Stationary electron broglie wavelength
  • Context: Graduate
  • Thread starter Thread starter roboticmehdi
    Electron Wavelength
The discussion revolves around the implications of de Broglie's wavelength formula for a stationary electron, particularly focusing on the concept of infinite wavelength and its consequences. Participants explore theoretical aspects, including the relationship between momentum, velocity, and wave-like behavior of electrons, as well as interpretations from quantum mechanics.
  • Some participants assert that if an electron is stationary, its wavelength becomes infinite, leading to questions about the electron's existence or behavior.
  • Others argue that an electron in a stationary state does not have zero velocity, referencing Bohr's theory and the uncertainty principle to suggest that there is always some nonzero velocity associated with an electron.
  • A participant proposes a scenario where electrons are fired from a gun and then caught up with, leading to a relative velocity of zero, which would also suggest an infinite wavelength.
  • Some participants discuss the implications of infinite wavelength, suggesting that it results in infinite uncertainty in position, but the consequences of this are debated.
  • There are discussions about the nature of wave behavior, with some participants questioning whether an electron behaves like a wave in the same way as a classical wave would.
Participants express differing views on the implications of an electron being stationary and the meaning of infinite wavelength. There is no consensus on the consequences of λ=∞ or the nature of the electron's behavior in this context.
Participants reference various theoretical frameworks, including Bohr's model and the Schrödinger equation, but the discussion remains unresolved regarding the interpretations and implications of these theories in relation to stationary electrons.
roboticmehdi
de broglie's formulation:
λ=h/(mv)
the more the momentum of a particle, the less wave-like behaviour it shows. But what if we have electron which is stationary, i.e. zero speed, according to formula λ becomes ∞. What does this mean? Does the electron disappear?
λ=h/(mv)
Why did you decide that an electron in a stationary state has zero velocity? This is an incorrect statement. Even from Bohr's theory implies that in stationary state we have a nonzero angular momentum, and as a result nonzero velocity.
From the viewpoint of the Schrödinger equation, the orbital angular momentum of the hydrogeh-like atom in the ground state is zero. But this does not mean that the electron velocity is zero due to uncertainty principle. Uncertainty in the position of the electron is of the order size of an atom [itex]r[/itex] , thus uncertainty in the electron velocity is equal to [itex]\Delta v \propto \frac{\hbar}{m r}[/itex].
But I am not talking about an electron in atom. Of course there an electron can not be stationary. Imagine you fire some electrons from electron gun in space and then you accelerate until you reach their speed ( this is possible since they move at lower speed than speed of light ). what would then happen? the wavelength becomes infinite? what happens to electron then?
Electron is in a ground state in atom just the stationary! If you acсelerate electron, its wavelength decreases, tends to zero (not to infinity).
Forget about the atom. You fire some electrons, then you catch up with them. Relative to you their speed becomes ZERO. λ=h/(m*0)=∞ do you agree now ?
Ok, if you go with the electron velocity, really, you find it velocity to be zero, but you will never know where it is, due to uncertainty principle. [itex]\lambda \to \infty[/itex] of this says.
I don't care about its position. I just want to know what happens when the wavelength becomes infinite. what happens to electron ? what are the consequences of λ=∞ ?
And none of it will not happen. A consequence of λ=∞ would be that the uncertainty in position becomes infinite. And that's all.
hi roboticmehdi! hi sergiokapone! :smile:
i was thinking of giving this answer too, but the problem is that the same argument applies at any speed …
if we know the velocity is exactly v, then its position is again infinitely uncertain :redface:
the wavelength is simply the distance it travels during a "phase rotation" of 2π …
watch something follow a sine wave … now keep the amplitude the same and reduce the (horizontal) speed to 0 … it simply goes up and down without moving horizontally … it travels 0 during a "phase rotation" of 2π :wink:
Yeah. The uncertainty principle is about Δv and Δx, not about v. you could have infinite uncertainty in position in any speed not just 0 m/s. what i am asking is, what happens to electron at zero speed, what are the consequences of λ being equal to infinity.
i know those things about wave but i don't think that electron is moving up and down just like that. it that would be the case the the up and down motion itself would generate another wave and that would generate another one and etc...
