #2 |
Recognitions:
| Feb22-12, 08:17 PM | #3 |
Mentor
| Feb23-12, 08:55 AM | #4 |
Because this is a two dimensional problem. you should break it into horizontal and vertical components. As Mark44 said there is an acceleration of -9.81 m/s^2 in the vertical direction and no acceleration in the horizontal direction.
| Feb23-12, 12:20 PM | #5 |
| Feb23-12, 01:22 PM | #6 |
Mentor
Has anyone noticed that the ball's speed is 5 ft/sec? That works out to about 3.4 mi/hr. If I start walking toward the wall at the same time the ball is thrown, I'll get there first (I can walk faster than 3.4 mph). Furthermore, I can't imagine any scenario in which the ball would actually get to the wall, inasmuch as it will fall ~4600 ft during its flight. |
| New Reply |
| Thread Tools | |
Similar Threads for: Solution to quadratic equation doesn't look right
| Thread | Forum | Replies | ||
| finding complex solution to quadratic equation | Precalculus Mathematics Homework | 7 | ||
| How was this ODE solution found? Doesn't seem to be the normal solution. | Introductory Physics Homework | 6 | ||
| In CuSO4 solution, why doesn't Cu(OH)2 precipitate out? | Chemistry | 4 | ||
| Related Rates, why doesn't my solution work? | Calculus & Beyond Homework | 5 | ||
| Quadratic equation solution | General Math | 8 | ||
