| New Reply |
My First Telescope Need Advice |
Share Thread | Thread Tools |
| Mar6-12, 11:22 AM | #1 |
Hi i am new to this forum so i apologize if ive posted this in the wrong place.
I have brought my first telescope: http://www.celestron.com/astronomy/t...odigy-130.html I have a puzzling problem though witch im sure u guys will know the answer to. I paid alot of money for this scope and the clarity is amazing but the size of planets is miniscule jupiter looks like a tiny orange dot with even smaller specs of light with are 4 of its moons i have seen people with less powerful scopes get much bigger images of planets even mars and venus were just tiny red and purple colored dots you can only just make out there spherical planets im using a 9mm lens. Do i need a better one or is it a case of calibrating the whole scope from camera to mirrors ? id really appreciate some guidance as im really frustrated and don't know who to ask not many people where i live know anything about it im in the uk. the only thing i can see clearly and very large is the moon id love to see some galaxys but haven't bothered as im sure i wont be able to at the moment :( |
| Mar6-12, 12:27 PM | #2 |
generally speaking, you paid for a nice computer guidance and assistance system, with a small telescope attached to it. however, your problem relates directly to the focal length of the optical system of your scope - you have a short focal length whose strengths would be for wide field observing. this is why you are having to use a very short FL eyepiece to acheive enough magnification to see any detail on objects such as jupiter. 4mm eyepieces are notoriously difficult to use due to very limited eye relief.
for planetary observations, you typically would want a long focal length scope where you can utilize longer FL eyepieces with greater eye relief. also, a scope with a larger diameter objective will, by gathering considerably more light, greatly enhance your observing enjoyment. however, there are many wonderful and interesting things to be learned and seen with the scope you have, and i encourage you to use it's abilities to the fullest. brighter/larger objects such as the moon can be a lifetime of study and visual enjoyment all by themselves. likewise, observations of the sun can be totally fascinating (there are very inexpensive ways to construct a solar filter which allow for safe direct viewing of the sun). |
| Mar6-12, 12:40 PM | #3 |
so ur saying theres no way i can see planets bigger ?
when i ordered it it says its very good for planet observation and even deep space and galaxys im so confused so i i cant do anything about it il lnever b able to see a galaxy either |
| Mar6-12, 12:46 PM | #4 |
Is there a return period? If so, I'd suggest using it (and paying a restocking fee, if necessary), and then spending hours on this thread:
http://physicsforums.com/showthread.php?t=391086 |
| Mar6-12, 12:54 PM | #5 |
i dont think there is i have a 10yr guarantee to so could always fry the circuits lol but lets just say i cant take it back is there anything i can do ?
| Mar6-12, 01:25 PM | #6 |
You've got a 5" scope there. That's about average for a beginner scope. Nothing wrong with that.
There are only 2 things you can do to see a larger image: 1] get a higher power eyepiece. Your 9mm is pretty high but you could go higher, to a 4 or so. That would double the size of objects. That would cost you, and I'm not sure it's wise to invest that kind of money in this scope. 2] Use a barlow lens. They are cheap. A 2x or 3x barlow will double or triple the size of object but at the cost of brightness. Frankly, I do not recommend even bothering with a barlow. I think the thing you need to adjust is your expectations. I have a similar scope and Jupiter resolves to a disc smaller than my pinkie nail at arms length. That's what you should expect. You should be able to make out the darkest bands on Jupiter but the Great Red Eye might or might not be visible depending on how good your observing conditions are. |
| Mar6-12, 01:25 PM | #7 |
| Mar6-12, 01:28 PM | #8 |
| Mar6-12, 01:34 PM | #9 |
ok thanks for the advice eveyone so what kind of scope im i looking at buying to see objects bigger? especially planets and galaxys ?
| Mar6-12, 01:38 PM | #10 |
Please read the thread that I linked. There are many pages of useful information there, and it would be counterproductive to try to duplicate that info here. If you want to add questions to that thread, they will be preserved so that others can benefit from the advice that you get (the thread is Sticky).
| Mar6-12, 01:54 PM | #11 |
A 2x barlow should solve most of your planetary viewing issues. An f5 scope is not ideal for planetary viewing, as already noted, but, the wide field views will be much more appreciated when you move on to deep sky objects. A 2x barlow with a 9mm ep will get you to about 150x, compared to the 76x you are currently getting. The practical magnification limit for your scope is about 250x and even that much magnification will rarely be usable save when conditions are outstanding [~ half a dozen times a year in most locations]. Under average conditions, 150x is about the maximum useful magnification with your scope. The plus part of barlowing vs buying a shorter fl eyepiece is eye relief - which is pretty bad in most ep's under about 6mm. The downside of a barlow is you lose some light due to the extra lens elements. Planets are fairly bright though so this should not be much of an issue.
| Mar6-12, 04:05 PM | #12 |
Also, if you want to view galaxies then realize that you are BARELY going to be able to make any of them out with any size amateur scope that doesn't cost several thousand dollars. And at best they will look like fuzzy objects. Your view will also vary greatly depending on how much light pollution is at your observation site. If you near a large city then the only things you will be able to see clearly will be the Moon and Planets, and a few of the brightest deep sky objects, such as Andromeda and a few star clusters. Also, do you know how a telescope works? Such as how to determine the magnification a setup will give you? |
| Mar6-12, 05:06 PM | #13 |
| Mar6-12, 05:32 PM | #14 |
| Mar6-12, 05:37 PM | #15 |
Celestron is a highly regarded telescope OEM and their products are generally very good. They are not, however, the best source for accessories, which tend to be overpriced [you pay for the name]. There are numerous after market sources for accessories and many of these products have excellent value. Antares is one that comes to mind, but, there are many. There are also forums where accessories are discussed in great detail by experienced amateurs and able to answer most any question you can imagine - e.g., cloudy nights.
| Mar6-12, 05:47 PM | #16 |
For example there are videos on youtube with smaller cheaper scopes than mine where planets are viewed much bigger than im seeing them. |
| Mar6-12, 05:55 PM | #17 |
It's time to dial down the commercial ads and expectations, and get some expert guidance. If you bought a $700 scope without visiting some clubs and star-parties first, I can't really help you. You should have done your homework and peered through enough star-party-scopes to figure out what you wanted, and what you could afford.
Best of luck in future purchases. |
| New Reply |
| Thread Tools | |
Similar Threads for: My First Telescope Need Advice
| Thread | Forum | Replies | ||
| Telescope advice | General Astronomy | 14 | ||
| Telescope Advice | General Astronomy | 21 | ||
| Looking for advice on telescope | General Astronomy | 8 | ||
| Telescope Advice | General Astronomy | 7 | ||
| Need some advice on telescope | General Astronomy | 21 | ||
