Finding equation for potential between concentric charged spheres
The problem involves determining the electric potential V(r) between two concentric charged spheres, specifically in the region between a metal sphere and a hollow metal shell. The inner sphere has a positive charge, while the outer shell has an equal negative charge. The potential is defined to be zero at an infinite distance from the spheres.
  • Participants discuss the integration of the electric field to find the potential and question the assumptions made regarding the electric field in different regions. There is a focus on the evaluation of integrals and the implications of Gauss' Law.
Participants are actively engaging with the problem, exploring various interpretations of the equations involved. There is a recognition of the need to clarify the relationship between the electric field and potential, as well as the correct evaluation of integrals. Some guidance has been offered regarding the integration process and the significance of constants.
There are indications of confusion regarding the interpretation of results and the online submission system's handling of constants. Participants are also reflecting on the definitions of potential and the work done in moving charges in an electric field.
Minhtran1092
A metal sphere with radius r_a is supported on an insulating stand at the center of a hollow, metal spherical shell with radius r_b. There is charge +q on the inner sphere and charge -q on the outer spherical shell. Take the potential V to be zero when the distance r from the center of the spheres is infinite.
What is the equation V(r) that models the potential in the region r_a < r < r_b?
ΔV = -∫E(r)∂r
ψ=Q/ε_0
E∫A = ψ; ∫A = 4πr^2
1. V(∞) - V(r) = ∫E(r)∂r (from ∞ to r) = ∫E(r)∂r (from ∞ to r_b) + ∫E(r)∂r (from r_b to r);
2. ∫E(r)∂r (from ∞ to r_b) should evaluate to a constant since E(r) = 0 by Gauss' Law (Taking the Gaussian object to have r > r_b, the enclosed charge is -q + q = 0; Electric flux = 0 and therefore electrical field outside the r_b shell is 0.)
3. ∫E(r)∂r (from ∞ to r) = Constant + ∫E(r)∂r (from r_b to r)
4. ∫E(r)∂r (from r_b to r) evaluates to q/(ε_0*4*π)| (from r_b to r)
V(r_a< r < r_b) = q/(ε_0*4*π)| (from r_b to r) is as far as I got.
Did I make a wrong assumption?
There is no constant in a definite integral. The electric field outside the big sphere is zero, so its integral between infinity and rb is zero, too.
When integrating between rb and r, you have to get a difference of two terms, when plugging in r and rb. ehild
ehild
Ok. V(r) should equal ∫E(r)∂d (from r_b to r);
ψ = Q_enclosed/ε_0 = +q/ε_0 = E(r)*4πr^2; E(r) = q/(ε_0*4*π)
E(r_a< r< r_b) = q/(ε_0*4*π*r^2); Gauss' law
Integrating E(r_a<r<r_b) gives q/(ε_0*4*π) ∫1/r^2 ∂r = q/(ε_0*4*π) [-1/r | (from r to r_b)] =
q/(ε_0*4*π)[-1/r + 1/r_b]. This isn't the answer though =\.
On the other side, it is the integral of V . What is it? Take care,
[tex]\int_{r_b} ^{r }{dV}=-\int_{r b}^{r}{Edr}[/tex]
I don't understand what this equation represents. I also tried evaluating it which did not give me the correct answer.
On the right side:
[tex]\int_{r_B}^{r}{Edr}[/tex] gives [itex]\frac{q}{ε_0*4*\pi}[/itex]([itex]\frac{-1}{r}[/itex]+[itex]\frac{1}{r_b}[/itex]).
On the left side, you get: V(r) + V(r_b); Where V(r_b) is [itex]\frac{q}{\epsilon*4*\pi*r_b}[/itex]
However, [itex]\frac{q}{ε_0*4*\pi}[/itex]([itex]\frac{1}{r}[/itex]+[itex]\frac{-1}{r_b}[/itex])-([itex]\frac{q}{\epsilon*4*\pi*r_b}[/itex]) isn't correct
That statement is entirely wrong.
[tex]\int_{r_b} ^{r }{dV}=V(r_b)-V(r).[/tex]
As for V(rb), think of the definition of potential. It is connected to work; and how much work is done when a test charge comes from infinity to rb, when the electric field is zero?
ehild
ehild
I'm sorry that was a typo. You're correct the left side evaluates to V(r_b)-V(r).
It turns out I had the correct answer (the negative of Edr from r_b to r). The online system to which I submitted my answer didn't interpret "1/4piE_0" to be the "k" constant.
Stupid program...
ehild
  • · Replies 17 ·
