Proving vector calculus identities using summation notation
The discussion revolves around proving vector calculus identities using summation notation, specifically focusing on the properties of derivatives and the Kronecker delta in the context of vector fields and their potentials.
  • Participants explore the relationship between partial derivatives and the Kronecker delta, questioning the implications when indices are equal or not. There are attempts to express vector identities using summation notation and to clarify the use of indices in differentiation.
Some participants provide guidance on simplifying expressions and avoiding unnecessary conditions in proofs. There is an ongoing exploration of the implications of constant vector fields and the conditions under which certain identities hold, with no explicit consensus reached on all points.
Participants express confusion regarding the use of indices and the application of the product rule in differentiation. There are also references to homework constraints and the need for clarity in mathematical notation.
lostminty
[itex]\frac{∂x_{i}}{∂x_{j}}[/itex] = δ[itex]_{ij}[/itex]
[itex]\vec{r}[/itex] = x[itex]_{i}[/itex]e[itex]_{i}[/itex]
[itex]\frac{∂x_{i}}{∂x_{j}}[/itex] = 1 iff i=j
δ[itex]_{ij}[/itex] = 1 iff i=j
therefore
r[itex]^{2}[/itex] = x[itex]_{k}[/itex]x[itex]_{k}[/itex]
[itex]\vec{r}[/itex] = x[itex]_{k}[/itex]e[itex]_{k}[/itex]
[itex]\vec{r}[/itex] = x[itex]_{j}[/itex]e[itex]_{j}[/itex]
r[itex]^{2}[/itex] = x[itex]_{k}[/itex]e[itex]_{k}[/itex][itex]\bullet[/itex]x[itex]_{j}[/itex]e[itex]_{j}[/itex]
= e[itex]_{k}[/itex]e[itex]_{j}[/itex]x[itex]_{k}[/itex]x[itex]_{j}[/itex]
e[itex]_{k}[/itex]e[itex]_{j}[/itex] = δ[itex]_{jk}[/itex] = 1 iff j=k
r[itex]^{2}[/itex] = x[itex]_{k}[/itex]x[itex]_{k}[/itex] iff j=k
([itex]\nabla[/itex]r[itex]^{2}[/itex])[itex]_{j}[/itex]= [itex]\frac{∂}{∂x_{j}}[/itex]([itex]x_{l}[/itex][itex]x_{l}[/itex])= 2x[itex]_{j}[/itex]
r[itex]^{2}[/itex] = [itex]x_{k}[/itex][itex]x_{k}[/itex]
pretty confused by now, so far I've guessed my way through.
is the j index communative? if so where did the l index come from. there is only 2 l's so maybe they cancel and you get x[itex]^{2}[/itex] which differentiation gives 2x. and it inherits the i index from the d/dxi.
hi lostminty! :smile:
(try using the X2 button just above the Reply box :wink:)
therefore
fine :smile:
no, the whole point of knowing that ∂xi/∂xj = ejek = δij
is that this notation enables you to avoid using those "iffs" …
ejekxjxk
= δjkxjxk
= xkxk :wink:
(and try the third one again)
Ok, sounds good.
so
3. Attempt at solving
([itex]\nabla[/itex]r[itex]^{2}[/itex])[itex]_{j}=[/itex]
[itex]\frac{∂r^{2}}{∂x_{j}}=[/itex]
[itex]\frac{∂}{∂x_{j}}(δ_{lm}x_{l}x_{m})=[/itex]
[itex]\frac{∂}{∂x_{j}}(x_{l}x_{l}) =[/itex]
[itex]\frac{∂}{∂x_{j}}(x^{2}) =[/itex]
[itex]2x_{j}[/itex]
lostminty said:
so
ok so far :smile:
(though you could miss out the line with δ, it's not necessary)
no, you need to turn [itex]\frac{∂}{∂x_{j}}(x_{l})[/itex] into a δ :wink:
What does it equal if [itex]i\ne j[/itex]? Don't you think you should say that?
therefore
lostminty said:
Ok, sounds good.
so
[itex]2x_{j}[/itex]
hmmm
so
[itex]\frac{∂}{∂x}(x_{l}x_{l})_{j} =[/itex]
[itex]\frac{∂}{∂x}(x_{l}^{2})_{j} =[/itex]
[itex]\frac{∂}{∂x}x^{2}_{l}δ_{jl} =[/itex]
if l=j [itex]δ_{jl}=1[/itex] else [itex]δ_{jl}=0[/itex]
[itex]\frac{∂}{∂x}x^{2}_{j} =[/itex]
[itex]2x_{j}[/itex]
lostminty said:
[itex]\frac{∂}{∂x}(x_{l}^{2})_{j}[/itex]
but that doesn't mean anything! :redface:
lostminty said:
hmmm
Still struggling with the concept. So I can use a kronecker delta to have the condition of index l being j...
[itex]\frac{∂}{∂x}(δ_{jl}x_{l}x_{l})_{j} =[/itex]
( [itex]δ_{jl}=1[/itex] if l=j else 0)
[itex]\frac{∂}{∂x}x_{j}x_{j} =[/itex]
[itex]2x_{j}[/itex]
(just got up :zzz:)
you need a push-start :wink:
∂/∂xj (xlxl)
= (∂/∂xj xl) xl + xl (∂/∂xj xl)
= 2(∂/∂xj xl) xl
carry on from there :smile:
(just got up :zzz:)
∂/∂xj (xlxl)
= 2(∂/∂xj xl) xl
That makes sense! So you do it that way because you can't have x2 instead you do product rule
= 2(∂ xl/∂xj) xl
= δjlxl
if l=j
= 2xj
well I'll assume that's close to right and move onto the next problem which seems to make sense
[itex]\nabla\cdot \vec{r}=[/itex]δii=3
∂xi/∂xjij
[itex]\nabla\cdot \vec{r}=\nabla_{i}r_{i}[/itex]
= ∂/∂xiri
= ∂xi/∂xi = δii
=[itex]\sum[/itex] between i=1 and 3 of δii
=[itex]\sum[/itex] between i=1 and 3 of 1
= 1+ 1 + 1
=3
hi lostminty! :wink:
yes :smile:
= 2(∂ xl/∂xj) xl
= δjlxl
if l=j
= 2xj
that "if" line is unnecessary and wrong
stop putting "ifs" into your proofs! (what is it with you and "if"? :rolleyes: do you keep saying "if" in ordinary speech?)
the δ takes care of that!
(and you missed a "2" :wink:)
= ∂/∂xiri
= ∂xi/∂xi = δii
= 1+ 1 + 1
=3
yes that's fine :smile:
(though i'd be inclined to shorten the ending to just δii = 3 or δii = trace(δ) = 3)
This is another problem I'm a bit stuck on with similar content
F is a constant vector field. hence [itex]\nabla\cdot[/itex] F = 0
this means there is a vector potential F = [itex]\nabla\times[/itex] A
also [itex]\nabla\times[/itex] F = 0
this means there is a scalar potential F = [itex]\nabla[/itex] ∅
verify
∅ = F [itex]\cdot[/itex] r
and
A = 1/2F x r
= Firi
= [itex]\nabla[/itex] (Firi)
= ∂/∂xk (Firi)
= (∂Fi/∂xk)ri + (∂ri/∂xk)Fisince [itex]\nabla\cdot[/itex] F = 0
(∂Fi/∂xk)ri = 0
and
∂xi/∂xj = δij = 1 when j=i
(∂ri/∂xk)Fi = δikFiei = Fiei = F
verify
and
A = 1/2F x r
F = [itex]\nabla\times[/itex] A = [itex]\nabla\times[/itex]1/2F x r
1/2F x r = 1/2εijkFjrk
F= [itex]\nabla\times[/itex] 1/2εijkFjrk
= εimn∂/∂xi(1/2εijkFjrk)m
=∂/∂ximjδnknjδmk)(1/2Fjrk)m
=(1/2)∂/∂xi(Fmrn - Fnrm)m
hi lostminty!
verify
= Firi
no, leave out "F = " … that's what you're trying to prove!
= ∂/∂xk (Firi)
no, you need to write either
[itex](\nabla[/itex] (Firi))_k
= ∂/∂xk (Firi)​
or
= ∂/∂xk (Firi) e_k​
fine :smile:
(∂Fi/∂xk)ri = 0
no, that doesn't follow at all, does it? :redface:
((∂Fi/∂xk) has nothing to do with [itex]\nabla\cdot[/itex] F)
you need the stronger condition, that F is constant
and
you're doing it again! :rolleyes:
using "when" is the same as using "if"!
just write "∂xi/∂xj = δij"
where did those e's suddenly come from?
if you were going to use them, they should have been there from the beginning :wink:
(i'll look at the other one later)
