New Reply
Scalefactor calculations for special cases using the Friedmann Equation
Share Thread Thread Tools
Mar8-12, 09:31 PM   #1
(i) Obtain the scale factor a(t) and redshift z when the energy density of matter and radiation were equal.
(ii) Next use the a(t) relation for a matter-only universe to estimate the time of matter-radiation equality.
(iii) Repeat (ii) but using the a(t) relation for a radiation-only universe. Which approximation, (ii) or (iii), is closer to the correct answer?
Can someone help me?
Thanks!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar9-12, 01:58 AM   #2
How far have you gotten? You should start by figuring out how dust and radiation energy densities depend on the scale factor. You can find this out using the conservation of energy-momentum, and the fact that radiation energy-momentum tensor is traceless.
After that you just equate the expressions you got, and integrate Friedmann equations
Mar9-12, 02:55 AM   #3
Ive understood the concept of how I'm supposed to do it. But, I am confused on how to start the radiation equation. As in what formula do I use to find the scale factor for a radiation dominated universe?
Mar9-12, 09:18 AM   #4
Quote by karan9 View Post
The way I understand the question is that you should use the scaling laws to find the value of scale factor at matter-radiation equality as a function of their densities today.
Mar9-12, 11:04 AM   #5
Recognitions:
Gold Membership Gold Member
Just remember that the average energy/photon is proportional to 1/a. I'm guessing that you should assume zero curvature, that the density is always at critical, and that the kinetic energy of the matter can be neglected. You'll need to assume some value for the amount of matter per photon (about 10-35kg/photon).
Mar9-12, 05:23 PM   #6
Oh that clears up part i for me. Thanks guys!! My answer for part i comes to a=2.8*10^-4
Is that right?
I am confused about the method we have been asked to use for part ii.
Do i just plug in the value of a into the (da)^2 = Ho^2/a^2 equation and solve for 't' ?
Am I missing something?
Thanks Again.
Mar9-12, 09:07 PM   #7
Recognitions:
Also remember that the average energy per blackbody photon is ~2.7kT, which is a little higher than you might guess.
Just to give a few clues, with radiation only, you'll find that a [itex]\propto[/itex] t1/2 whereas with matter only, a [itex]\propto[/itex] t2/3. Then [itex]\rho[/itex] [itex]\propto[/itex] k/tn where n is a certain positive integer that I won't disclose (same integer for radiation and matter), and k is a constant, although kradiation is slightly larger than kmatter.
New Reply
Tags
cosmology, friedmann, radiation, redshift, scale factor
Thread Tools
Similar Threads for: Scalefactor calculations for special cases using the Friedmann Equation
Thread Forum Replies
Special Cases for Gravity Force Inside Solid Objects General Physics 1
Special cases of the Schroedinger Eq? Quantum Physics 2
Friedmann Equation Cosmology 9
Atwood Machine Special Cases Introductory Physics Homework 1
Friedmann equation Cosmology 3
