Linear Independence: What It Is & When to Use
The discussion revolves around the concept of linear independence, particularly in the context of vectors and functions. Participants explore definitions, implications, and examples related to linear independence and its relationship with orthonormality.
  • Participants question the definition of linear independence and its application to sets of vectors and functions. There is a discussion about the relationship between orthonormality and linear independence, with some participants providing definitions and geometric interpretations.
Several participants are actively engaging in clarifying the concept of linear independence. Some have provided definitions and examples, while others are questioning assumptions and seeking further understanding of the implications of orthonormality.
There is a mention of the need for context when discussing linear independence, as well as the importance of understanding the geometric implications of the concept. Some participants express confusion over specific statements and seek clarification.
sncum
Any one please tell me about the term linear independence?and when we say that the function is linear independent
You need to supply context. Usually linear independence refers to a set of vectors or a set of functions. These things are called linearly dependent if some linear combination = 0. If not then they are linearly independent.
[A][/A]=[c][/1]x+[c][/2]y[j][/j]+[c][/3]z[k][/k]
when we say it is linearly independent
and also my friend argue with me that orthonormality implies linear independence but i was not satisfied please help :smile:
I don't understand your first line.
However your friend is correct, if two vectors are orthogonal (unless one of the is 0) they are linearly independent. Note that the converse is not true.
A set E is said to be linearly independent if for all finite subsets ##\{x_1,\dots,x_n\}\subset E## and all ##a_1,\dots,a_n\in\mathbb C##,
$$\sum_{k=1}^n a_k x_k=0\quad \Rightarrow\quad a_1=\dots=a_n=0.$$
Suppose that E is orthonormal. Let ##\{e_k\}_{k=1}^n## be an arbitrary finite subset of E, and suppose that ##\sum_{k=1}^n a_k e_k=0##. Then for all ##i\in\{1,\dots,n\}##,
$$0=\langle e_i,0\rangle=\langle e_i,\sum_k a_k e_k\rangle=\sum_k a_k\langle e_i,e_k\rangle=\sum_k a_k\delta_{ik}=a_i.$$
Geometrically, linear independence means each vector contributes something to the span of the vectors.
So, if you have one vector, it spans a 1-dimensional subspace. If you add another vector to the set, you get a linearly dependent set if the span doesn't get any bigger. So, two vectors are linearly dependent if one is a multiple of the other. So, if you added a vector that was pointing in a different direction (and not the opposite direction), together they span a 2-dimensional subspace. In that case, they are said to be linearly independent.
So, in general, if you have n vectors, they are linearly independent if throwing one of them out makes them span a smaller subspace. If you can throw one out without changing the span, they are linearly dependent.
This picture is less accurate, but still helpful, for more general vector spaces, in which the "vectors" aren't exactly "arrows" pointing in space anymore.
Functions are really a kind of vector because vectors are things that you can add together and multiply by scalars. So, it's the same idea for functions.
Thank to all of you
  • · Replies 30 ·
  • · Replies 28 ·
