| New Reply |
Is the universe infinite? |
Share Thread | Thread Tools |
| Feb29-12, 03:38 AM | #103 |
Is the universe infinite?I also mention another point as follows: Is there any way to "see" empty space? I postulate that the limits of our observable universe may merely be the limits at which space-time truly becomes empty. Not only empty in a sense that Object A is located 5 billion light years away, and that there is nothing in that line of sight until 12 billion light years away, but rather empty in that there simply hasn't elapsed enough time for something to be 80 billion light years away. We cannot assume that the only kind of empty space that there could be is empty space that is between two other "things" (such as galaxies). It is possible for empty space to mean that there is literally nothing out there beyond some distance away from some position (such as ours). A region of the universe that we cannot see presently because it has undergone metric expansion beyond our "horizon" greater than the speed of light, and a region of the universe that we cannot see because it is empty space, are indistinguishable, I believe. |
| Feb29-12, 04:22 AM | #104 |
The reason why I believe that is because space-time will continue to exist is specifically because of the time dimension of space-time. Assuming that time will continue to exist no matter how much "time" passes, it is unbounded. In the language of limits, there is no finite time interval starting from any initial time not t = 0 such that space-time itself will not exist at the end of that interval. In the case of matter and energy, on the other hand, we know of no law that states that the mass-energy as a whole can be created or destroyed, nor have we ever observed such a process. Therefore, the amount of mass-energy that exists now will be the amount of mass-energy that exists at any time in the future. The distinction between space-time and mass-energy is clear in the sense that space-time has the capacity to become unboundedly large whereas mass-energy clearly does not, according to presently known physical laws. I argue that a quantity that has the capacity to become infinitely large is actually infinite. If this were not the case, how is the following paradox resolved? Space-time can grow without bound, and probably will. Let us define two variables: P (present) := presently existing space-time F (future):= potentially available but not currently existing space-time S (sum) := P + F We cannot, with perfect confidence, know F. We cannot even know P, since we do not know exactly how large our whole universe is. But if the universe is accelerating in its expansion rate, then we know that F is unbounded. Then even if P is finite, S is unbounded. The universe will exist for a lot longer than it exists now. Therefore, I argue that F, being the "long run supply curve" of space-time versus P, being the "short run supply curve" of space-time, is the most faithful representation of space-time's true nature. However, if the metric expansion of space involves the conversion of space-time into mass-energy specifically in the form of dark energy, then my claim cannot stand. But this would involve having to define an additional conservation law between not only energy and mass, but between mass-energy and space-time, and there isn't a shadow of a hope for that to work. |
| Feb29-12, 04:48 AM | #105 |
The observable universe ends abruptly 13.7 billion years ago. This 'boundary' is called the CMB, or surface of last scattering. There are no galaxies, stars, etc. lurking behind the CMB waiting to be discovered, and precious little spacetime. Only about 400,000 years separates the CMB from the Big Bang.
| Feb29-12, 04:52 AM | #106 |
Recognitions:
| Feb29-12, 06:03 AM | #107 |
| Feb29-12, 06:12 PM | #108 |
A conservation law that is so general cannot go from being obeyed in all instances at all scales that are smaller than some arbitrary scale, but then transition abruptly into there being existing "no such thing" as you said. In any case, the burden of proof is on your part. We both agree that there is a possibility that the universe's properties at the cosmological scale are different, even in extremely surprising ways, from the universe at smaller scales. But this doesn't eliminate the fact that such differences need to be quantified, or precisely stated. How is saying that there is no such thing as a conservation of energy on cosmological scales any different, in its radicalism, than me saying that there is a finite amount of mass-energy? At least, in my view, the law of conservation of mass-energy is obeyed, which is not at all a triviality. |
| Feb29-12, 06:25 PM | #109 |
| Feb29-12, 07:17 PM | #110 |
| Feb29-12, 07:54 PM | #111 |
Think about the expansion of space and the resulting redshift of light. If all galaxies outside our cluster are receding from us, and those galaxies in their cluster see all other galaxies receding from them as well, that means that we are losing energy. Normally redshift from a moving object is countered by the fact that the light emitted in the opposite direction is blueshifted the same amount. The galaxies at redshift z=2 or whatever are moving away from us but they are not moving towards anything else, meaning there is no blueshift, only redshift. So, since expansion doesn't happen on the galaxy cluster scale, the conservation of energy still applies. It is only above this scale that it breaks down. However this could simply be a lack of understanding about dark energy, expansion, or any number of things. Now, think about the following. You look at a proton travelling at 10% c. How much energy does it have? Well obviously it would have a certain energy we can find by doing the math with the right equations. But wait...that energy is only for one particular frame of reference. If you were moving at 5% c in the same direction then the proton would NOT have the same energy as it did in the stationary frame. So how much energy does it "really" have? I don't think that's answerable. (This may not be relevant to conservation of energy, but I wanted to point out that some types of energy are relative) Also, as has been explained to me, energy is ill defined in General Relativity, so it's hard to say whether it's conserved or not. I had a link to a page that explained some of it, but I don't know where it is at the moment. Even the page itself states something along the lines of "Is energy in GR conserved? Well, that depends on what you mean by energy...and what you mean by conserved...", so I really don't know for sure. If I've made a mistake somewhere someone let me knwo. |
| Feb29-12, 08:53 PM | #112 |
Recognitions:
Conservation of momentum is honored whenever you have a system that is unchanged when you move the system from place to place. Conservation of angular momentum is honored whenever you have a system that is unchanged when you rotate it through some angle. Conservation of energy is honored whenever you have a system that is unchanged when you move the system forward or backward in time. This fact comes directly from Noether's theorem. And the actual statement is a bit more subtle (in reality, some things can change). If you imagine our own solar system, for example, it is a periodic system: if you wait some amount of time, the planets will all be back in their previous positions. So energy is a conserved quantity for planetary motion. You can build similar arguments for most anything we do here on Earth. In fact, for most of our laws of physics, those laws remain unchanged at all times. The specific system may change, but the laws do not. This means that energy has to be conserved for Newtonian gravity, electricity and magnetism, and quantum mechanics. However, General Relativity throws a wrench into this whole system, because there is no absolute time coordinate any longer. Time itself becomes a parameter in the theory, and this symmetry is lost. No longer can you change time without changing the laws of motion in General Relativity, and so you can't define a conserved energy. However, General Relativity doesn't get rid of conservation of energy entirely. Instead of conserving energy, it conserves the stress-energy tensor. This tensor has ten independent components, including energy density, pressure, momentum density, and twisting forces. Conservation of the stress-energy tensor will sometimes force energy to change because the other components of the tensor change. So GR doesn't say, "anything at all can happen," but rather that we now have a new conservation law which is more correct: conservation of stress-energy. And conservation of stress-energy doesn't allow energy to be conserved in all cases. Finally, I'd just point out that the conservation of mass is trivially disproven by the fact that we can create higher-mass particles in particle accelerators, and do so very often. |
| Feb29-12, 09:37 PM | #113 |
Thanks Chalnoth! That's the first explanation of conservation of energy in GR that I've actually understood and learned something from.
| Mar14-12, 12:52 AM | #114 |
Compared to solar systems, galaxies, clusters and super clusters we can call everything else the universe only because we are inside of it. But that doesn't mean there are not many other universes just like it all lined up forever. I believe they use to call the Milky Way the universe. |
| Mar14-12, 01:51 AM | #115 |
You don't get to decide what you want the definition to be even though you seem to think you can. |
| Mar14-12, 02:21 AM | #116 |
| New Reply |
| Thread Tools | |
Similar Threads for: Is the universe infinite?
| Thread | Forum | Replies | ||
| The Universe - infinite or not ? | Cosmology | 139 | ||
| If the universe is infinite | General Discussion | 3 | ||
| Infinite-infinite universe explains all | General Discussion | 42 | ||
| Does an infinite universe effect an infinite outlook? | General Astronomy | 11 | ||
| Universe Infinite !!! | General Astronomy | 37 | ||
